FAGOR GEYSER PARTS
FAGOR 10004274 Model : PG-102-1 Input : DC 1.5V OUTPUT : MIN 12KV SERIAL NO P 112652 PTC
2 Suggested Answers
  • 12 Answers
SOURCE: power supply/ no output voltage
Actually i haven't fixed the problem as yet but i did find some info that would help me to fix problem.
I went to google and entered keyword,,, Electronic parts,,there came up a page,,and i went to several manuf sites till i found a replacement transformer,,then i disassembled the power supply and am now waiting for a replacement transformer.
Posted on Sep 22, 2008
Where is the amp and how do i check it in 98 cadillac
Radio Amplifier
Left hand rear of the passenger compartment, behind the rear seat back.
Check the connections , check power an ground .
Connector Part Information
12110088
24 Way F Micro-Pack 100 Series (GRY)
Pin
Wire Color
Circuit No.
Function
A1
PPL
1952
RH Front Tweeter Output -
A2
LT GRN
1852
RH Front Tweeter Output +
A3
BLK
1856
LH Front Tweeter Output +
A4
YEL
1956
LH Front Tweeter Output -
A5
DK BLU/WHT
346
Rear Shelf Subwoofer Coil 1 Output +
A6
LT GRN/BLK
1794
Rear Shelf Subwoofer Coil 1 Output -
A7
YEL
1860
Center I/P Midrange Output +
A8
LT BLU
1960
Center I/P Midrange Output -
A9
DK GRN
1795
Rear Shelf Subwoofer Coil 2 Output +
A10
LT BLU/BLK
315
Rear Shelf Subwoofer Coil 2 Output -
A11-A12
Not Used
B1
DK GRN/WHT
368
Right CD Changer Input
B2
BLK/WHT
372
CD Changer Common
B3
BRN/WHT
367
Left CD Changer Input
B4
LT GRN
1948
Right Audio Input -
B5
LT GRN/BLK
512
Right Audio Input +
B6
DK GRN
1947
Left Audio Input -
B7
TAN
511
Left Audio Input +
B8
DK BLU/WHT
653
Chime Input/Return
B9
PPL/WHT
652
Chime Input +
B10
Not Used
B11
PPL
1807
Class 2 Serial Data Line
B12
PPL
1807
Radio Amplifier (UX8) C3
showgif.do?image=35456
12064749
2 Way F Metri-Pack 480 Series (BLK)
Pin
Wire Color
Circuit No.
Function
A
BLK/WHT
651
Ground
B
RED
1242
Battery Positive Voltage (B+)
Check
Mar 22, 2016 | 1998 Cadillac Seville
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
What is the power output of ac dc adapter in jensen jta 460? Can this adaptor be changed with 220volt ac dc adapter with required dc output?
For Any Adapter:
As long as the Voltage and Power output of the power supply (wall outlet or other) matches the input requirements for the adapter whether 110V or 220V.at enough amp output; and
IFF the dc output of the adapter is exactly the same voltage and has for amps at a minimum matches the maximum amperage requirement for the input of the device, any of them will work, as long as it has the right connector with the correct polarity needed for the device!
Or, in other words...
Supply Output V = Adapter Input V
and
Adapter Output V = Device V
Adapter Output A(min) >= Device A(max)
Aug 27, 2015 | Computers & Internet
How do you repair a ac switch on your fujitso siemens amilo pro v 2010
The AC switch you mention is a PSU (power supply unit).
You can by them complete on Ebay.
Part number ACADA-C7
AC input voltage 100 ~ 240V 50~ 60Hz DC output voltage 20V DC output current 3.25A Power 65W Connector size 5.5 x 2.5mm
Sep 30, 2014 | Computers & Internet
I need a user's manual for Voltcraft Fast Charge Delta Peak model MW3610HC. I believe it is a battery pack charger. It is a Europian product that requires a U.S. AC adapter. I want to know what size...
SPECYFIKACJA :
  • V detection
  • Cigarette lighter plug
  • Double output
  • Discharge function
  • Dla Ni-Cd/ Ni-MH battery
  • Input voltage: 230V AC, 50Hz, 13.8V do 24V DC
  • Output :
  • Dla 230V AC or 24V DC input: 5.6V DC (4 celle) do 11.2V DC (8 cell)
    • Dla 24V AC input: 5.6V DC (4 celle) do 8.4V DC (6 cell)
  • Output regulowany : 1,000/2,000/3,000mA
Sep 04, 2011 | Vacuums
3-phase recty fier not output voltage 230V 10V
What is the type (input, output, power) of the rectifier.
If controllable - may be the control PCB or thyristor.
If not controllable - 10 V DC instead of 230 V DC is hardly believable.
In this case the rectifier may be OK, but the input - low.
If you have a voltmeter, check the input AC and the output DC if the output has about 200 V AC you may have shortened diode.
Jul 02, 2010 | Electric Measuring Tools & Sensors
I need a new ac/dc adaptor for my pdv 709 ac100-240v 50/60hz 0.5a output dc 9v 2a efficiency level 1v factory id a
If you have the original adapter simply purchase a generic adapter with the same connection type, amp/current and voltage. Otherwise it will show on the products sticker, normally with the model and serial number, what input the ac/dc adapter uses. Im assuming from the information given you need to purchase a 9 volt adapter with an amp or current rating of 500mA or 0.5 amps. I hope this helps. Good luck.
Dec 03, 2009 | Durabrand PDV-709
How many volts does a HP Pavillion TX1410 adaptor has?
Please look carefully at the unit, the ratings are on the outside of it.
Oct 21, 2009 | HP Pavillion ZV6000 Notebook
DELL OptiPlex GX280?®??»????¦??????????????¢???¦???¾?????
TAKE THE OLD ONE OUT OF THE MACHINE, UNPLUG ALL CONNECTOR AND LABEL THEM EACH. TAKE IT TO ANY COMPUTER STORE THEY SHOULD BE ABLE TO HELP YOU
IT IS 4 SCREWS PHILLIPS TYPE, POWER SWITCH
BUT THE MIN. POWER SUPPLY SHOULD BE AT LEAST 250WATTS
AND HIGHER IF YOU ARE GAMER, GRAPHICS NUT, ALOT OFF
EXTRA GEAR,
CANDYMANGANDY
Jan 23, 2009 | Computers & Internet
Power supply/ no output voltage
Sep 21, 2008 | Boston Acoustics MicroMedia Computer...
 Grubhead
Grubhead
