Question about Dometic 3313107.107 Adapter Kit
Dometic dip switch zone 2
Which way is on for the dip switch
    Top Expert:
  • Dometic Master
  • 5,061 Answers
Look on schematic on cover should be to the right
Posted on Sep 11, 2017
Why is my Dometic thermostat not changing from Zone to Zone
make sure dip switches ok and hold down zones and mode till it recognizes
Nov 12, 2015 | Dometic Heating & Cooling
Why does a CCC2 thermostat continually kick on and off even though the set temperature has been reached?
Double check your batteries in both the outside and inside units changing the outside ones FIRST before you change to reset the inside batteries, IF you have two separate units. If this doesn't help, it could be the control switch/relay for your interior unit. Please go to your browsers information line and type in DOMETIC CORPORATION.COM AND SEARCH FOR YOUR SPECIFIC THERMOSTAT by entering your CCC2 Comfort Control Center 2 information. They should have a help section at this website.
I hope this helps. Check to see if its still under warranty.
Jul 07, 2014 | DOMETIC CORPORATION Dometic CCC2 Comfort...
My 2 zone ac/furnace/heat pump system is not showing zone 2 at all. where should I start to look for a problem?
I assume you are seeing this at the zone board at the unit?
How many zones can a 20-40 ft RV have? seems silly
is 1/2 the coach not getting any thing?
post the model and serial number.
Sep 22, 2013 | Dometic Rooftop RV Air Conditioner
I have a 2003 HR Endeavor with 2 roof ubits. The front unit will cool and heat but the rear unit will not come on. The thermostat will not cycle to zone 2. Any suggestions?
Try resetting the thermostat. If you have the 5 button comfort control, turn the thermostat off. While holding down the mode and zone buttons, turn the tstat back on and hold the buttons until FF appears in the display. Release the buttons and then see if zone 2 is available. If not, remove the inner cover off the front air and remove the cover off the control box. Inside this box there are DIP switches (red stripe with white switches). Set the one for zone 2 to off and then reset the tstat as described above. Turn zone 2 back on and once again reset. If this does not work, you more than likely have a bad control board in the front unit as this is the one that controls all that.
Hope this helps,
Jeff
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
I have a duotherm double unit A/C setup on a 2003 Triple E Commander - I reset the thermostat by pressing the top and bottom buttons on start up - "FF" code shows up, but now it doesn't recognize Zone 2...
In the main unit, remove the inner shroud and then pull down the control unit (two phillips screws). Remove the access cover on the control box to view the dip switches. The switches should be set to Zone 1 and Zone 2 to on and then the furnace to on (if so equipped). If the zones are not in the in position, then set them to the correct position and reset the thermostat again. If they are correct, try turning them off, resetting the thermostat and then turning them back on and resetting again. If this does not work, then you have a bad thermostat or control box.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
Comfort control center not working properly
You need to check the cable that connects the Comfort Control to the upper unit. This cable has four wires and should have continuity through all wires. If there is a break in one of the wires or a short, it will cause the CCC to fail and report an error. If all this is fine, then you have a bad control unit in the main unit. Try unplugging the rear unit from the control board and then resetting the Tstat, if this works, then there is a communication problem between the front AC control board and the rear AC control board or the rear control board is bad. Check the cable between the front and rear AC for OK. If it is alright, then you have a bad control unit in the front unit.
Another quick check is to remove the inner shroud from the front unit pull down the control box. Remove the access cover and view the dip switch panel located inside. It should be labeled Zone 1 Zone 2 etc...try turning off Zone 2 and furnace and resetting the tstat. If this works then turn zone 2 on and reset the tstat. If this is ok, then turn the furnace on and reset again. If this works, then all should be ok. If one of these fails, then you can pinpoint the problem there and move forward.
Hope this helps,
Jeff
Rate me please!!!
Jul 04, 2009 | Dometic Rooftop RV Air Conditioner
Thermostat shows error on unused zone
You will need to take the inside cover down on the front air conditioner. There is a control box mounted there, open the control box and you should see many dip switches on the face of the board. Make sure that Zone 1 and Zone 2 are selected (furnace as well if your furnace is fed through this thermostat). After making sure that the switches are set, turn off the thermostat and hold down the mode and zone buttons at the same time, turn the tstat back on. When EE appears on the face, release the buttons and see if everything works. If not, then I would say that you have a bad control unit in the air conditioner.
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
Error code of E4 on Dometic HP air conditioner ??
16. SYSTEM RESET
a. Turn the ON/OFF switch to “OFF” position.
b. Simultaneously depress and hold the MODE and ZONE
push-buttons while turning the ON/OFF switch to “ON”.
FF should appear in the LCD display until the MODE
and ZONE push-buttons are released.
c. When a dip switch is turned on or off after initial configu
ration, a system reset will need to be done before the
Comfort Control CenterTM will recognize the updated selection. Try this. This is for the five button thermostat. Did you check the dip switches to be sure the proper ones are turned on? I need to know which stat you have 4 or 5 button. I have trouble shooting for both.
If you notice reset needs to take place after a dip switch is turned on or off. The dip switches are on the circuit board. You need to drop the lower cover. the dip switches will read in this order #1 heat strip/ #2 zone2/#3zone3/ #4 zone4/#5 furnace/#6 differential/#7stag/#8 gen start. Check this out and be careful. Turn off the stat to change dip switches. On will be toward the description. If you don't have remote start gen set the dip should not be on. If you dont have a Zone 3 the dip should not be on, etc.
Any questions feel free to post back
Thank you for using fixya
Jerry
Mar 25, 2009 | Dometic Rooftop RV Air Conditioner
I get F4 (Freeze control failure) on my Dometic Penguin A/C
This is from the service manual:
16. SYSTEM RESET
a. Turn the ON/OFF switch to .OFF. position.
push-buttons while turning the ON/OFF switch to .ON..
Hope this helps
Feb 28, 2009 | Dometic Rooftop RV Air Conditioner
Dometic 3313107.107 Adapter Kit Logo
53 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
