Question about Hyundai ImageQuest HQL260WR 26 in. HD-Ready LCD Television
Hyundai LCD TV HLT 3010 Pictue suddenly turns black but has voice
Hi, I've a Hyundai LCD TV (HLT 3010) for 2 years plus. Recently, it has a problem. The pictue suddenly turns black but still has voice when it is powered up from off to 2 min, after that it is ok. It seems need to warm up. Between from off to 2 min period, I try to switch to other channel, after 2 or 3 sec, it turns to black again and keep the voice. I did check the power supply, the plug is firmly connected, no loose. Kindly advise what's happened and can I fix myself? Thank you very much Best Regards, Edmund
  • Anonymous Feb 21, 2009
    hi my tv turn on with voice but no pic.after manny turn on off it comes for 2 secand then go black
This is quite a common problem on LCD televisions.
It is not a fault you can repair yourself unless you are a competent electronics engineer.
One of the transformers on the inverter board will be the cause as the tend to go open circuit. Being surface mounted adds to the dificulty of changing this item as well.
Posted on Dec 18, 2007
Hyundai hlt 3270 can't connect to my direct tv hd box
I know this is an old post but the solutions helped me just recently. My hyundai does not have a hdmi port and I was very frustrated. Luckily I had an old rca connector. The green blue and red cord with the white and red audio connector. If your hdmi box does not have this option you are sol. Call your cable company and request one. This is the only solution. Hyundai tvs are garbage. Good luck.
Aug 28, 2012 | Hyundai ImageQuest HLT-3270 Television
46in Vizio LCD HDTV distorted black picture when tv is turned on
Hi There are three things that can cause this problem. Your lcd screen, t-con board or the signal board. Most likelly in your case since you say it's only half the screen it's going to be your t-con board. You can try removing it and cleaning all the contacts and replacing it see if that helps. If that doesn't help then replace it. If that does not solve it then it's going to be your screen.
You can get parts at www.interliquidparts.com
Nov 28, 2011 | Vizio VW46LFHDTV10A 46 in. LCD TV
I have an lg 52LG70, 3 years old. recently, after i hit the on button, the tv will come on, but within seconds, fades to black, starting at the corners, moving to the middle. still have audio. a few...
Tv have 2 long LCD inverter boards it probally require replacing.These 2 long LCD inverter boards job are to provided the tv LCD screen panel to have a backlight to the tv LCD screen panel to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 2 long LCD inverter boards for the replacement.
Mar 22, 2011 | LG 52LD550 52Inch 1080p 120Hz LCD HDTV...
Philips 32PFL5332D 32 won't power up.
U have a LED green light indicator on the LCD panel blinking?Yes,the tv is worth fixing.The power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.The average price of a refurbish power supply board is between $100-$120 plus shipping.
May 06, 2010 | Philips 32PFL5332D 32 in. LCD Television
Watching dvd, great pictue and all of a sudden black out
7 Blinks is the failure of the SC/SU/SD PCB's (1 2 or 3 depending on how lucky/unlucky) you are.
Panasonic have a great warranty usually. Give them a ring, it has failed.
The flashing LED is the fault code.
Sep 06, 2009 | Panasonic TH-42PZ77U TV
Looking to buy a Polaroid TDA-03211C the needs repair
I have a 3 year old TV with the same problem as shema_ross.
Aug 16, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Hyundai 32''LCD with No red power indicator.
G'Day!
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need further assistance so that I can help you further.
Jul 11, 2009 | Hyundai VVUON E323D LCD-TV 32 in. LCD TV
Gateway shd 3010 LCD goes black
I have the same problem now!!! Did you ever find a solution?
Jan 02, 2009 | Gateway SHD-3010 30 in. HD-Ready LCD...
Hyundai ImageQuest HQL260WR 26 in. HD-Ready LCD Television Logo
791 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Jaime Hernandez
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
