Question about Garden
Adjusting the blade on a Kubota G18 ride on mower
I have tried turning the adjustment knob but it won't move, any suggestions would be appreciated.
mickey813
  • 472 Answers
SOURCE: Kubota Z18 zero turn mower won't start.
souns like the key swich is bad ck that
Posted on Oct 01, 2009
  • 133 Answers
SOURCE: need to replace drive belt on cutting deck and
You will have to disconnect the deck from the tractor. There might be some rods hanging down by the pulley on the motor. You have to loosen those not remove. Then install the new belt with the inside of belt (V) into the pulleys. The outside of belt (flat side) goes up against any idlers (oversized pulleys). Once you get the belt routed properly the belt will be snug in the pulleys. If you have excess play you have to use trial and error to get the belt routed the right way around the idlers.
Once belt is on reattach the deck and tighten the rods by the motor that keeps the belt from coming off. They need to be close but not touching the engine pulley.
Good luck and let me know if this helps.
roundo4
Posted on Oct 24, 2009
backwoodsctr
  • 169 Answers
SOURCE: Adjusting a craftsman dlt 3000 riding mower
assuming that you are working on a briggs engine? regardless of make what the problem is that the needle and seat inside the carb is not sealing off the fuel flow from the fuel pump/fuel tank or both......gravity feed fuel systems are the worst about flooding, the only fix will be a carburetor repair with needle and seat replacement
Posted on Nov 25, 2009
  • 420 Answers
SOURCE: how do you set the mower blade height on a riding
The blade height is not adjustable on any of the tractors I have worked on or owned. The blade seats against a shoulder on a spindle and held in place by a nut. Sometimes replacement blades are not shaped the same as the original and changes the blade cuttnig height but other than in those circustances there is no adjustment.
Posted on Jun 18, 2010
  • 3074 Answers
SOURCE: I have a Kubota TG1860
belts,solenoid,ignition switch and the PTO, you can hook 12v directly to PTO and see if it is engaging, the ignition switch feeds 12v to the PTO, the switch/solenoid engages with the help of the pulleys and belts, just a matter of figuring if its the belts(or in may cases the tesioner pulley) Hope this helped Tim
Posted on Apr 18, 2011
Why wont it start
Try adjusting the valves. Both intake and exhaust .004.
GOOD LUCK FRIEND.
Jun 13, 2015 | Kubota Garden
How do I level the deck on a John Deere X500 mower
FInd and buy a deck level guage (makes it so much easier) photo.25191349-sc2hyhwnmj3wm0xvqhiyjoyo-1-0_0.jpgAdjust the front tire pressures to 14 psi. Set the rear tires to 10 psi. Make sure that the mower is on level ground,concrete driveway or garage floor. Set you deck height knob to 2.5 inches. Move the blades to where the blade tips are pointing to the side of the mower deck. Level the deck side to side by adjusting the lift link nuts,15mm or 17mm wrench. Get the side to side as level and possible and close to a number or mark on the guage. Move the blade tips to the front of the mower deck. Check the front to back and have a 1/8" to 1/4" lower on the front of the blades than the back. 18mm and 19mm wrenches for the front adjusting bracket.
Oct 06, 2014 | John Deere Garden
What causes fuse to blow every time I try to engage blades?
To engage the blades is it a knob to an electric switch that you pull?
If so does the wire from the switch activate a electric clutch?
Is the wire damaged and shorted to the frame, is the clutch shorted. If you provide the brand name and model number I might be able to find a schematic for your mower.
Video shows an electric clutch but yours may be different but this should give you an idea of where to look. Riding Mower Electric PTO Clutch Won Engage When Hot Problem Fix
Oct 02, 2014 | Garden
Why does my kubota lawn mower die when i mow in reverse even when i push the button?
Check the blade housing and any build up of waste which can cause too much tension on the blades when they are operating as the unit moves in reverse. The rotor head could could be jamming. With the unit turned OFF try to move the blades clockwise and counter clockwise. There should be equal force required to move the blades in either direction. If not then clear and clean all the area and especially where the spindle comes through the body from the engine. Oil and regrease all required points.
Jul 22, 2014 | Kubota Garden
My neighbor and I just changed the blades on my Wizard riding mower. (The nuts were hard to loosen!) I bought new blades and we put them back on in the same direction as the old ones. I fired up the...
Sounds to me like the belt is too tight and not grabbing, the squealing noise is the sound of motor pulley spinning on the belt. This could also happen if belt is worn out. I'd try adjusting the belt. Hope this helps.
Sep 14, 2013 | Garden
Blades won'e engage
Your belt may be on wrong or slipping.
May 23, 2013 | Craftsman Garden
Why does the engine of my Kubota ride on cut out when cutting
Sounds like you have a bad safety switch somewhere, possibly the seat switch.
Aug 10, 2012 | Kubota Garden
24 hp LA165 mower. While mowing the mower stopped moving. Engine runs, blades turning but won't move forward or backward (the side lock has been released and the pin at the back is pushed in) 11...
check the connecting rod to the tranny. follow the gear handle and you should find a rod connecting the handle to the axle make sure you're in neutral and adjust the rod until the handle starts to move
Jul 17, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Z5426
under the seat should be 2 black adjusting knobs, left and right control arms, these are for adjusting the neutral lock position
Nov 05, 2008 | Husqvarna Zero Turn Mower Z5426
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
