Question about Sony Bravia KDL-32BX300 32" 1366 x 768 1000000:1 LCD TV - KDL-32BX300
Sony model #KDL-32BX300 has vertical lines
Need to know what boards I need to change or repair
ProMonkey
  • 59 Answers
SOURCE: Sony Bravia KDL-46Z4100
if the line is in the same place all the time im afraid to say that is a pixel problem on your display contact sony they may offer you a replacement display or altleast a way of changing the set.
Posted on Mar 10, 2009
jerryg50
  • 1667 Answers
SOURCE: SONY KDL-52xbr4 - lcd panel shot after 17 months
This can be the panel itself, and or the matrix decoder/driver boards. The cost of this type of repair can approach the cost of a new set. From your description, I am thinking it is the panel itself that has failed.
Parts for your set are from Sony only because there is no third party manufacturing for these types of parts and assemblies.
Usually, when these types of sets become defective they are usually not worth servicing. During warranty the manufactures generally give a new set to the client, or they give a re-built set which has been built up using parts and modules from other sets that came back for service and had different types of problems.
If you know a tech is is good at servicing these types of set, maybe he can find a number of scrapper set of the same model to take parts from. You just have to hope the ones he finds have the same types of fault.
Jerry G.
Posted on Aug 06, 2009
  • 51 Answers
SOURCE: I have sparkled vertical lines of color on my Sony
the lcd controller is a seperate part that can be replaced you don't have to replace the whole panel if the controller is bad
Posted on Aug 08, 2009
vinnyq
  • 157 Answers
SOURCE: Sony Bravia KDL-40S2000 thin vertical line
If the line is present in all inputs and modes, there is a problem with the LCD Panel. The only way to fix it is to replace the whole LCD Panel which is very expensive (usually around $1000+ for 40" Sony). Unless the TV in under warranty, it is usually around the same price for a new TV.
Posted on Oct 05, 2009
Testimonial: "Thanks for the response. The service company Sony recommended told me it was probably the screen, too, and they quoted $1000."
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
Tcon BRAVIA 2010 sony kdl-32bx300
The T'Con is a built in part of the display panel, and cannot be replaced. The display panel should be replaced with a new one.
Dec 31, 2016 | Sony Bravia KDL-32BX300 32" 1366 x 768...
Sony Bravia Bx 300 Blinking Light/Volume
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. You can get a clear idea about which board should be replaced.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 30, 2016 | Sony Bravia KDL-32BX300 32" 1366 x 768...
I have a Sony KDL-32BX300 showing vertical lines. Is this repairable?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Apr 30, 2015 | Sony Bravia KDL-32BX300 32" 1366 x 768...
Sony Bravia KDL 32BX300 Error codes
Five blinks denotes an IRK error. To detect damaged components and to troubleshoot this error, you must have sound in electronics.
May 21, 2013 | Sony Bravia KDL-32BX300 32" 1366 x 768...
Remote code sony bravia
Almost any Sony remote will do the basic things--If need to replace the remote go to the Sony consumer site with model number or call them.
Don't waste your time and money on a Universal remote.
May 03, 2012 | Sony Televison & Video
I need a manual for a Sony Bravia KDL-32BX300
Go to this link, and follow the instructions. Not sure sure if it is totally free as advertised, as I have never personally used it. Good luck.
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/KDL-32BX300-_E
Mar 31, 2011 | Car Audio & Video
I have a Sony Bravia KDL-32BX300 the screen is cracked and broken where can i find a replacement screen
i have a Sony Bravia KDL-32BX300 the screen is cracked and broken where can i find a replacement screen
Aug 25, 2010 | Sony KDL32BX300 32 in. TV
I have a Sony 26 inch Bravia LCD tv model KDL-V26XBR1.It has thin vertical black and yellow lines about an inch apart across the whole display. Not noticeable from a distance but really see them up...
Well if the panel is bad it would not clear up in any situation, so its not the panel. most likely the t-con board or just poor connections inside. Julio Millenium TV in Las Vegas.
Dec 18, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony Bravia KDL-32BX300 32" 1366 x 768 1000000:1 LCD TV - KDL-32BX300 Logo
41 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
