Question about Garden
Toro lx425 belt diagram
Replace drive and clutch belts
  • 666 Answers
SOURCE: john deere model 14sb lawn mower repair
Check for bad bearing in clutch immediately, Remove belt, try and turn the clutch pulley if it is hard to turn or feels rough, replace the bearing in the clutch. If you do not replace bearing immediately you will be buying a $300.00 clutch very soon. I know from experience. You possibly have been hearing a loud unusual roar from engine area for awhile and wondered where it was coming from. As these bearing will usually squall a cry for awhile before they die.
Posted on Mar 28, 2009
  • 8 Answers
SOURCE: Cub Cadet 1610 Drive Belt Diagram
Go to Cub Cadet. com and click parts. Type your model number 1610. You will see parts diagram. Click that. It will show a long list of parts to click on. Choose drive and it will show you a diagram of all the pulleys and how the belt looks. Hope this helps. I had the same problem.
Posted on May 04, 2009
SOURCE: I need a toro z4200 drive belt diagram as my belt
I have the same problem and juts figer that out and put back on but still not working,
Posted on May 02, 2010
SOURCE: diagram on how to replace belt on deck 48
This is an older model, but the routing might be similar.
Posted on May 07, 2010
  • 10865 Answers
SOURCE: i have a cub cadet lt 1050 need diagram for drive
Hi. All of these questions are answered in the owner manual. TO download one go to this link http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10051&langId=-1
J.
Posted on Aug 03, 2010
Replac drive belt 20068 personal pace with blade clutch
One belt runs your clutch the other runs your drive. there is a very small but thick belt which runs the clutch. longer belt for drive system
Jul 28, 2014 | Toro Garden
How do i replace a drive belt for the toro lx425 lawn tractor?
Jump onto www.toro.com and download the free service manual for your machine. Note down all the details on the ID plate on the mower, you will need it to find the correct manual......
Oct 10, 2010 | Toro Garden
Lx425 has grinding noise but won
replace the starter gear. the starter is probably fine and alot cheaper if you just relplace the gears.
Jul 14, 2010 | Toro Garden
Front wheels quit pulling
Ya most likely the lever that you normally squeeze to make it "go" has a cable. Cables stretch just like belts. If you replaced the belt already then that automatically removes any stretching that the first belt would have suffered from no doubt. Look at the drive lever's cable up at the lever end. There is usually a cable adjuster there. It will be a threaded shaft portion with a nut or knurled ring to spin. tighten up that "go lever" cable a bit. Even better, if you have visual access to the belt as you squeeze the drive lever, then you can see if squeezing that lever moves one of the belt's pulleys enough to cause it to tighten it up enough to transfer spin motion thru the belt to the other pulley. You see that whole system is really a "slip belt clutch" when belt is loose, no forward motion, as you squeeze the "go/drive" lever the pulley moves away tightening up the belt more and more. The tighter the belt, the less the slippage, the faster you go! But the slippage is necessary! ( That's the clutch component) If you simply had the belt tight all the time, the mower would always go full speed! It would be in full time "run away mode" LOL! so watch out. Once you see it in action...you'll get the idea no problem!
May 10, 2010 | Toro Lawn Mower With Toro Power Tools
How do I get instructions on replacing both upper and lower drive belts on a LX425 Toro Lawn Tractor?
You can go to Toro.com and look at the lower left side for "Homeowner" or "commercial" parts. If you enter your model number you can get an owners manual online. I tried your LX425, but didn't come up. Maybe a different number?
Oct 25, 2009 | Garden
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
