Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity Front Load Washer
I have a Frigidaire Affinity Front Load Washer and I am having a problem with it. It shows as error code of E41. It does not appear to be draining all the water and is making a really loud noise when attempting to spin. I have a feeling my pump may be clogged or possibly even bad, but I cannot get the front panel off to take out the pump. I have taken the 4 screws out of the bottom of the front panel and even taken the ones out of the top, where you add detergent and softner, but I stil cannot get it off. Any suggestions on removing the panel without damaging anythign else and without breaking or damaging the seal for the washtub? Am I even on the right track with the pump? I have already checked the drain hose and the house drain, neither of which are blocked.
  • Anonymous Aug 24, 2008
    does not spin and pump motor making noise took apart and found 3 coins in back hose removed put back together but did not help
    New Friend:
Instead of replacing the door switch assembly, you may want to try this because it worked for me:
1. unplug
2. remove the door switch assembly
3. carefully take the cover off this (there are 3 plastic tabs to open it)
4. refer to this diagram http://www.applianceaid.com/ads/doorsw417.jpg and bend the contact towards the contact on the coil (away from you in this picture) with some needle nose pliers. Watch the white contact switch as it tends to pop out. before you re-assemble it, poke the switch and see if the contact makes actual contact. if it does reassemble the unit and go about your merry way. if it doesn't bend it a little bit more.
do not bend this contact any more than you have to as it will always read as door closed if it is bent too far.
Posted on Sep 13, 2010
  • Pimpcoat Jan 28, 2011
    Had a broken striker piece. Replaced that thinking it would solve the problem but still wouldn't start (kept giving "dr" prompt). Was about to order the door switch assembly and saw this post. Figured if the thing was broken anyway, what does it hurt to dissect it? Pulled apart, gave the contact a little bend and then after a few min of trying to get the stupid white contact and spring back in place, re-assembled to washer. Works great! Thanks for saving me $65!
  • tmiller332 Mar 25, 2011
    Worked like a charm. Thanks for posting
We have had the absolute worst experience with this washer. It beeps any time, turns on and off ALL the time, and we never know if and/or when the washer will actually come on and wash the clothes. I've had to smell the clothes in the morning to see if it actually turned on over night and washed the clothes.
We have had it replaced once under the warranty and will have to go back to the dealer before the warranty ends to try and get a new/different model washer - one the WORKS.
Has anyone else ever had this problem?
Posted on Jan 16, 2008
    Novelist:
    Champion:
  • 244 Answers
U should be able to get to your pump from underneath or from the back dont try taking front panel of because you have to take the lid/front fasure and then u will be able to get to the screws your pump will be blocked with more than likely blocked with a coin usual thing
Posted on Aug 12, 2007
  • 725 Answers
E41 Control board thinks the door switch is open.
to check control In the J2 plug on the control, measure voltage
from the black wire to ground with power on.
1) if 0 volts. Check the door strike. If good, replace the
door switch assembly.
2) if 120 volts. Replace the control board.
Posted on Aug 24, 2008
SOURCE:
My Frigidaire Affinity washer stopped working in middle of cycle and shows E41 code.
Hello Shawn Smith - Typically error code E41 indicates that washer has detected that the main control board thinks the door switch is open. Try reprogramming the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs.
Mar 03, 2013 | Frigidaire Affinity ATF7000E Front Load...
Fridgidaire upright washer E41
Hello Marcee Peterson - Typically error code E41 indicates that washer has detected that the main control board thinks the door switch is open. Try reprogramming the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs.
Feb 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
E41
Control board thinks the door switch is open. You may need a new door switch.
Dec 23, 2012 | Frigidaire Affinity ATF7000E Front Load...
E41 is displayed
Hello mev1985 - Error code E41 indicates that the main control board thinks the door switch is open. Contact a professional to check the continuity between the pins in the plug and door strike. The unit either has a defective door switch assembly or main control board.
Oct 05, 2012 | Frigidaire Affinity ATF6000F Front Load...
Error code e41
Hello phrainer3 - Error code E41 indicates that the main control board thinks the door switch is open. Contact a professional to check the continuity between the pins in the plug and door strike. The unit either has a defective door switch assembly or main control board.
Oct 01, 2012 | Frigidaire Affinity ATF7000E Front Load...
Hi Mr. Barry Coates, I have frigidaire ATF 6700FS front load washer. I am having problem with error code E41 and all time it shows me PAU. I tried all the solution on this site but nothing works. Could...
E41 - Control board thinks the door switch is open.
PAU means PAUSE in the cycle; if you are try all methods, I assume that the control panel needs to be replaced.
Check in this link your Control Board Replacement
Hope helps.
Oct 12, 2011 | Frigidaire ATF6700FS Front Load Washer
Frigidaire Affinity washer (LAFW3511KW0) with an E41 error. I have unplugged to reset (no change), checked the stricker (fine), removed outer seal and disconnected and reattached (I also received an E41...
Install the door lock/switch assembly with the door switch harness disconnected but "jumped". Jump a wire between the wire harness terminals and if the error code (E41) stops appearing when the machine is started, the door lock/switch assembly is indeed faulty and needs to be replaced.
Check the continuity of the door switch harness connecting the switch and terminal J2 of of the control board if the error code (E41) still appears every time the machine is started after putting a jumper wire between the door switch harness terminals.
Make sure the connectors are clean and snugly connected to both. Replace the wire harness if you are skeptical about its condition. Disconnecting the door switch wire harness (J2) from the control board and putting a jumper wire between the leads of terminal J2 on the control board will directly confirm the condition of the wire harness and the board itself. The wire harness is the problem and must be replaced if the error code E41 stops appearing. On the other hand, consider replacing the control board if the error code still flashes even when the leads of terminal J2 on the board is shorted ("jumped").
Aug 21, 2011 | Frigidaire Affinity ATF7000E Front Load...
Error code
E41 =Control board thinks the door switch is open.
1. Remove the door lock assembly and
measure the resistance of the PTC.
Shorted or open. Defective door lock assembly.
Around 1500Ohms. Defective control board
hope` this helps
Jul 26, 2010 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity atf7000es1 E41 code
check to see if the door stike is not broken on door if good and you have changed door lock asm you have a bad control board
Dec 11, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
2,415 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
