Zip hydrotap we have suffered power cuts and now our Hydro Tap is not working and giving error message of a water leak have you any idea,s how to reset its brain?
  • 105 Answers
SOURCE: error message: water tap closed .
check water inlet valve clean of rubbish from water inlet hose
otherwise water inlet valve maybe faulty
Posted on Jan 02, 2008
SOURCE: Water filter system leaks at tap
The line from the faucet to the drain was plugged. I cleared the line and the system is working well.
Posted on Apr 15, 2009
  • 380 Answers
SOURCE: Samsung washing machine gives Low Water pressure
You get these messages turned off by fixing the problem.
Low water pressure is basically one of the valves is not letting water pass through.
1. Do as you already did and clean the inlet filters. Any kinked hoses?
2. Adjust the water pressure in the house. Is it too high or too low?
3. Replace the valves in the unit.
4. Main board.
Posted on Dec 30, 2009
  • 33 Answers
SOURCE: Treadmill cuts out after 10 seconds and gives an E1 message.
Your problem might be that a magnet has fallen out of place. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
BElectric
  • 1140 Answers
SOURCE: I have a Delonghi dishwasher,
The E4 error message could be because the water pressure is too low rather than too high. Can you let me know the exact model number of your dishwasher and I should be able to tell you more.
Regards,
BElectric
Posted on Dec 06, 2010
Unable to get wi-fi to kick in and hold for a call. although it works just fine in store.
Troubleshoot issues related to data connectivity and your ...
support.sprint.com/...Kyocera.../WTroubleshootingGu...
Sprint CorporationThis article helps you troubleshoot data connectivity issues on your Kyocera Rise. You may have data connectivity issues if you're unable to: ... Some features and applications require a data connection to work properly. ... Note: Most Wi-Fi networkshave a range of less than 100 feet indoors and up to 300 feet ... Contact us ...
Troubleshoot issues related to your Kyocera Hydro Edge ...
support.sprint.com/...Kyocera.../WTrendTroubleshoot...
Sprint CorporationThis article helps troubleshoot your Kyocera Hydro Edge slowing, freezing, ... You mayhave performance issues if your device: ... back on; Displays error messages; Isunable to install or update applications ... Press and hold the Power key, tap Power off, and then tap OK to turn your Kyocera Hydro Edge™ off. ... Contact us ...
Brigadier by Kyocera Support ' Verizon Wireless
www.verizonwireless.com/support/brigadier/
Verizon Wireless
Dec 13, 2015 | Kyocera Cell Phones
How do I get my text messages transfered to my laptop so I can print them off? I have a kyocera hudro
. Download BackupTrans Software's "Android SMS + MMS Transfer" software .It help us extracts SMS and MMS messages from any Android device and stores them on the PC.
2. Connect your Kyocera Hydro to your PC via mini USB cable. "Android SMS + MMS Transfer" will scan your drive and create a list that it can sync to your computer.
3. Click on "Kyocera Hydro" under the list of devices in the left-hand panel of the software.
Select the messages from the list, click "File" -"Print SMS and MMS." Select your printer and then click "Print."
App Option
4. Press the "Home" button on the Kyocera Hydro.Tap the "Google Play" icon to open the application market. Search for "PrinterShare Mobile Print." Tap "Install" to download and install the software.
5. Both the printer and the phone need to be on the same wireless network.Tap the app to searches the network for the printer.
6. Tap "Messages" to open your SMS and MMS messages in PrinterShare. Select the wireless printer.
Manual Method
7. Click on the messages and then tap"Copy message text".
8. Return to your Home screen and then open the email app.Compose a new message to yourself and paste the messages you want to print.Tap"Send".
9. Open the email on any computer connected to a printer and then click "File," and choose "Print".
10. Then you have successfully print your message from Kyocera Hydro.
Aug 12, 2014 | Boost Mobile Kyocera Hydro Smartphone
Kenwood KDW45X13 E1 error message
Poor water supply, check the supply hose is not kinked. Check the supply tap is fully on. Check the debris filter in the hose to machine connection is clean.
Jan 26, 2014 | Kenwood Dishwashers
Power cut when printer was shutting down
Unfortunately it's entirely possible the printer has suffered a power surge as a result of the power cut so you could have one or all of the following issues:
1. The printer mainboard may have suffered damage in which case it's game over.
2. One or more of the cartridge chips may have been "fried"... You could try removing all the cartridges, turning the printer off and then on again to see if the printer alters the message to indicate that cartridges are missing. If that works it's unlikely that 1 applies...
If the printer recognises the cartridges are missing, try inserting cartridges one at a time (closing the printhead/cartridge cover and printer lid each time to allow the printer to recognise the cartridges) and see if one or more in particular is not being recogised..
Try a new or old cartridge to see if that is recognised if necessary.
Beyond that you may be out of luck unless anyone else has any other suggestions...
Nov 26, 2012 | Epson Stylus NX515 All-In-One InkJet...
I have a zip hydrotap & have just come home after 1 month away to finfd that I can't get any hot running water. I have checked the child proof is not on. The cold water flows just fine and...
Hi, I would turn the power off first for 5 minutes and then back on again, this normally works for me. You can also check on the front screen of the unit that it is in "Normal Operation" Cheers Pete
Jul 07, 2011 | Kitchen Ranges
Just installed a kitchen faucet and now it leaks when on at the b
sounds like you may have clogged the little screens at end of spout try unscrewing and see what happens if not you may be suffering from the returned part open box syndrome
May 10, 2009 | American Standard 1340M.105.002 Polished...
Error messages on my Ariston AVXD109
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
Sep 07, 2008 | Ariston Technologies AWD121WH
Whirlpool washer
maybe too much soap powder
cut down soap and use low suds powder
Jan 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
29 people viewed this question
k24674
jasbo
jasbo
