Question about Sewing Machines
How to change light bulb on singer inspiration 4220 sewing machine
2 Suggested Answers
  • 323 Answers
SOURCE: Singer-Inspiration 4220/4228
Send this machine back where it came from! machine. You have described a timing problem which you can not and should not need to do.
Change the needle first and test it to be sure the needle still hits on the hook. If it does,follow the above instructions. If it no longer hits then it's possible it is not as serious as I first thought.I'm not sure if the bobbin keeps coming out or the bobbin case(the plastic part the bobbin sits in) comes out.If it is just the bobbin, insert the bobbin in the case and pull on the thread. The bobbin should turn COUNTERCLOCKWISE. If it turns the other way, turn it upside down and try it again.
If it is the bobbincase,then Remove the needle plate and take the bobbin case completely out. On this machine there is a small lever which holds the bobbin case in position. Looking down on the bobbin case the lever is located at about 11 o'clock and has a small slot in it. It is also probably spring loaded which means it is not easy to turn without a small screwdriver. Insert the screwdriver in the slot and turn it to the left. Lift out the bobbin case and Carefully examine it for any nicks, scratches or rough spots. If you find any, they will need to be removed with an emery stick and or a sharpening stone. Buff with a very fine steel wool for total smoothness.
To replace the bobbin case use the screwdriver to open and hold the lever open while you insert the case back in. The straight part of the case will be on the right and you need to place the case so that the circular part rides on the slight grove in the hook.(The metal thing it sits on). Once you have it in place you can release the lever you've been holding open . It should fit over the edge of the bobbin case and not allow it to come out. Rethread the machine and turn it by hand a few times to see that it is working properly. Good luck!!!
sewman7
Posted on Jul 01, 2008
THREADING AND BOBBIN LOADING HOW?
http://www.singerco.com/uploads/download/492_4228_4220_030707_new.pdf or http://www.youtube.com/user/SingerSewingCompany or http://www.singerco.com/sewing-resources/operation-basics
Feb 16, 2014 | Singer Inspiration 4220 Mechanical Sewing...
Bottom thread: you can pull right out of material after stitched.
Very vague question... well it's not even a question. If the bobbin thread is straight with little loops... your top tension is too loose. Tighten it.
Sep 24, 2013 | Singer Inspiration 4220 Mechanical Sewing...
Singer 4220
try changing the needle
rethread the machine top & bobbin
check to see if the thread has come off the thread take up lever
clean under the needle plate & in the bobbin area for lint & thread
May 02, 2012 | Singer Inspiration 4220 Mechanical Sewing...
How do you replace bulbs for a singer inspiration machine?
Call Singer at 1-800-4singer and they can guide you through it. Joann's fabrics might be able to show you, also.
Sep 13, 2010 | Singer Inspiration 4210 Mechanical Sewing...
What bobbin should be used for a singer inspiration moder 4220
Normally it is a #15 or 15J. Your manual should tell you or you can go online at singerco.com and look under support for a free download of you manual. I checked the Singer site and you may have to have a "surefit" bobbin that is exclusive to Singer. You can call them at 1-800-4singer
Sep 08, 2010 | Singer Inspiration 4220 Mechanical Sewing...
Singer 4220 bobbin thread wont raise
To learn how to solve the bobbin problems and select the correct needle, I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional step-by-step repair guide written by an expert. Besides Singer sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Oct 23, 2009 | Singer Inspiration 4210 Mechanical Sewing...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
