Question about Lux Products TX9000TS Touch Screen 7 Day Programmable Thermostat
Where does the red wire go? - Lux Products TX9000TS Touch Screen 7 Day Programmable Thermostat
  • Lux Master
  • 15,633 Answers
What are you wiring it to? Post the make and model of the HVAC
Posted on May 05, 2013
We purchased a new electric hot water heater we installed it on a 220 line and we are not getting no hot water
check with a vom set on high voltage setting. for power... black wire to black wire,, white wire to red wire on heater ground wire to tank ..on 220v there is no neutral like on 110volts..check red reset button under top panel / control push on it resets it,,,
Apr 17, 2011 | Whirlpool Water Heaters
PowerStar AE9.5 isn't working. Bought new. Water lines are hooked up to the correct water lines. The 240V wire coming from the breaker is hooked up as follows: Uncovered copper wire connected to ground,...
The unit will not owrk unless you have 240V ACROSS the black and white wires...if you do not have that coming to the unit then you have a bad breaker...
heatman101
Feb 19, 2011 | Bosch PowerStar AE9.5 AE9.5 Point-of-Use...
I replaced the heating elements(2) and switiches(2) on my Rudd electric hot water heater. Model PES 40-2. The switghes came with several wiring diagrams.(universal) Can I get a diagram specific to my...
Residential water heaters USUALLY follow same diagram unless water heater is wired for other purpose. Multiple diagrams on instructions show available options. Take photo of wiring before removing wires on any electrical device.
Upper element.
Black wire from top of heater connects to #1 top left screw.
Red wire from top connects to #3 top right screw.
Blue wire from upper element connects to #4 middle screw on right side
Red wire from lower element connects to #4 middle screw on right side
Yellow wire from upper element connects to #2 lower left screw
Black wire from lower thermostat connects to #4 lower right screw
Upper element: Yellow and Blue wires connect to either screw
Lower element: Red wire from top connects to either screw
Lower thermostat: Black wire from top connects to top screw
Short wire between lower thermostat and lower element
http://waterheatertimer.org/images/Water-heater-wiring-w-numbe.jpg
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
Sep 18, 2010 | Whirlpool Water Heaters
I need to know what wires go to each marking
com=common= [ L ](live)same, the one that kills you. =red/brown N - neutral=black/blue Earth=green or green&yellow striped old colours= red, black, & green. new colours= brown, blue & green/yellow. L,N E.......... If you are uncertain of your abilities to wire up ,ask a competent electrician .........your life is worth more than £50.00.
Mar 08, 2010 | Water Heaters
My hot water heater has a red and a black wire,but the electric supply wires coming in to power the water heater have a red,black white and a bare ground. Which wires go where?
Your 220v hot water heater does not need the neutral(white) wire coming in. Bare wire goes to ground -green headed screw. Black goes to black, Red goes to red. White gets teminated with a wirenut or some electrical tape.
Jan 24, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Installing new flomaster xp2 pump. what color wies
Are you asking about the cord from themotor to the control? If so It should either be Green Black and white or all those plus a red. The green is the ground and it goes on the green screw. White goes to the common or line(1) post, and usually red is Hi and Blk low for the speeds. If it is a single speed only no red and black will go to the other line(2).
If this does not answer your question please post a comment with what wires and where you are dealing with.
Dec 18, 2009 | Water Heaters
ON A 71-52D WHERE DO THE RED AND BLACK WIRE THAT GOES TO THE BOTTOM ELEMENT WIRE TO THE TOP?
the red are positive power + and mostaly connect to thermostad and from themostad trou the heating ellement and the black wire are the negative power - and connect to the heating ellemend and the yelow with green are grounded to the boiler
Nov 08, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I installed kenmore power miser heater not getting hot water need to know if wires are correct please
Water heater are usually 240 volt. I do not know if this is a standard water heater (tank type) or a tankless but the main wiring will be the same. Black should go to black and the the red to the white if you do not have corresponding red wires. The green is the ground and should be attached to the screw in the wiring box of the heater. If you have any other questions please contact me at kreaume@charter.net
Jul 31, 2009 | Water Heaters
Lux Products TX9000TS Touch Screen 7 Day Programmable Thermostat Logo
42 people viewed this question
Top Lux Water Heaters Experts
Gene Haynes
Bill
Level 1 Expert
Are you a Lux Water Heater Expert? Answer questions, earn points and help others
