Question about Plumbing
Blanco filtra The plastic casing housing the filter spontaneously cracked flooding my kitchen. Where can I get a replacement?
3 Suggested Answers
  • 1584 Answers
SOURCE: Blanco harvest kitchen faucet with pullout spray low flow rate
Check fine filter at tip, probably blocked, got caught with same thing myself recently!!!
Posted on Jan 26, 2010
  • 349 Answers
SOURCE: remove water saver device from Blanco Grace kitchen faucet
Remove the aerator at the end of the spout. It will unscrew and once off it will have a dime sized restricter in it that can be removed this restrict's the water down to about 1.6 gpm to save water.
It will either be plastic or metal and about the size of a dime with a small holw in it to let water pass by maybe 1/8" hole just remove it and put aerator back together.
Clean aerator screen out before you put it back together.
http://www.plumbersurplus.com/pdf/07163.pdf This link has a breakdown of parts. Look at parts 8b-10 for aerator breakdown.
Posted on Jun 13, 2010
At the end of my kitchen faucet a small piece of plastic which controls the water flow fell out. it's 12 years old. is it repairable?
Yesd. It simply screws out. There should be two flat spots where you can use an adjustable crescent wrench to unscrew it. Bring it to the hardware store or plumbing supply that carries Blanco so they can give you the right one.
Aug 02, 2016 | Blanco 157-085-ST Medallion Kitchen Faucet...
How does water line connections disconnect and reconnect on the water valve coming from the water filter housing?
Grab the water line close to the connection to the filter. Push the water toward the filter. In that poisition, push the round sleeve on the filter connection forward.hold it there and pull the water line out.
Dec 31, 2014 | Refrigerators
I've bought a Blanco 1.5 bowl sink. It came supplied with a universal odour trap and waste kit. I'm struggling to figure out how to fit them both without cutting some of the plastic pipe. Any...
Generally you often have to trim some of the plastic drain pipe to get things to fit in your particular situation. Just be sure to cut the end that goes into the compression fitting, Don't cut an end that has threads or a rim on it. Cut the pipe carefully with a saw or better yet a hacksaw. It enjoys cracking and will do so if given half a chance. The good news is it is chap and available at every hardware store. So cut and trim away just leave enough so that it will fit a good 1 1/4 inch plus into the other pipe. Hope this helps
Jun 09, 2011 | Blanco - Kitchen Sink - 2 Bowl - axia 6S -...
I had to replace a small section of the galvanized steel main water line at my house today. In conducting the repair, some small pieces of corrosion material entered the line. After turning the service...
it is more than likely that it is a ceramic insert and they do handle grit , dirt or anything else very well
the fix here will be to remove that ceramic insert and clean out anything that is found
a point of interest here is this
one small section equals all the pipe is in the same condition
you should consider replacing all of the gal pipe with either copper tubing or high pressure plastic pipe
Apr 01, 2017 | Blanco Classic Single Handle Faucet with...
Remove water saver device from Blanco Grace kitchen faucet
Jun 12, 2010 | Blanco 157-052-ST Grace Single Handle...
Jan 26, 2010 | Blanco Harvest Single Handle Faucet with...
Refrigerator gushing water through ice maker filter
Filters themselves don't usually leak. Check full insertion of filter, cracked filter housing or cracked supply line.
Aug 14, 2009 | Whirlpool Refrigerators
My blanco kitchen mixer does not swivel. It is stuck in one place
You need to remove the handle and then remove the top cover to the housing. After the cap is removed you can pull off the spout. It probably needs new washers. You will see what you need to fix it at this point. Just remember to turn off your water before doing this.
Mar 22, 2009 | Blanco CLASSIC 1 Handle Pull-out Spray...
Ge water filter cracks
The issue is with length of the filter and the space behind the filter allowing it to bend.
Along with many people we put a lot of things in our frig. When you jam things into your frig they can hit the filter causing it to bend towards the back of the frig. The long filter becomes a lever putting extra force on the plastic threads on the filter causing them to crack and leak.
Luckly we noticed our leak early and did not have a big leak into the floor below. But when I was removing items from the frig to get to the filter we had just bought two big gallons of milk and one was jammed into the filter.
You can try to remember to not put to much on that side, but within a month you will for get. Best thing to do until GE comes up with a better filter is to tape a wedge to the filter that fills the space between the filter and the back of the frig. That way if you jam a big gallon milk into the filter it will not bend and crack.
Jan 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Plumbing Logo
26 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
