Question about Whirlpool Washing Machines
WTW6800WL1 What is the warranty on this machine?
HL-L8350CDW series Unable to print 0A. How do I fix this?
"Print Unable 0A" indicates that a hardware malfunction has occurred.
- If the error message is "Print Unable ZC", refer to: "Print Unable ZC"
1. Power the machine off by holding down the power button. Wait a few seconds and then power the machine back on.
-If no error message appears on your machine's display, go to Step 2.
- If the error changed to "Self-Diagnostic" on your machine's display, contact brother for warranty service.
-If "Print Unable 0A" returns, contact brother for warranty service.
2. Leave the machine with power ON for 15 minutes.
- If "Self-Diagnostic" or "Print Unable 0A" returns, contact brother for warranty service..
WARRANTY AND SERVICE OPTIONS.
Brother Authorized Service Center locator
Jan 12, 2018 | Office Equipment & Supplies
How do i fix the Ld code on a whirlpool cabrio top load washer WTW6200SW2?
Troubleshooting Cabrio, Bravos, & Oasis Washer Problems Cabrio, Bravos, Oasis Washing Machine Overview
Washer Components
Diagnostic Mode & Tests ' Tips & Tricks Error Codes LF ' Ld ' uL ' oL ' Sd ' lid ' Po ' HC ' dL ' dU ' F1 ' F2 ' F30 ' F32 ' F40 ' F41 ' F50 ' F51 'F52 ' F53 ' F54 ' F70 ' F71 ' F72 ' F80 ' F81 ' F82 ' F83 ' F84 ' F85Always disconnect the washing machine's power supply before working on the appliance!Washing Machine Models That ApplyWhirlpool Cabrio Washing Machines
WTW6200SW0, WTW6200SW1, WTW6200SW2, WTW6200SW3, WTW6200VW0, WTW6200VW1, WTW6300SB0, WTW6300SB1, WTW6300SB2, WTW6300SG0, WTW6300SG1, WTW6300SG2, WTW6300SW0, WTW6300SW1, WTW6300SW2, WTW6300WW0, WTW6340WW0, WTW6400SW0, WTW6400SW1, WTW6400SW2, WTW6400SW3, WTW6500WW1, WTW6600SB0, WTW6600SB1, WTW6600SB2, WTW6600SB3, WTW6600SG0, WTW6600SG1, WTW6600SG2, WTW6600SG3, WTW6600SW0, WTW6600SW1, WTW6600SW2, WTW6600SW3, WTW6700TU1, WTW6700TU2, WTW6700TW0, WTW6700TW1, WTW6700TW2, WTW6800WB1, WTW6800WL1, WTW6800WW1 WTW7300XW0, WTW7340XW0, WTW7600XW0, WTW7800XW0
Maytag Bravos Washing Machines
MTW6300TQ0, MTW6300TQ1, MTW6400TQ0, MTW6500TQ0, MTW6600TB0, MTW6600TB1, MTW6600TQ0, MTW6600TQ1, MTW6700TQ0, MTW6700TQ1, MVWB300WQ0, MVWB300WQ1, MVWB400VQ0, MVWB450WQ0, MVWB450WQ1, MVWB700VQ0, MVWB750WB0, MVWB750WB1, MVWB750WL0, MVWB750WL1, MVWB750WQ0, MVWB750WQ1, MVWB750WR0, MVWB750WR1, MVWB800VB0, MVWB800VQ0, MVWB800VU0, MVWB850WB0, MVWB850WB1, MVWB850WL0, MVWB850WL1, MVWB850WQ0, MVWB850WQ1, MVWB850WR0, MVWB850WR1
Kenmore Oasis Washing Machines
110.27092603, 110.27092602, 110.27092601, 110.27092600, 110.27087605, 110.27087604, 110.27087603, 110.27087602, 110.27087601, 110.27087600, 110.27086605, 110.27086604, 110.27086603, 110.27086602, 110.27086601, 110.27082605, 110.27082604, 110.27082603, 110.27082602, 110.27082601, 110.27082600, 110.27072604, 110.27072603, 110.27072602, 110.27072601, 110.27072600, 110.27062604, 110.27062603, 110.27062602, 110.27062601, 110.27062600, 110.27052602, 110.27052600, 110.27042603, 110.27042602, 110.27042601, 110.27042600, 110.27032603, 110.27032602, 110.27032601, 110.27032600
NOTE: For All Error Codes
First press PAUSE/CANCEL once to clear the error code.
If code appears again put it through an automatic diagnostic cycle while you enjoy a nice soothing cup of tea. (Watch The Cabrio, Bravos, Oasis Diagnostics Video) This will reveal any stored error codes. Then you will be able to better use the repair guide to fix the major malfunction. Now put the tea down and get to work!
flood stop water supply hoses that may have closed internally?Is the drain hose sticking too far into your home's drain pipe (siphoning)?
Is the pressure transducer hose kinked, disconnected, or punctured?
Back to Top
Press PAUSE/CANCEL to clear display. pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests "Po" Pump Out (Lid Opened) Po flashes when the lid of the washing machine has been left open for more than 10 minutes. Close the lid to stop the drain pump.
"HC" Hot & Cold Hoses Switched This code will appear at the end of the wash cycle to indicate that the hot and cold-water inlet hoses are reversed.
"dL" Door/Lid Cannot Lock (Stored Error Codes F80, F82, F84, F85) Indicates the lid cannot lock.
Check for items caught in the lid keeping it from closing completely.
Is soap, fabric softener, or anything else keeping the lock from extending into the lid?
The control detects an open lid switch, or cannot determine if the lid is locked. Test the lid lock connection to the washer's control board and lid lock resistance levels.
Press PAUSE/CANCEL once to clear the code. "Ld" Washer is taking too long to drain water from the washtub
(Stored Error Code F32) Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
Jun 07, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
What is error 4f on a brothers fax all in one machine
This usually always turns out to be a broken printhead. If it's under warranty (one year) get to an authorized service center and Brother will cover all the costs except your time and gas. If it's just past warranty, call Brother's customer support and beg. Sometimes they issue work orders for warranty service on machines that are past their warranty.
If it's out of warranty, I'd recommend giving up on it. The parts are expensive, it's time-consuming (expensive), and you can buy a replacement machine pretty cheaply. www.BrotherMall.com lists refurbished, more advancedicon1.png machines for $90.
Dec 12, 2013 | Brother IntelliFAX-2440c Plain Paper...
Warranty for singer 7436
When/Where did you buy the machine. Most machines these days only have a 90 warranty. Janome has a bit longer... then of course there's the warranty the seller may or may not sell you.
Personally? I would toss that Singer as far as I could then let the neighbor boys shoot at it. I'm sorry they just aren't made like they used to be and Singer is not well regarded by seamers anymore. Spend your $$$$ on a Janome or Babylock.
Aug 07, 2012 | Singer 7436 - INGENUITY
It's hard disk of e-machines laptop is under warranty if it is almost 10 months age?
Hi, Yes your machine normally carrys a 1-2 year warranty from day of purchase.
Regards
Jul 23, 2011 | E-Machines Computers & Internet
Feeding foot does not work
Unfortunatly warranty doesnt apply to you. Warranty on these machine are 2 years for parts and labour. The motor's warranty is 3 years.
Jun 22, 2010 | Brother SE-270D Computerized Sewing...
Warrantee for Esante
The 25 year warranty only applies to parts that came from the factory defective: not parts that break during use. It also only covers replacement of the part, not labor to repair nor transportation of the part.
The 25 year warranty is probably the most useless warranty in existence. Some company (that shall remain nameless,) started advertising it heavily many years ago, and everyone else followed suit to compete.
Most machines have an effective 1 year parts and labor, and 5 year electronics warranty.
For a more accurate diagnosis of your machine, bring it to a warranty station. They'll be able to tell you the warranty status of your machine as well as diagnose the problem, and repair it as necessary.
-R
Aug 27, 2008 | Baby Lock Esante
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
