Question about Cyclops CYC-S250 Thor 2.5 Million Candle Power Rechargable Halogen Spotlight (Cyclops)
Charge adaptor need charge adaptor
Why does innotab charging light blink when charging and will not charge?
the charge imdicator is suppose to blink when you plug the toy to the wall adaptor. if it doesnt blink then there's something wrong with either the adaptor, the adaptor port on the toy or the rechargeable power packs. now i said that the light is suppose to blink. but the frequency of the blinks shouldnt be fast. if that's the case clean the compartments and re-insert the batteries. if you are still having problems try the ff T/S:
1)remove the power packs, plug the toy to adaptor and turn it on. if it turns on that means your adaptor is working.
2)remove the adaptor and try using just the power packs.
3)try using 4aa batteries.
if the toy turns on with only one of the power sources stated above you better call vtech hotline.
Sep 01, 2014 | Vtech InnoTab 3S The Wi-Fi Learning App...
Charging adaptor for motorola talkabout T5022 bought in USA
You might try contacting wirelesspro.com. They are very knowledgeable on the TalkAbout line of radios.
Best regards.
Apr 07, 2013 | Motorola Battery For Talkabout T5022 T5025...
The battery is not recharging
Possible that the battery is bad or weak, the adaptor is not outputing the required voltage or is faulty or that the charging circuit is faulty in the motherboard.
In all these you need to check on the voltage incident on the battery terminals. So connect the adaptor an check the voltage at the battery terminals in the laptop, if absent check at the pins, if absent check on the adaptor circuit.
check this link;
http://www.fixya.com/support/r5164850-laptop_power_supply
If voltage is present then the battery is a suspect, if not the motherboard charging circuit has problems if adaptor is good and there is no charging.
Sep 17, 2011 | Acer Aspire 3623WXCi Notebook
Kindle 3G will not keep a charge. Tryed turning off the WI-FI and charging all night. Still Kindle was dead when I tried to use at lunch, advise please!
The only advice is that you need to replace the battery that you already have and get a new one. Replace the adaptor as Plan B.
If it connects to the computer does it keep the battery charging? If it does it could mean the adaptor needs replacing and not the battery. First is battery and then adaptor.
Dec 10, 2010 | Amazon Kindle 3G
I have purchased a Nextar Bluetooth Solar Charging wireless speaker from Kohls Department Store in Sussex WI I paid $99.00 serial number is VT0906005834 and it was manufctured June 2009. I bought it on Jan...
Please use the car adaptor and/or USB adaptor(Car adaptor is equipped with USB adaptor as well) to charge the unit. Car adaptor will be fast and effective as compared with USB, USB charging thru PC is slow.
Try this.
Feb 08, 2010 | Cell Phones
Ac adapter will not charge my computer
If the laptop will run from the adaptor, then the adaptor is probably fine. That being the case, if the charge light flashes when the adaptor is plugged in, the battery is faulty. No charge light on an otherwise working system is probably the battery charging circuit in the laptop.
May 17, 2009 | Dell Inspiron 1525 Laptop
Ac adaptor for psp
this i'm afraid is a problem with the psp. to charge the psp off a computer usb mode doesn't need to be entered. so it will charge automatically and if not either the battery or psp charge port are stuffed. try a borrowed battery first then if that doesn't change it trade it in to eb games and get yourself a new one
Apr 21, 2009 | Sony PlayStation Portable (PSP) Console
Ac Adaptor not working??
as u said that when u plugged in the ac adaptor into the laptop it recognises that the ac adaptor is connected but it does not charge the laptop in this case what u can do is that if have the same charger extra then u can try with the another charger and if the other charger also does the same thing then in this case u need to replace the mmotherboard and if the other charger is working fine in this laptop then definately chage ur aac adaptor.....good luck...
thanks
Jan 25, 2009 | HP Pavilion dv6000z Notebook
Battery on lap top is not charging
switch off - disconnect ac adaptor - wait 3 seconds - connect ac adaptor - repeat about 20 times.
Is charge light blinking when you connect ac adaptor?
Try reseating battery.
If battery is old (over 2 years) or heavily used then it may need replacing. They only last for 250-500 complete discharges.
Aug 08, 2008 | Evesham Computers & Internet
Cyclops CYC-S250 Thor 2.5 Million Candle Power Rechargable Halogen Spotlight (Cyclops) Logo
Top Cyclops Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Cyclops Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
