Question about Cisco 7942G IP Phone
Camera icon what is the camera icon for
Can not figure out how to switch camera to face out instead of in "selfie" mode
Start the camera app.
Somewhere on the screen should be an icon to switch to video and an icon that looks like a camera with an arrow below.
Tap the camera with the arrow icon.
Apr 04, 2015 | Tablets & eReaders
Change languege of panasonic
Turn the camera on, slide the REC/PLAYBACK selector to REC (the camera icon), turn the mode dial to the camera icon, press the MENU/SET button, press cursor-left, use cursor-up/down to select the wrench icon, press cursor-right, use cursor-up/down to select the talking head icon, press cursor-right, use cursor-up/down to select the language, then press MENU/SET.
Oct 12, 2014 | Panasonic DMC-FX35 / DMC-FX36 Digital...
How to operate camera
How to use the camera is on page 15 of the manual.
http://www.kocaso.com/manuals/M752/M752_User_Manual.pdf
Basically click on the camera icon and follow the instructions.
If the camera icon is not on the screen, transfer the camera icon by dragging it from the applications list.
Jun 08, 2014 | Kocaso M752 Dual Camera Android 4.0 ICS...
Protax
Try connecting camera to computer.
Open My Computer and see if camera shows
If camera does not show then computer is not recognizing the connection, try different port o different cord, or different computer.
If camera icon shows, then right click on icon and select Open.
Navigate to images.
Drag and drop images into a folder.
While icon is still active.
Right click icon, select properties, or select 'open-with', and rummage around to see if there are options telling XP what to do when camera is connected.
Sep 12, 2012 | Mitsuba DC500T Digital Camera
How to change japanese to english language in Lumix dmc-zx3 camera change to
Slide the REC/PLAYBACK switch to the REC position (the camera icon). Set the mode dial to the camera icon. Press the MENU/SET button. Press cursor-left. Select the wrench icon. Press cursor-right. Select the talking-head icon and press MENU/SET.
Mar 25, 2012 | Panasonic Cameras
I can't change the language on my Panasonnic DMC-TZ5
Set the REC/PLAY switch to record (the camera icon) and turn the mode dial to the camera icon. Press the button at the center of the cursor pad to bring up the menu. Select the wrench icon, then the speech-bubble icon.
Aug 21, 2011 | Panasonic DMC-TZ5 Digital Camera
How will i change my camera (panasonic lumix dmc-fx37) languge from japanese to english
Slide the [REC]/[PLAYBACK] selector to the recording mode (camera icon). Set the mode dial to the camera icon. Press [MENU/SET] to display the menu. Press cursor-left, use cursor-up/down to select the wrench icon, then press cursor-right. Select the head-with-speech-bubble icon.
Apr 30, 2011 | Panasonic DMC-FX37 Digital Camera
Camera fails to flash every time we take a picture
1.Turn off the camera.
2.Install a set of new or fully charged batteries into the camera. then turn it ON
3.Press the Flash Status button to scroll through the flash options until Fill Flash (the lightning bolt icon alone, with no other letter or symbol) is displayed. This forces the camera to use the flash. a86196b.jpg
4.Take a picture. [If flash still doesn't work contact Kodak support line 1 800 235 6325 (23KODAK)]
Nov 16, 2009 | Kodak EasyShare C875 Digital Camera
Resolution
To set the resolution just Press the MENU icon (middle icon) on the left side of the LCD screen. Then press the QUALITY icon (lower row left icon). Choose from one of the four icons.
Sep 11, 2005 | Toshiba Sora PDR-T30 Digital Camera
Icon that looks like a hand with lines around it
This icon represents Movie Mode Camera Shake Correction In Movie mode, digital camera shake correction can be applied to reduce image unsteadiness and camera shake.
Sep 01, 2005 | Olympus i:robe IR-500 Digital Camera
Cisco 7942G IP Phone Logo
44 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
