Question about Dual Xr4115 Mechless Digital Media Receiver 200w
My Dual X4115 was working until I plugged in the USB with an external drive. It was loading and nothing happened. I took it out and tried to use the one I normally use and now nothing plays. Not even the radio. It looks like it's on but I don't get any sound. Please help before I rip it out of my Jeep.
4 Suggested Answers
SOURCE: My Dual XDM7615, will not even shut off and no buttons will work
unplug the reciver from the back of it and wait for 20 sec. and plug it back in, this should allow you to eject. now turn off your car and jush eject, when it opens to eject's push the release button on the back of the face like your removing it but instead force the face to completely go down, as far as it will go. now turn your car on and put a cd in and see if that works for ya.
Posted on Apr 27, 2010
walesarumi
  • 6993 Answers
SOURCE: My dual xdvd710 was working
your dual xdvd710 is having a power problem. The power board is defective that's why the dual xdvd710 is not powering on. One way or the other, the power board has been affected.
A component on the power board like capacitor may have been defective.
Detach the dual xdvd710 from the truck, get a screw driver, disassemble the dual xdvd710. Use a meter to read the power board of the dual xdvd710, in other to detect the bad component. Make necessary replacement and the dual xdvd710 should power on again.
Purchase the replacement online or at any electronics accessories store within your vicinity.
Good luck.
Posted on Dec 06, 2010
BaronVonNuke
  • 1915 Answers
SOURCE: Just installed a Dual XD760BT head unit and everything plays through the speakers(usb,aux and bluetooth) except for the radio. It makes no sound whatsoever. Any ideas
I would double check your antenna connection to make sure it is solid.
Posted on Jul 04, 2016
I cannot put files on my external hard drive
just plug your hard drive in another noze of usb...
if u have loose connection in usb then it will happen. try to copy small size of data
Sep 01, 2012 | Western Digital My Book Essential 1TB...
My Ovation 320GB external hard disk is not showing on the computer when I plugged in although the red light is on. There's a sound from the disk but after that while it just remain quiet and nothing...
I would try to plug it into a different USB port on the computer or try and see if it works on another computer. It could be that the computers USB port is no longer working or that the drive has failed.
Mar 29, 2011 | Western Digital Elements powered by WD 320...
When connecting iphone in usb port, display stays reading and nothing happens on dual xdm6350
ANSWER:
The USB is not going to work with your iPod. It is intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files.
REASON:
The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer.
Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
SOLUTION:
You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
Good Luck!
- Chris Proia
p.s. Here is the User Manual for your XDM6350 : http://www.dualav.com/support/manuals/xdm6350.pdf
Mar 23, 2011 | Dual Electronics XDM6350 Car CD/ MP3...
I, im having problems with my 1.5 TB external hard drive. I've had the hard drive for three months, It's been working fine up until today. I plugged in the power cable and when i plugged the USB cable into...
Restart the compuetr and try again. be sure that the USB cord to the external HD is NOT plugged in when the computer restarts until Windows has been loaded completely.
You can also try a different USB cable and a different USB port on your laptop
Mar 21, 2010 | Computers & Internet
How do I use my simpletech external hard drive. I
I have a 500GB and a 1TB. Both drives if they work at all, is because you have to apply the power after usb is connected. The 500MB still good but the 1TB took a big dump.
Dec 31, 2009 | SimpleTech 1TB External USB 2.0 Hard Drive...
Computer doesn't recognize the external drive
I asume the connection is via an USB?
Try another usb-port and see if that helps, if not try to connect the disc on another PC (maybe a friends pc) and see is that pc recognize the disc.
Nov 21, 2008 | SimpleTech Signature Mini 250GB External...
SimpleTech hard drive not found by my computer
This may or may not help, but it worked for me! After about 4 hours of trying everything (Device Manager/Uninstall, Disk Management, etc..) nothing at all would work. The USB external hard drive would power up but when you plug it in, the New Found Hardware will pop up and search unsuccessfully for drivers for a PLUG AND PLAY external drive!?!?!
In any event, I simply plugged another USB drive into my laptop (and desktop) and viola! The new hard drive was recognized and installed immediately as 'plug and play' should do. I then unplugged the new drive and tried plugging in the one that was recognized and all of the sudden....IT WORKS AGAIN!!!!
This fix might not help anyone who doesn't have a second USB external drive, but you could try plugging another USB device in and get it to load and then unplug it and try your drive. It worked for me on my laptop and then I did the same thing to my desktop (which also wouldn't recognize it) and it worked on the desktop too! Problem solved for me, thank GOD!
Hopefully, this bypass can save you a few hours of google time and unwanted anguish. Like I said, you may not have another USB drive but try plugging in any other USB device until it loads and then unplug it and then plug in your USB drive that wasn't working. It worked perfectly for me.
Hope it helps!!!!
-BIRDMAN - BIRD ^v^
Oct 02, 2008 | SimpleTech SimpleDrive 250GB, 7200RPM,...
Wd 120gb External no longer recognised by my PC
hi there
have you tried looking at the device manager?
you can also try transfering it to different usb ports.
hope this helps
Feb 04, 2008 | Western Digital Passport WDXML800UE...
Won't recognize my USB
i have a feeling its not the hard drive thats bad i think it sounds like the case .
you can try buying another case and transfering the hard drive to it the case is around $20.00
Nov 30, 2007 | SimpleTech 250GB USB2.0 7200 RPM External...
Dual Xr4115 Mechless Digital Media Receiver 200w Logo
35 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
