Question about Little Giant Submersible Fountain Pump
Sunterra pump How to take apart
Sunterra o ring
I would like to know that also
May 29, 2014 | Sunterra 30016 Pond Bio - Filter 1000...
Does anyone know where I can get a replacment impeller for a 2008 model Sunterra 2000 gph pump ? The cover comes off and looks replaceable. I have a warranty replacment 2009 model and the cover of it is...
If you find a replacement 2000 Impeller for your 2008 sunterra pump, let me know! I called the company who promptly told me they don't sell component parts for any of their pumps larger than 1250. They very matter-of-factly told me to go buy a new pump.
plasticmaster@msn.com
Oct 29, 2009 | Sunterra 202000 Pond Pump 2000 Gph, Black
My pump is making a loud humming noise and when I turned it on would not come on , just hummed. Tried again later and eventually came on but still making noise. Do I need a new pump. It is about 5 years...
My Sunterra pump made that noise and I had a problem getting it to come back on after unpluggin to clean pre-filter each time. It was not long after that the plastic impeller sheared in pieces (the pump was only 1 year old and thankfully under warranty) My guess is that this is fixing to happen to yours as well. You are lucky to get 5 years. There was no reason for mine to come aparts. Uunterra sent me a replacement pump which had been slightly re-designed of the same 2000 gl size and the new one jsut did the same thing (only 2 1/2 months old) I called them again which in the meantime will mean my pond going witout filtration once again. I am getting very upset about this and will be looking for a good deal on a different brand pump.
Oct 05, 2009 | Sta Rite Dyna Glass 1.5 H.P. 115/230 Pump
Where can I get a new impeller for my Sunterra pump?
Hi ive done some searching and cannot find a retail outlet for replacements parts for this pump,however i have found its original origins and makers, so visit this site and they will be able to help you
http://www.sunterrausa.com/contact-us
Jul 20, 2009 | Garden
Sunterra 300106 pond biofilter 1000 gallon intakeoutake nozzles have broken. Where in the twin cities can I go to buy new ones?
You can contact Sunterra LLC directly from their website or you can call (309)690-2460 (Ill #) or (800)800-0993 (Cal #) and they will ship you the needed parts right away. Walmart was carrying Sunterra a few years ago and may still carry ...check with them. I also noticed Target on-line had Sunterra. But as far as replacmeent parts, I would call Sunterra directly. Also www.Amazon.com carries a lot of Sunterra supplies !
Jul 11, 2009 | Sunterra 30016 Pond Bio - Filter 1000...
I am looking for replacement filtersfor Sunterra Pump #201250
Check www.amazon.com for lots of sunterra supplies
Also you can contact Sunterra LLC directly from their website or e-mail
Their # is 309-690-2460 (ILL) or 800-800-0993 (Cal.)
Jun 11, 2009 | Sunterra 30016 Pond Bio - Filter 1000...
Pump just stopped working one day. It was working fine the day before. Hums when submerged but does not pump.
It sounds like your filter is plugged, Take the filter cover off and rinse out your filter, it should take care of the problem. I clean my filter out every 2-3 days.
Apr 22, 2009 | Garden
Sunterra 2000 gph pump quit working, after cycling on and off
take the pump apart take the insides out the shaft and that's it . now take the part with all the copper wire soke it in turpintine put it back togethere the coating on the coper has a hole some were leave it in over night if your pump has circuit board remove before you put it in
Jan 26, 2009 | Garden
Pump goes on and off
Does the pump have thermall protection? It sounds like its getting hot and tripping the thermal protection switch in the pump windings.
Oct 06, 2008 | Sunterra 450gph Pond Pump
Little Giant Submersible Fountain Pump Logo
41 people viewed this question
Top Little Giant Garden Experts
Jim Goldsmith
Jim Goldsmith
Mike Squire
john h
Are you a Little Giant Garden Expert? Answer questions, earn points and help others
