Question about Hampton Bay Dryers
Fccid chq8bt9051t not functioning other than light on/off
Why is the light not working on my harbor breeze fan kujce9603? The bulbs are fine. Please advise.
Here is the manual on the remote.
https://fccid.io/document.php?id=893958
These remotes can fail and often times do if the wattage on the lights is too much. Also they can become disconnected from the wire to the lights. Be careful if you work on it. Turn off the power at the breaker. Get an assistant because those fans are heavy.
Feb 18, 2017 | Dryers
Tip
How to get a manual for most any electronic device.
This will help you obtain a USER'S MANUAL or other relevant information for just about any electronic device out there, provided it was filed with the FCC (which is nearly every legal device). This will work for everything from Mobile Phones to Bluetooth enabled Devices to TVs and Universal Remotes to Appliances and just about any other device you can think of.
Just follow the below steps.
Locate the FCC ID, either on the product or the packaging.
Examples: BCGA1241 or DZL201678 or YPD-HF300
Note: hyphens (-) are counted as part of the FCC ID and should be entered as a character. It is also good idea to have the model number handy in the case that there are multiple listings, though most times you can figure it out after the search.
Goto FCC Search Site: http://transition.fcc.gov/oet/ea/fccid/
Enter FCC ID, including hyphens (see image below).
First Field (Grantee Code): (First three characters of FCCID)
Second Field (Product Code): (Remaining characters of FCCID)
Locate your specific model, then click the "Detail" link.
http://i.fixya.net36dca14.png
Then, select User Manual (usually a PDF file, so you will need a reader).
http://i.fixya.net3ecaa2d.png
Note: If this helps you, please remember to give me a vote and rating.
Thanks.
on May 26, 2010 | Lands Phones
WHATS THE FCCID
Contact a Nissan dealership near you, provide proof of ownership and your VIN # and they should be able to give you the Federal Communications Commission I.D. number for your electronic key device. Best Wishes
Sep 02, 2014 | 2009 Nissan Maxima
CHQ8BT9051T
Yes. Call Minka aire @ 1-800-307-3267
Jul 16, 2014 | Minka Aire Ceiling Fan
Type : RM-84 model:n70-1 FCCID:QFXRM-84 IC:661Z-RM84 359381/00/499644/4 CODE:0534654 MADE BY NOKIA
i want to unlock code for n70-1 type:rm 84 model:n70-1 fccid:qfxrm 84 ic 661z-rm 84 359367/00/363516/6 code:0524109
Feb 16, 2012 | Nokia N70 Cellular Phone
Not charging and no light saying it is
There is a possibility that the battery could not be taking the charge, but typically the light is red while charging and green when done. Sometimes if the is fully drained it can take up to 15 or 20 minutes before the red charging light comes on. Try leaving it charging for 24 hours.
May 05, 2010 | LG HBM210 Bluetooth Headset Wine Red Color
LG HBM- Bluetooth- need to find how to link
Strat with headset 'OFF' then hold power button until light flashes blue and red or solid blue, then search for headset on phone, pass key should be 0000, 1111, 1234.
You can get the manual by searching for the FCCID, which should be in the headset https://fjallfoss.fcc.gov/oetcf/eas/reports/GenericSearch.cfm
Apr 30, 2010 | LG HBM-760 Bluetooth Headset
Is keyless remote fccid#a269zja073 compatable with
only the dealership can give you that answer.
Oct 09, 2009 | 1997 Infiniti.5 Q45
Dryers Logo
418 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
