Question about Welding Tools
Powcon 400ss welder
Low output and ticking sound
Low output on silverline inverter welder 633822
Got anyone around with a multimeter? You need to see where the power drops -- primary or secondary side, control circuit, etc.
Aug 25, 2014 | Welding Tools
Ranger 10,000 has low weld output and ac output
This is not a simple question. Take this magnificent machine to a service shop.
Aug 25, 2014 | Lincoln Electric Ranger 250 GXT AC/DC Arc...
200P AC/DC /PLASMA WELDER WONT WORK
try cleaning the ground inside the welder. and make sure you have a good power supply ie. power cord. check the transformer for continuity and clean all the contacts ( are you sure the power inverter diodes are only passing current one way and are not "open" )
Nov 24, 2013 | Welding Tools
Powcon sm400 welder fluctuates amperage. please help
May be you need to have one better UPS that have regulator integrated.
Oct 19, 2013 | Electronics - Others
Miller welder 330a/bp it will not weld in D/C straight or reverse no ark but will work in A/C its like there is very low volts I was welding and then could not strike a ark
It's likely that your pedal is the problem. Pull the cover and check it electrically - these have been problematic in the past. You can further troubleshoot by selecting constant output and test the output.
Nov 09, 2011 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
No or little ac output
By ac you mean receptacles, not ac welding?
If so what about welding output on AC (DC)?
If welding is OK then you may have breaker or fuse problem.
If welding output is also low or no output your problem is the generator.
You should check your gen rpm to be normal. If so you may have field problem: rectifier, AVR etc.
If you can measure the field DC voltage at rated rpm, if it is missing (very low) try to find any circuit broken.
If you do not succeed answer this instruction in order to give you more.
Jul 20, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
No welder output
Sounds like a control board problem, would much more info to diagnose.
May 29, 2009 | Lincoln Welding Tools
Dead unit Cyclomatic PowCon 300 SM
Well John Henery I'm new to this type of correspondence,but I'll give it a try!
#1 Disconnect from power & remove the 10 bolts holding the cover.(There should be diagams by each of the 3 jumper sets to be changed.)
#2 Standing at the front look to the rear left ,and you should see 4 studs. (Dotted line=buss jumper)
x----x x----x x x----x x
240V 480V
#3 At the front center down low there will be 4 more studs.
240V 480V
#4 On the right rear there is a vertical board with 10 studs.
x x x x x x
x x x x--------x x
x x x x--------x------x
x x
(240V) (480V)
As far as your no power problem look at the main power switch. Of the wires that go to the welder, 3 will go to the power board, and 2 to the control board. When you hook the power cord to the house power you need to make sure to use the 2 cord conductors that will also feed the control board.
I do have an operator's manual for a 300SM, contact me at blandt101@att.net ,and I'll get you a copy.
Tom
Apr 10, 2009 | Miller Welding Tools
Ticking sound
ticking sound (like a Watch) coming from around the Flyback Transformer but I don't see a spark is called EHT voltage . if eht voltage is ok 1 check filament is glowing or not if it is ok check voltages on crt. 2 if it is ok check luminance section in chroma section. if filament is not glowing check for low eht due to hor section check power supply output also. good luck
Sep 18, 2007 | GE 25GT270 TV
Welding Tools Logo
76 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
