Question about Maytag Heating & Cooling
What is seer rating for maytag model # psa1bc048ka-cond. unit & pamibm060acb-ahu
22yooper
  • 828 Answers
SOURCE: Size and SEER rating
2 ton (24,000 BTU) 10 SEER
Posted on May 22, 2008
SOURCE: what is the seer rating for this unit,and how old
for witch unit need name plate data information
Posted on May 03, 2009
james3751
  • 614 Answers
SOURCE: what is the SEER rating on Goodman Air Handler model a32-05c?
Slightly more than 10 seer . Depending on the outside unit. A30 are 10 seer. Rusty
Posted on Jun 07, 2009
  • 10 Answers
SOURCE: I have a Carrier model 38ycc048320. Does anyone
On Carrier.com. All units are listed there. You can call your local Carrier office and they can get that for you as well
Posted on Oct 21, 2009
SOURCE: I have 2 Weather King units model numbers
Hello Larry Both units are 10 SEER.Standard rating ,not efficent units.JA25 is a 2 ton unit,JA60 is a 5 ton unit.Thats 24,000 BTU & 60,000 BTU.I hope that helps.
Posted on Jul 08, 2010
I just installed this unit and can not get the blower to run
Seriously depends on what unit you have. Model # & serial #? You can "jump" R to G at the unit. If its a standard Goodman AHU there may be a terminal block or just some wires that were factory installed outside of the unit. R to G will send 24v to the blower relay, sequencer or board (depending on model) energizing the relay and then returning to common. If you have tried that you should ensure you have proper line voltage 220-240vac. at the service breakers on the AHU.
May 18, 2015 | Goodman Manufacturing Goodman GPH1330M41...
I live in Phoenix, AZ. I have a 2 story 2300 sq ft home built in 2001. I have two Carrier AC units outside on the side of the house. They are the originals. The Large unit (upstairs) model 38CKC042340 and...
T the upstairs is a 3 1/2 ton 10.0 SEER condenser, and the downstairs is a 2 1/2 ton 10.0 SEER condenser. You can use any 10 SEER Unit on replacement, but if you go any higher in SEER (efficiency), there is a possibility the unit will freeze up. The reason is because the indoor coil also has an efficiency rating (10.0 SEER). It is not a good idea to mismatch units when it comes to SEER. Otherwise, you can use any brand of unit, if you want to go higher in efficiency, you need to change the indoor coil as well. Hope this helps. Mark
Jul 31, 2011 | Heating & Cooling
I have a raka-037jaz air cond. I was wondering what size is this unit? And if my breaker keeps tripping for the outside condenser does that mean my compressor is workIng too hard and needs to be replaced?...
Hello You have a 3 ton unit with a 10 SEER rating.this unit should NEVER be on a 50 amp breaker.The breaker size is on the model plate/sticker....any way the compressor is shot and it is time to find a new 3 ton condensing unit.espescially if it is TRIPPING a 50 amp.Good luck
Jun 17, 2011 | Heating & Cooling
NO PROBLEM YET, JUST HAD A GOODMAN AIR CONDITIONER INSTALLED MODEL CKL36-IL AND WAS TOLD IT HAD EXCELLENT EFFICIENCY TO FIND OUT THAT ITS A 10 SEER EFFICIENCY RATING WHICH I UNDERSTAND IS THE LEAST...
10 seer was the most efficient for the older generation units and in 1992, it was required that any unit has to have 10 seer or greater. The least efficient seer rating you will find on any new unit will be 13 seer which is a lot better than 10 seer and will save you almost 30% in energy cost. As of lately, they have made units available that are up to 20 seer or more, but they are pricey. I know you said you just had the unit installed, but from the model number, I'm assuming it is an older unit? If new, then it would have at least a 13 seer rating. Hope this answers your questions!
Aug 18, 2010 | Heating & Cooling
I HAVE A GOODMAN MODEL CKL36-1D I'M TRYING TO FIND OUT THE SEER RATING ON THIS MODEL.CAN ANYONE HELP?
Your going to need to know the age of the unit. If its less than 5 years old, its most likely a 13 SEER. If its anything more than 5 years old, its most likely a 10 SEER. If its anything over 10 years old, its most likely an 8 or 6 SEER.
Remember, that a unit will loose an average of 1-2 SEER for every full year of operation. This is just due to age, wear and tear, and usage.
So, if its a 10 SEER unit that is 7 years old, you could say that it is about as efficient as something in the 4-6 SEER range.
Jul 12, 2010 | Goodman CKL36AR36 Air Conditioner
I have 2 Weather King units model numbers 10AJA2501 & 10AJA6001 and am trying to determine the sizes and SEER ratings of each
Jul 08, 2010 | Weather King 10AJA2501AH Air Conditioner
I cannot find the seer rating or tonage of a Goodman air conditioner serial number 9908524497
My books do not go back far enough to get you the Seer rating, it is a 5 ton unit and as the serial number shows it to be a 1999 model, it is probably a 10 SEER unit, maybe a 12 seer, but not likely, but I can tell you that it was manufactured on the 8th week of 1999.
I hope that I have helped, have a great day.
Sincerely,
Paul Gibson
Mar 31, 2010 | Goodman CKL60AR60 Air Conditioner
No problem. Need to find out the seer number for
12 SEER In accociation with name brands such as Maytag, Westinghouse, Frigiaire, Kelvinator, etc.
Jul 11, 2009 | Heating & Cooling
What is the cooling btu on my BDP company division of carrier
is this unit real old ? it does not come up in my book . the btu is 30000 that is the same as 2.5 ton it may be 6,7 or 8 seer i dont think its a 10 seer because the 10 seer units are listed and yours is not . if this sounds wrong please look up the mod # again and post the ser # too ......... Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 15, 2009 | Amana Comfort Zone 12M32PBEH Air...
Model #uacc 030jas - BTU/H and SEER
that is a three ton unit and most likely a 10 seer rated seer rating are posted 6 months in cool and 6 months in heat to get the number on the unit if you are more interested in heating rating of heat pumps the aher or annual heating efficiency rating is of the most importance in this category the unit posted very well
Nov 14, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
47 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
