Question about GE Refrigerators
My GE Profile Refrigerator is leaking at the right hand corner looking at the refrigerator.
My GE Profile Refrigerator, Model # PSCS5RGXCFSS, is leaking from the right hand corner facing the refrigerator. The water is coming from the small reservoir at the back of the second drawer from the bottom. The reservoir is full of water. Help.
aborcass
  • 2651 Answers
SOURCE: Water freezing at bottom of refrigerator/Temperature not right
thats a water tank holding water dfor the dispensor, if everything in refrig is freezing quite possible that the water in tank froze as well, which would explain no water,
Posted on Feb 24, 2008
SOURCE: GE Profile Refrigerator - Small Leak & Loud Noise
Does water come out of the water dispenser?
I is more likely that the tube that drains the water down from the self defrost mechanism is clogged. Look in the very back of the reefer cabinet, you will see a trough back there, if it is full of ice and water the drain tube is clogged up. If so, a little blast of air from a can of air (like the ones you use to blow off computer key boards will blow it out. Then the water can drain down to the evaporator pan and you will no longer get water on the floor.
Posted on Nov 10, 2008
  • 219 Answers
SOURCE: ge profile water/ice fridge side under bottom drawer
take out the back panel in frzzer side use a steamer to clean out your drain hole
Posted on Mar 19, 2009
Sea Breeze
  • 4655 Answers
SOURCE: water leak under GE Profile refridgerator when using door water
The water dispenser problem may be due to a defective water control valve. But when the refrigerator leaks this needs to be solved. I have a lot of different ways and reasons listed so click on the below link and read over this and use the part that applies to your refrigerators leaking problem. You also can contact me here or by email should I not get any messages here from you. Hope this helps and we will work on the dispenser problem next, Thanks, Sea Breeze
appliancepartsse@yahoo.com
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Posted on Aug 17, 2009
SOURCE: GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Posted on Jun 03, 2010
How to replace ge rpwfe filter
I think on that model there is a long plastic cover on the top right hand corner with a tab in the front. Push tab and cover should hinge down to uncover the filter. Unscrew filter to left and pull forward. Reverse to install new filter.
Feb 25, 2015 | GE Profile PDS22MHR Bottom Freezer...
GE Profile side by side TPH21PR refrigerator leaks water on the floor at left front corner weekly but not daily. It there a fix or should we purchase a new refrigerator.
it sound like the drain pan and the drain line need cleaned or maybe the drain tube got knocked out of the pan, take a light and look and see what you find down there and let me know.
Feb 21, 2011 | GE Profile PSW26P Stainless Steel Side by...
My ge profile refrigerator won't keep it's temperature setting?
G.E. has had problems with the main computer board located on the back outside wall of the machine,you need to give the parts store or whoever you get the board from the full model number to get the correct board.i looked up the machine with the number you sent but there are 2 different boards that they show so open the fridge door,look up near the ceiling on the right hand wall and you'll see the model and serial number,all you need is the full model number or you can send it to me and i can look it up for you.good luck
Jan 13, 2011 | GE Profile PSW26P Stainless Steel Side by...
A GE Profile Model, double door refrigerator with a water leak
If the leak is on the refrig water valve where the wall water line connects to , then use a 1/2" wrench and tighten the fitting on the water valve itself . If the leak is on the plastic tubing at the bottom of the refrig water valve , pull up on the small white ring while pushing down on the plastic tube to remove it from the valve . Cut off about 1 " of the tubing and reinsert it into the valve with pretty good pressure to be sure it is inserted completely .
Mar 27, 2010 | GE Refrigerators
Water from dispenser comes out very slowly and takes too long to fill up a glass
The PSW26P comes with a water filter in rear right hand top corner of the fresh food section. Some have a digital diplay for changing filter. Most times that is what begins (water flow restriction) as the filter expires its usefulness. If you have recently changed the filter then we need to have a look at the water control valve on the rear of refrigerator. Look around the door and confirm that model number. I seem to only find numbers like this=> PSW26SGPASS I will return with a link to a photo, Thanks, Sea Breeze
Feb 16, 2010 | GE Profile PSW26P Stainless Steel Side by...
Nov 06, 2008 | GE Profile PSW26P Stainless Steel Side by...
Location of GE refrigerator circuit board
The main board is located behind the unit at the lower right hand corner behind a panel that's about 8" X 12".
Oct 29, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Leaky Refrigerator
remove the whole back cover at the bottom and check all the nylon lines. they get britle and crack from the heat that the compresor and condesor make. chack that and get back to me. I may be able to send a parts break down / explosion if I can get the model number.
Cheers,
Todd
Oct 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
117 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
