Question about RCA 32V550T 32" TV
RCA 25GT511 - fuzzy picture slight static sound; wiggle coax rear mount temp resolve
My RCA 25GT511 has a slight static sound and the picture is somewhat fuzzy. If I wiggle the coax mount at the rear, it will temporarily resolve but then return. It is NOT the coax cable to the tv that is the problem. But where the coax enter the rear of the tv. I opened the back and see where the male end enters a silver box. I am lost from here... and suggestions redbyrd
    Genius:
  • 1,139 Answers
There might be a bad (loose) connection in the RF isolator or the tuner (both are silver boxes. Try to unplug the coax and bend the RCA tabs in so that the connection gets firmly made when reconnected. This may help. If it does not The connector may have to be replaced.
Posted on Sep 19, 2007
RCA 27 inch ColorTrak Plus. TV is hooked to cable. I can produce the problem by wiggling the coax connector. The screen goes through various degrees of snowy-ness until I find the sweetspot on the coax....
The failure with this TV is due to faulty ground in the tuner that is why when you wiggle the cable connected to the tuner the picture clears up. If this failure is not repair, it will corrupt the data on the eprom until the TV will not power ON anymore.
Check the info from this link to find more info on the failure of your TV.
Let me know if you require further assistance.
Apr 12, 2010 | RCA F31672ET TV
We had to move our tv for the installation of dish network. Since then, tv will start to have interference and loud static. Problem can be fixed by slightly pushing on either side of the cabinet front. Any...
im assuming this is hooked up with the coax from the satellite have you checked to see that the cable is tight and secondly that your rf fitting is not loose at the back of set and rechecked your cabling
Oct 26, 2009 | RCA HD52W56 52" Rear Projection HDTV
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
Power light flashes 3 times and makes and alarm or chirping sound then nothing. its a 52 inch RCA hd52w59 itc222 chassis. I replaced cp150 and cp120/114 and also flyback transformer and still same thing? I...
Chirping sound is coming from coil on right side behind FBT, resolder then use Glue gun to glue on top of coil LL037,Make sure high voltage wire from FBT to Trippler is in Good this is what maybe causeing lines and fuzzy picture.Also make sure solder on all pinns of FBT are good.
Sep 22, 2009 | RCA HD52W59 HDTV Projection Television
Fuzzy picture
Tryi going threw video jacks instead of coax cable see if that works better
Jul 18, 2009 | Mitsubishi VS-5047 50" Rear Projection...
How do I repair where the coax cable connects to my 13 in TV
go to RADIO SHACK and get a RF MODULATOR ,this will do the trick , good luck , AJ
May 22, 2009 | GE 32GT740 32" TV
No picture but noice
Its possibly a defective vertical output IC as that can cause the picture tubes to blank out and volume will audio will remain.
Jul 06, 2008 | Hitachi 50UX57B 50" Rear Projection...
GE Model #25GT511 Power on, no picture or sound
The question I have is if the tv stays on but with no pix or sound,we have a way to check,if you place your forearm in the face of the picture tube and the hair in your arm stands up it means you have the high voltage needed to light up the tube but something else is missing like the screen voltage or it has a loose conection in the crt board,if the hair in your arm does not react to static then we are missing the high voltage and the problem might be more involved and related to the horizontal circuit not creating the high voltage needed.If you are familiar with tv service you have a few places to check but if you are not to familiar play it safe and call for assistance from a professional servicer.Let Us know how it goes please.
Oct 25, 2006 | GE 25GT511 25" TV
Snow on screen/wiggle the coax
SOUNDS LIKE BAD SOLDER CONNECTIONS IN SIDE THE TUNER. TAKE THE BACK OFF AND TRY TAPPING AROUND WITH YOUR DRIVER HANDLE THIS WILL LEAD YOU TO WERE THE PROBLEM IS. THEN WE TAKE THE TUNERS APART AND RE SOLDER THE CONNECTIONS,BUT YOU HAVE TO BE VERY GOOD OR YOU WILL MAKE MATTERS WORSE.
Apr 11, 2006 | RCA P52830BL 52" Rear Projection...
RCA 32V550T 32" TV Logo
190 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
