Question about CVS/Pharmacy CVS Digital Ear Thermometer
Cvs digital thermometer
Error reading
My blood pressure machine keeps giving me an error 3 it is a cvs brand
Several of the CVS brand blood pressure monitors are made by MicroLife USA. For those models, the Error 3 indicates that you may have been moving your arm while the unit was obtaining the readings. You need to repeat the measurement while staying still.
The other possible cause of the error are that the cuff didn't inflate in a reasonable length of time. Check that the cuff is properly placed on your arm. Also make sure that the inflation hose is tightly connected to the cuff socket on the unit.
I hope this helps.
Aug 14, 2014 | Health & Beauty
Oven thermometer only displays lo
I just had that LO reading. Pulled back on the tip of the thermometer. Seems I had it inserted into my turkey too far. Probably up against a bone or too close to the center. Good luck! Happy Thanksgiving 2016!
Dec 25, 2013 | Farberware New Classic Alert Oven Probe...
Sick dog
How to take Dogs temperature?
Required Things:
• Digital pet thermometer
• Lubrication, such as petroleum jelly or mineral oil
• Soap and water
• Rubbing alcohol
For a breeder it is mandatory to know why their pet not feeling well? Why he/she has lack of appetite, restless, and not involved in daily activities. These are signs and symptoms suggested that their pet is ill. Fever can be in these illnesses. It requires special attention. A dog is not express like human when it gets fever, and has not signs (e.g. warm skin, and trembling). For these reasons it is important to know and learn how to take temperatures reading of fever as a vet can do it. It can be done very impressively to follow the following steps:
First of all you should have a Digital pet thermometer; it can be bought by local market.
For your help call somebody who hold the dog when you take the readings.
Do clean your Digital pet thermometer with prescribed rubbing alcohol.
Before taking a temperature apply lubricant (i.e. petroleum jelly or mineral oil).
Pick dog\'s tail upward and insert thermometer gently into your dog\'s rectum. Put it into half of the length of the thermometer.
Grasp the thermometer in that position until it beeps, or for 1 to 2 minutes.
Pull it out and look at it to see what your dog\'s temperature is.
The normal body temperature should between 100.5 to 102.5 degrees Fahrenheit
Clean the thermometer thoroughly with semi-hot water and prescribed soap
Ask your vet if temperature is low or high with sign of sickness.
During the learning process (dog\'s temperature measurement process), be relaxed and don\'t show nervousness to your canine. This will add to the pet\'s irritation.
Be very conscious during all the process of taking temperature, don\'t insert thermometer into deep of dog\'s rectum, it can be a cause of pain.
Tie a cord around the other end of the thermometer so that if it slips or accidentally go into your dog\'s rectum too deeply, you will be able to easily pull it back.
Remember a digital pet thermometer is best than an oral human thermometer to measure dog\'s temperature. Conventional sort (contains mercury) can be very dangerous if accidentally broken.
Always prefer rectal digital thermometer to take a temperature reading of pet.
Ear thermometer is also available in market but it is not as accurate as rectal thermometer is.
Never strive to take your canine\'s temperature if he/she is very irritated or very hyper. If you do so, it could be dangerous for pet. Be patience until dog calms down when he/she calm down then attempt to insert the thermometer.
Without lubrication insertion may be dangerous action it can cause the pain.
Self medication is prohibited if the temperature of pet is very low/high.
Do not get anger with your canine if he/she will not get calm enough to permit you to insert the thermometer. Take him/her to your vet if you are not capable to take your dog\'s temperature.
FOR MORE READING ABOUT A SICK DOG SIGN AND SYMPTOMS PLEASE VISIT
http://www.dogbreedplus.com/dog_care/how_to_take_dogs_temperature.htm
FOR other information visit.....
Jan 11, 2013 | Dogs
How to calibrate Ryobi digital thermometer?
Wrong. You need black body to check accuracy of IR thermometers (unlikely that you will have one). Accuracy bellow 50F is +/-3F and other ranges is +/- 1.5% of the reading.
Read the manual: http://www.ryobitools.com/product_manual/file_url/478/RP4030_656_trilingual.pdf
Jan 04, 2013 | Ryobi Tek4 Professional 4-Volt Infrared...
The digital thermometer was flashing "lo". I assumed it needed new batteries and then replaced them. It is still flashing lo, but also showing a C reading. What do I need to do to reset it?
there should be a setting on it that changes the temp from Celsius or "c" to ferinheight and lo means that it currently isn't reading a temperature in the normal range. try running it under hot water and see if it says error or high.
Jul 15, 2011 | Prestige Medical Infrared Ear Thermometer
I need a instrution manual for a ear themoniter model no ET1200
Hi.
  • 1 Consider that most digital thermometers take a temperature in less than 30 seconds, quickening the temperature-taking process for squirmy children.
  • 2 Read the thermometer's instructions carefully. Never throw the instructions away. Keep them near your digital thermometer.
  • 3 Wipe the thermometer probe with a soapy washcloth or a tissue dabbed in isopropyl alcohol or put on a clean probe, depending on your brand of thermometer.
  • 4 Turn the thermometer on.
  • 5 Use a gentle rocking motion as you insert the thermometer into the ear canal or rectum. Never push or cram the probe into the body. Forcing it causes pain, especially if there is swelling in the ear canal or rectum.
  • 6 Listen for the beep.
  • 7 Remove the thermometer.
  • 8 Read the thermometer. If you see "ERR," you did not get good contact with the ear canal or rectum, and will need to take the temperature again.
  • 9 Use the chart insert that comes with your thermometer to see what your normal reading should be.
  • 10 Clean your thermometer probe with a soapy washcloth and/or isopropyl alcohol before storing.
  • Aug 26, 2010 | Health & Beauty
    I have a Sunbeam digital meat probe thermometer used once. Now the display for thermo/temp comes up H instead of the temperature of the meat. What is wrong? Sunbeam digital meat probe thermometer has quit...
    I left mine in a hot tub for well over an hour. It started reading room temp at about 125 degrees. It worked for me to put the thermometer in the freezer until the readings were correct. hope this works for you.
    Feb 22, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
    CVS/Pharmacy CVS Digital Ear Thermometer Logo
    78 people viewed this question
    Top CVS/Pharmacy Home Experts
    john h
    Tom Chichester
    Are you a CVS/Pharmacy Home Expert? Answer questions, earn points and help others
