Question about GE GSH25JFR Side by Side Refrigerator
Doors need adjustment
I have an older ge side by side. Model tfx27pf. The doors are not closing properly. They are too close together in the center and one door is a bit highre than the other. How do I correct this. It was recently moved and the movers had to remove the doors and reinstall them if this info helps.
  • colespider Mar 15, 2009
    I went back several times last nite until I figured the solution out and corrected the problem. I received your reply this morning but the info is spot on. The adjustment was under the hinge caps as you said. I looked at those earlier but could not see that one was slotted was the screw were loosened until I actually removed them. I appreciate the quick reply. Oh, you were also correct about the platic height adjuster, one was broken. Thanks again!
  • 1,543 Answers
You should be able to take the top trim caps off the door hinges, loosen the hinge screws a little, and move the door(s) away from the center of the refrig, then re-tighten the hinge screws to get the doors to stop hitting each other. You may want to check the bottom hinge(s) for the hight. The bottom hinges and the bottom of the doors have matching plastic "ramped" washers, which raise the door as it is opened, which help them to self close. If one of those is broken, the hight will be off.
Posted on Mar 14, 2009
SOURCE:
I have a GE side by side refrigerator (Model #GSL25JFXLB and the doors will not close all the way
Leveling the refrigerator so that the doors close easily is one of the most important ways of getting the doors to work properly. Here is a link to a Profile/Artica Service Manual Go to page 24 through 26 where the manual explains what you need to do to get the doors to open and close properly. If you have questions I will be here to answer any questions you may have, Thank You Sea Breeze
Mar 09, 2013 | GE GSL25JFXLB (250 cu ft) Side by Side...
Our side by side freezer door opens slightly
That is a common occurrance for side by side refrigerators. Closing the fresh food door is like having your car windows closed and closing the door. You can feel the air pressure on your ears. In the refrigerator, the air passes through the duct and into the freezer pushing the door open. The magnet on the door gasket should keep it closed. But it may be the freezer door needs the hinges adjusted to the door seats better when closed. Take the plastic cover off the top hinge and you can loosen the screws (don't take them out) and adjust the door slightly (so it looks even between both doors) and tighten the screws up. The top of the door should be level with the top of the unit, and the gap between the doors even the whole way down.
Jan 03, 2010 | GE Refrigerators
Have 36 in monogram refridgerator.....after moving units to new location,door is out of plumb and will not close properly
You will need to adjust both door at the same time. You will need a 5/16 wrench. Loosen the hinge screws on the top. Try to line one door with the center post between the doors. Open it and see if it closes by it's self. If so, go to the other door. line it up with the other door, allowing about 1/2" between them. Now see if it will close by it's self. If not, you will have to play with it. The only other adjustment is on the bottom. You will need a3/8" wrench (some have 1/2" screws). loosen screws on one side, have someone pull door up until the top is even with the top if unit. Tighten and then do the same with the other side.Once you have this done, adjust the top hinges. Good luck.
Oct 17, 2009 | GE GSH25JFR Side by Side Refrigerator
Frozen refer door prevents water from dispensing
fold the door gasket back remove screws on side,,, top... bottom ..put more insulation on hose keep it on the front side away from freezer and put it back together....make screws just snug until all are in(you may need to adjust door to close...when door will close proper tighten screws all the way
Aug 19, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
Hi I have a GE side by side and the frig door is not closing / sealing properly. Any ideas? John
close the door and test for drag on all sides. you may need to realign the door hinge adjustment. Just check the clearence around the doors, make sure the doors don't drag. you may need to tweek the doors if they apear to be sprung. last thing is to check the magnet and make sure its strong enough to pull the door closed. I use a dollar bill and slide it up and down and all around the door seal. the westinghouse repair man showed me this and it stuck with me. well i hope i was of some help thank you sawdust46
Aug 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Garage door chain is sagging
If the chain is adjusted properly the chain will sag slightly on one side when the door is closed and on the other side when it is open. It should not sag enough that it is dragging on the T-rail. You can adjust it at the trolley. If you over tighten it you will hear a clicking sound when the opener opens or closes.
Jul 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Doors are rubbing and clicking noise when closing
It sounds like your door is misaligned - try adjusting your door hinges by moving them back and tightening them - make sure your door seal is tight after or you will have air leakage problems.
May 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Doors don't swing shut automatically
The GE side by side refrigerator has 2 cams on the bottom hinge that helps shut the door. If the cam wears out then the door will not close properly. One of the cams is riveted to the hinge assembly and an extra cam is shipped with it. The cam assemblies can easily be replaced by using the information on the Partselect.com website that refers to the GE TFX22R refrigerator.
Apr 25, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
GE fridge doors open and close
Raise the legs up on front till the machine tilts slightly towards the wall. The weight of the doors will then be shifted towards the machine instead of away from it. Only a slight adjustment is needed and should have been done by the delivery guys. A $5 tip would have gotten that done, you must be a cheapskate.
Source: I used to deliver them before I learned how to fix them. LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Condensation inside top near the center
Check your owners manual to see if your model has an "energy saver" switch somewhere. That switch turns on or off the heating around the doors to prevent moisture/condensation, etc. If it does, take it off the energy savings mode and put it in the other mode (energy savings means the heater is off to save a tiny bit of electricity over the years time). Also use a dollar bill and close the door on it to see if you can pull it out with the door closed, it should be a slight pull to remove it if the gasket is sealing right. Do this around the whole door a couple inches at a time and see if you have the same friction on pulling the bill out the sealed door.
Feb 04, 2007 | GE PFS22SISS
GE GSH25JFR Side by Side Refrigerator Logo
340 people viewed this question
Top Refrigerators Experts
Brad Goodale
R.A. Ellis
R.A. Ellis
Darrin P. De May
