Question about Masterbuilt Double Burner Outdoor Camping Stove/Cooker Propane
Where do i buy a A200-0 GAS REGULATOR, DOUBLE BURNER CAMPING STOVE
2 Suggested Answers
nitronuke
SOURCE: I need to replace my Brass Gas Regulator for my 2
http://www.appliancefactoryparts.com/search/part/297644/
Posted on Jul 03, 2012
Can I buy a replacement grill?
You could try Coleman, they might be able to supply one.
The Coleman Company, Inc.
3600 North Hydraulic
Wichita, KS 67219
1-800-835-3278
TDD:316-832-8707
Jul 03, 2014 | Coleman Vintage Bernzomatic Deluxe Propane...
Why wont second ring wont turn off
It should have a shut off valve on the left side. You should turn it clock wise and turn off the second burner c32cb27e-6bff-49c1-b3fe-ba672eaf151e.jpg
Jun 13, 2014 | Coleman 425e Camping Stove White Gas Duel...
Can we buy refills in the north of Italy?
most gas bottle these days with that size of stove is all the same thread. if there is a cmaping hiking store near wheere you are going. its likely. yes
Aug 22, 2013 | Kovea TKB-8712 Gas stove Outdoor Camping...
Hi I lost my regulator assembly for the camp stove model # 842-A100-W. Where can i purchase a replacement. & can you use a different one like for a coleman camp stove???
Hi bearsmommy19...
Yes you can use a generic regulator/coleman on your brinkman...just make sure the threads all match, if not, then adapters in brass can be bought at the local hardware HomeDepot,Lowes,etc.
Then you can install them to adapt your regulator to your brinkman grill
Please take time to rate me
Aug 28, 2011 | Brinkmann 842-A250-0
Clogged regulator?
Disconnect the disposable bottle and make sure the stove's gas adapter is not clogged with insect debris or something. Also make sure your bottle is not empty by trying another one just in case! Douglas
Jul 10, 2010 | Coleman Grill
Coleman propane stove problem
The connector for attaching the regulator to a disposable propane cylinder has a sintered bronze filter in the tip of the brass probe tube that is prone to clogging, or the bronze pellets get mashed down over time, restricting gas flow, and this will cause a portable grill or camp stove to perform poorly. The filter is so fine that it takes very good eyesight and bright light to see that it isn't solid metal, or use of a strong magnifying lens. The best solution is to buy a new Coleman regulator assembly. If you are unable to get a new regulator assembly and have the skills and the tools, you can try drilling a very small hole on the side of the probe tube with a #60 drill bit, just below the bronze filter, but near enough the end of the tube so that the hole will be past the plastic seal when the disposable cylinder is fully screwed into place. You should avoid drilling directly into the end of the probe tube, as the end of it is used to depress the Schrader valve in the disposable cylinder to allow gas to flow. A #60 wire gauge drill bit is only 0.040 inch (1.016 mm) in diameter, but makes a hole large enough to supply sufficient gas to a portable grill or a dual-burner camp stove. If you choose to perform this work, the probe should be unscrewed from the regulator body and the Schrader valve core in the probe tube should be removed before drilling. Be sure to clean all brass and bronze particles out of the probe tube before re-installing the Schrader valve core and the screwing the probe into the regulator. Use a removable-grade thread locking compound to secure the probe in the regulator body and don't over-tighten it, so as not to crush the rubber gasket. Allow the thread locking compound to cure for several hours before attempting to use the regulator. Keep in mind that this modification increases the likelihood of dirt getting into the needle valves and jets of your stove or grill, which can cause maintenance problems in the future.1_28_2013_4_49_27_pm.jpg
Aug 19, 2008 | Coleman Gas Grill Stove
Masterbuilt Double Burner Outdoor Camping Stove/Cooker Propane Logo
49 people viewed this question
Top Masterbuilt Grilling Experts
Paul Carew
Simon Flummox
Simon Flummox
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
