My boombox Trutech CD and Stero and Tape Boimbox .T250-B. The CD stopped playing . Please let me know if we can do some home repairing?
  • 5 Answers
SOURCE: eats tapes when i push play
tape recorder
Posted on Oct 16, 2008
  • 416 Answers
SOURCE: Dura brand Mp3 Boombox
If there is sound in radio mode, but no audio in CD mode (for any CD/MP3 disc of course) , there is a lens problem. Try to clean the lens with cleaning disk. If it wont help you need lense replacement.
Good luck
Posted on Dec 07, 2008
dunnbiker
  • 8546 Answers
SOURCE: Lenoxx compact disc player stero cassette
Does it fail on AC power, too? Motors draw a lot of current. Batteries may be weak.
Posted on Jan 18, 2011
  • 159 Answers
SOURCE: cassette tape on boombox (panasonic
Hi, I remember this problem. Your " take up spindle " isn't turning. This will be the one that also fast forwards the tape, so if the fast forward doesn't work you probably have a bad rubber band that drives it, or motor for a more sophisticated model. Also this symptom could be cause by debris that has built up on the " capstan " the little silver spike that will be close to the tape heads ( also on occasion has caused tapes to be eaten-so make sure it is clean, rubbing alcohol for this-same thing for the capstan.) I hope this was useful, write back to let me know-even if it wasn't so I may try again, thanks for asking FixYa-good luck, Prodzilla
Posted on Apr 23, 2011
intower18
  • 957 Answers
SOURCE: My Magnavox Boombox Model
If that is the case, I would highly suggest to contact a local technician so that they'll be the one to open it, because if you will try it by yourself you will end up breaking it.
Posted on Jul 16, 2011
Cd player only shows
You will need to check the swith that change from Tape to CD to other functions. If the switch is good. Then the next thing is to check for tape function. Can you try to fast forward, reverse. If these functions are working properly then the pinch roller ( the little wheel that is pulling the tape need to be replaced). If nothing moves then you need to replace the belt and the wheel and possible the motor at the same time
Nov 17, 2011 | Lenoxx Electronics CD-102 Cassette/CD...
I have memorex radio/cd/cassette player model MP3226. The PLAY button on the cassette tape does not stay in the down position when pressed when a tape is in the housing. If I remove the tape, and press...
I can imagine 2 cases for your problem:
Either there is a mechanical problem and something is not allowing the "play mechanism" to go all the way up to the clip position when the cassette is in the housing,
Or the tape isn't rolling up properly. Some of these deck's have some kind of protection and when the tape isn't rolling properly a system stops the play procedure. Check if both of the rollers for the tape are spinning around properly. In case of not spinning, run the cassette fast speed forward and backward in order to come to the proper state. Also check without any cassette is any roller spinning around or not?
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
May 15, 2011 | Memorex MP3126 Cassette/CD Boombox
How to record a cassette from cd on a sony xplod boombox cfd-g505
Insert a tape.
Select the program source you want to listen/record (CD).
Insert a cd, press stop.
Press record on the tape player.
Press play on the CD player.
The volume control or any audio emphasis buttons will not affect the record level.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CFDG505
Mar 17, 2010 | Sony CFDG505BLACK Xplod CD Radio Cassette...
Tape Deck
This unit has 2 belts that are slipping and need to be replaced. This is not the easiest repair for a novice. The belts shouldn't cost more than about $5 total. I woud recommend that you seek a shop that repairs audio gear and inquire about the repair cost.
Dan
Mar 25, 2009 | Sony CFD-G35 Cassette/CD Boombox
Eats my Cassette Tapes
Ok sound like the play head is out of a-line ment - easy way to fix if it is this - remove from the mains supply and open the cassette deck door - press the play button down and look at the play head there is 2 screws 1 either side 1 is fixed and 1 is sprung - now inset batterys (much safer) - try and fit a cassette in without using the cassette door should just fit in then press play and ajust the Right hand side scree with a small screwdriver (insulated) and ajust slightly to the left or to the right and this should fix the chewing - to get it just right use headphones ajusting left to right will tke the sound + & - to each earphone. Warning dont turn to far to the left as this will undo the screw completely - u have a least 1 whole turn either way is fine
Nov 20, 2008 | TruTech T350B Boombox
Play mode
Tape the play button down (better if you have a repeat button) I have done this and used a marble under the tape to simulate a thumb-like pressure imitation
Apr 11, 2008 | Sony CFD-S200 Cassette/CD Boombox
 Grubhead
Grubhead
