Question about Sharp Mx-2300n Copier Color Mx2300n Printer Scanner
Sharp mx2300n tray 3
My computer won't let me print to tray 3.. I can print to the other trays and scan and email to my computer, I just cant access tray 3. how do i fix this?
    Guru:
  • Sharp Expert
  • 106 Answers
Sounds like you need to configure your print driver with the options that your machine has on it.
Check out my instructions on how to do this!
How To Configure Sharp Print Drivers with Installed Options to print...
Posted on Jul 28, 2014
How do i print on cardboard (heavy paper card)
The mx2300n only supports up to 209gsm heavy card. You must make sure that your heavy card is not over this rating.
Set the bypass tray as 'Heavy' by clicking on the trays on the main copy mode screen, select type & size for bypass. Select heavy, and Auto AB as this will allow the tray guides to detect the size of your paper. Load the tray with up to 20 sheets of Heavy paper.
Open your document, select Print, then properties. Under the 'paper' tab, select paper source as bypass tray, and paper type as heavy (if you miss one of these steps, the ,machine will ask to load paper due to size or type mismatch).
That's pretty much it.
Oct 16, 2013 | Sharp MX-2300N Color Copier
Sharp MX-2610N printer can't set-up the print job (for labels from by pass tray) from my desktop computer.
Some documents like word override the settings... you need to change/save within your document you are printing. page layout and then page set up
Sep 16, 2012 | Sharp MX-2300N Color Copier
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
Mx2300n try to print envelope from bypass tray but error says
Try putting the paper in the 2nd paper tray and then go to system settings then paper tray settings and change to paper for that drawer to envelope and maybe COM10. Then try to print on the envelopes.
Dec 11, 2011 | Sharp MX-2300N Color Copier
How do i print 6 3/4 return size envelopes on a sharp 2600n
You have to select the Manual Feed Tray by touching the picture of the copy machine on the LCD screen. That will then show you the paper trays. Touch the paper type soft key for the Bypass/Manual Feed Tray and then select envelope. then press ok a couple of times till you are back to the main screen. Put your envelopes face down on the Bypass/Manual Feed Tray. If you are printing from a computer do the same thing after you go to printing preference/properties.
Oct 20, 2011 | Sharp MX-2300N Color Copier
I just installed driver for my mac to mx2300n printer. When I print a page from my computer the printer heats up and acts like it is going to print, but never picks up a page from the tray and never prints...
For a Mac to print to the Sharp MX-2300N the Postscript Kit (MX-PKX1) has to be installed on the copier. If that is not installed you will not get any mac to print to it.
Sep 05, 2011 | Sharp MX-2300N Color Copier
On the mx2300n the center tray (output tray) has a little "doohickey" that is attached, but on mine fell off---I just want to attached it in the right place.
Most likely the stack height sensor flag. Unless you're running hundreds at a time, it's not needed.
It's hard to attach in the proper position with the exit unit in the machine.
Mar 06, 2011 | Sharp MX-2300N Color Copier
Sharp arm 450n (ce-02)
1) If you're actually scanning to an email address, make sure your SMTP email server information in the copier's web page is correct.
If you are using names instead of IP addresses, also make sure your DNS server IP's are correct.
2) If you're scanning to create the fake email set up by Sharp Network Scanner tool, the connection info in your copier is old and needs to be refreshed.
From the computer you're trying to scan to, right click on the Network Scanner Tool icon in the tray, go to Automatic Profile Update, and select Update Now. If you have no tray icon, reboot your computer.
If your copier is set up to store names instead of IP addresses, make sure your DNS information is correct in the web page.
Jun 30, 2009 | Sharp Office Equipment & Supplies
I can't use Print function for ByPass or Document Feeder?
The document feeder is used for copying and scanning ,it is a unit in a copier where you can placed your documents or originals for copying and scanning. The bypass tray is used for copying and printing, the bypass tray is used for types of paper like plain paper, acetates etc and customized papers. If you want to used the bypass tray for printing you should go to printer properties or configuration and select the tray you want to used like bypass tray .
Feb 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp Mx-2300n Copier Color Mx2300n Printer Scanner Logo
99 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
