Question about Minolta Di3510 Fax
Set distinctive ring - Minolta Di3510 Fax
  • Minolta Master
  • 6,696 Answers
Does not have that option. looked at the service manual. Anyone else find this option?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Dec 28, 2014
Hooking up fax to KX TG7871 Panasonic Phone
There is excellent support here on basic fax setups. You have what is known as "Distinctive Ringing Service". There are pros and cons to the various setups. I assume you recognize the rings and answer only when the ring for the landline talk comes on. The fax will pick up the faxes, and the answering machine will pick up the voice.
Need model number of your fax - google that!
Service manual for your phone.
http://service.us.panasonic.com/OPERMANPDF/KXTG7841-MUL.PDF
This link shows various configurations of setting up your phone/fax/answering machine or using an answering service.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00059780#Dist_ring
Distinctive Ringing Service setup While it is not available everywhere, a distinctive ringing service can be purchased from most telephone companies. With this service, more than one phone number is assigned to the same phone line. Each phone number will ring differently. The main number will ring with a normal single ring and the additional number will ring with a distinctive ring pattern assigned by the phone company.
When a distinctive ringing service is used, set the Rings to Answer to 2 and then follow the steps below to set the distinctive ringing pattern:
  1. Press Setup , press 4 , and then press 1 to enter the Answer Ring Pattern setup of the Advanced Fax settings.
  2. Use the Right Arrow to scroll through the available settings. When the ring pattern assigned by the phone company displays (double or triple rings), press OK .
Mar 06, 2014 | Lands Phones
COULD LEXMARK 901 FAX ANSWER THE PHONE IF THERE ARE DISTINCTIVE RINGS CALLING. (1 PHONE LINE / TWO NUMBERS)
If you subscribe to a distinctive ring service provided by your telephone company, then make sure that you set the correct ring pattern for the printer. Otherwise, the printer will not receive faxes even if you have set it to receive faxes automatically.
Press the wrench icon > Fax Setup > Ringing and Answering > set the Distinctive Ring.
May 20, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
Our HP 2140 fax under distinctive ring setting DRPD was answering under our Master ring (double Ring) until yesterday it switched inside somehow where it now answers regular phone ring instead of...
Was the fax plugged into another telephone line? Maybe a power surge?
My solution would be to reconfigure the fax from scratch to learn the ring pattern.
From the Manual:
Step 1-Teach the HP Fax the ring pattern
The HP Fax will learn the ring pattern when you call it from another telephone or fax
machine.
1. Be ready to call the fax machine.
2. Press Menu repeatedly until BASIC FAX displays and press OK.
3. Use LEFT ARROW - RIGHT ARROW BUTTONS to scroll through the options until DRPD Mode displays and press OK.
Call this fax from another fax machine... Waiting Ring...
will display.
4. Call the HP Fax.
DRPD OK will display when the pattern has been learned and the HP Fax will return
to Ready mode.
Step 2-Set up distinctive ring (DRPD) answer mode
Once you have activated distinctive ring, it becomes one of the answering modes you
can select by pressing the Mode/Contrast button.
Press Mode/Contrast repeatedly until DRPD Mode appears in the display.
• In Ready mode, DRPD appears in the right hand corner of the display.
• Now, the HP Fax will manage calls and faxes as if it were set to AUTO mode
(AUTO mode on page 28)
TIP: Distinctive ring must be set up again if you reassign your fax number
or connect the machine to another telephone line. Once set up again (that
is, the fax machine has learned the ring pattern and the answering mode is
correctly set), you should test the fax machine by calling the fax number
and another number on the same line. The machine should respond
appropriately to a call placed to the fax number with fax tones, and to a
normal telephone call with the expected ring pattern.
Mar 04, 2011 | HEWLETT-PACKARD HP 2140 Fax
Can't receive faxes from my fax machine. I can send out faxes but can't recieve any faxes in. I was told that My fax machine did not ring when someone was trying to send me a fax. They could dail my number...
Go to settings and enable Rx.
The fax machine doesn't
receive documents
automatically.
Make sure that the reception mode is set to
FAX. If you subscribe to a distinctive ring
service, make sure that the Distinctive Ring
function is set to the correct ring pattern. If you
do not subscribe to a distinctive ring service,
make sure that Distinctive Ring is set to OFF
SETTING. (See
Distinctive Ring
in Chapter 7.
This machine can also block faxes from certain numbers if you wish. Your manual is here;
http://pdf.textfiles.com/manuals/FAXMACHINES/Sharp%20UX-460%20Plain%20Paper%20Fax%20with%20TAD.pdf
Nov 20, 2017 | Sharp UX 460 Plain Paper Thermal transfer...
Can't receive fax. MP530is set on DRPD. Phone
DR is for distinctive ring, do you actually have distinctive ring from your phone company? Have you set the matching pattern into the Canon? It will only answer when it is sent the proper ring, unless you turn off distinctive ring.
Apr 20, 2010 | Canon PIXMA MP530 All-In-One InkJet...
How to set fax machine so it can accept after 2 rings?
Distinctive Ring basicsDistinctive Ring service is an optional service available from many telephone companies. The Distinctive Ring service permits you to assign more than one telephone number to the same telephone line. Distinctive Ring allows you to use a single phone line for both voice and fax calls. You can assign a unique phone number and ring pattern for incoming fax calls. When a fax comes in, each telephone number makes a distinctive ringing sound, such as a single ring, double ring, or triple ring.
NOTE: The Distinctive Ring Service is the name HP and others use to describe this feature. Distinctive Ring is also known as:
  • Call Sign
  • Custom Ring
  • Ident-a-Call
  • Ident-a-Ring
  • Ident-a-Ring
  • Multi Ring
  • Personalized Ringing
  • Ringmaster
  • Smart Ring
  • Teen-Ring
The Distinctive Ring Service allows the HP product to work similarly to a dedicated fax line. If you connect an HP fax product and a telephone to one telephone line, you can assign one telephone number for fax calls and another for voice calls.
NOTE: You cannot send or receive faxes when the phone line is in use. Even if the HP fax product has a separate telephone number, it is still sharing the same phone line. Set the Distinctive Ring Service Using the menus on the product control panel, follow these steps to set a distinctive ring pattern. Step one: Turn on Auto Answer Turn on Auto Answer by pressing the Auto Answer button on the control panel. The button light indicates when Auto Answer is on.If the button light is already on, you do not need to press the button. Step two: Set the distinctive ring patternFollow these steps to change the answer ring pattern.
  1. Press the Setup button (c01461502.gif ) on the product control panel.
  2. Press the Right Arrow button (c01185072.jpg ) to select Advanced Fax Setup , and then press the OK button.
  3. Press the Right Arrow button (c01185072.jpg ) to select Distinctive Ring , and then press the OK button.
  4. Press the Right Arrow button (c01185072.jpg ) to select one of the following options:
    • All Rings
    • Single Rings
    • Double Rings
    • Triple Rings
    • Double & Triple Rings
  5. Press the OK button to select the option.
  6. Press the Back button (c01490920.gif ) to return to the main menu.
Now if you have anymore problems copy the link from below and paste it in your address bar and it will help you further with a document. Follow all the settings in the document and your fax should be setup,keep in MIND THAT THE RINGS TO ANSWER SHOULD BE 2,SO YOU CAN RECEIVE FAXES AFTER TWO RINGS
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01647469&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3795406
Feb 01, 2010 | HP Officejet 6500 Wireless All-in-One...
How do you set HP7210 all in one for distinctive ring fax
The user manual is posted here if you have access online: http://h10032.www1.hp.com/ctg/Manual/c00278645.pdf
and distinctive ring information is on pages 77, 79, 83, 84, 97, 102, 103, 119, 187, and 189. Hope this helps you find info to set your 7210 for distinctive ringing.
Jul 15, 2009 | HP Officejet 7210 All-In-One InkJet...
Answer a distinctive ring?
No, distinctive ring is not available on this machine.
May 24, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
I need to set Distinct ring
Press Function then Data Registration press set use the Down arrow to RX setting press set scroll down to RX mode press set Scroll down to DRPD press set pess set again at Drpd Select fax and Choose your ring type.
Apr 09, 2008 | Canon FAXPHONE L80 Laser
Setting personalized ring
Its called distintive Ring. This is the instructions from the manual -
VERY IMPORTANT
If you have Voice Mail or a TAD (Telephone Answering Device) and want to keep
one of your phone numbers dedicated only to fax calls, you must leave the fax machine
in MANUAL mode at all times while using the distinctive ring feature. Here’s why:
Manual mode will never pick up a call by itself, since it is «Neutral ». When the fax
machine is in this « neutral » mode, the Distinctive Ring Feature can be activated. The
distinctive ring feature is actually an answering mode. So, do not activate FAX ONLY
mode or FAX /TEL mode while using distinctive ring; otherwise, the fax machine will
answer calls for all the numbers.
Registering the Distinctive Ring Pattern
Set the fax machine to MANUAL mode.
2 Press Menu/Set, 0, 1.
3 Press to select DISTINCTIVE:SET?, and then press Menu/Set.
4 Press to select the prestored ring pattern you want to assign, and then press
Menu/Set. (You will hear each pattern as you scroll through the four patterns.)
Be sure to choose the pattern assigned by the Telephone Company.
5 Press Stop/Exit.
and a link to the manual if you need it -
http://static.tigerdirect.com/pdf/brother-IntelliFax-775-Manual.pdf
Feb 21, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Minolta Di3510 Fax Logo
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
