Question about Garden
New holland t35d pto
The pto on my NH TC35 doesn't stop spinning when I disengage the pto lever. It started intermittently with weak spinning after disengaging and the pto shaft could be stopped by applying slight pressure manually and would stay stopped. I changed the hydraulic fluid which was long overdue. That didn't help. The old fluid actually looked very good, clean, no grit or metal, no bad or burnt smell. The problem worsened. Now the PTO won't stop at all. When engaged it spins full speed. When disengaged it spins somewhat slower. Also when the tractor is shut off the pto shaft will turn freely by hand. I have the New Holland repair manual. But I don't know where to start. Depending on what the problem is, this may be beyond my scope. Some of the overhaul procedures require special tools etc. Any help would be appreciated.
4 Suggested Answers
wireguy212
  • 1627 Answers
SOURCE: PTO CONTROLS. How do you engage and disengage PTO.
The tractor is not a 6300 is it.If it' not you need to adjust the cable for the p.t.o. until it will stay down.Don't turn the turnbuckle too much at a time because there is a fine line between the won't engage and the won,t disengage adjustment.
Posted on Oct 21, 2009
  • 1575 Answers
SOURCE: I am looking for a owners/repair manual for tc35 New Holland tractor
The manual's only available for purchase online with the best deal being from the site on the link below.You may have to part with $29.95 for the whole manual package.Click on the link if you wish to make the purchase.
www.tradebit.com/filedetail.php/106149126-new-holland-tc35-3-cylinder-compact-tractor
Hope this helps.Thanks!
Posted on Jan 12, 2012
radco855
  • 126 Answers
SOURCE: Can malfunction of PTO or other safety switches prevent start up of mower
You didn't state the model or brand of tractor, but usually the way the cranking circuit work is, from the "S" terminal of the ignition switch, the circuit runs to the PTO switch, if it's in the OFF position, the circuit then runs to the pedal switch, if it's in the DOWN (or brake on) position it then runs to the solenoid. On other tractors, from the ignition switch, the circuit runs to the pedal switch first. (The seat switch isn't used in the cranking circuit).
Any switch can go bad, but I would more likely suspect the pedal switch or loose connection at either switch. (But it could actually be the PTO switch).
Try tracing the circuit from the "S" terminal of the ignition switch through the PTO or pedal switches to the starter solenoid. You may get lucky and find something obvious.
If you find nothing, try jumping across the pedal or the PTO switch (only two terminals are used in the cranking circuit, trace back to ignition switch for the incoming, outgoing is usually directly adjacent). Jumpering will take these out of the circuit and tell you if either is bad internally.
Lastly, there's always the possibility that the ignition switch is bad. (Doesn't happen all that often, but it's suspect as well). Jumper from "B" terminal to "S" terminal will take it out of the circuit.
Posted on Aug 22, 2012
I have a nh ts125a and the pto symbol and the ! Is on pto works fine the parking brake light is also on the brake is disengaged
Ford New Holland TS135a TS125a TS110a repair manual
www.slideshare.net/.../ford-new-holland-ts135a-ts125a-ts110a-repair-ma...
Feb 8, 2014 - New Holland TS100A TS110A TS115A TS125A TS135A Repair ManualComplete Factory Service Repair Manual New Holland Fuel Injection ...
Jul 28, 2015 | Cars & Trucks
Any adjustment for hino dutro tipper pto.
When engaging the pto it is important that you have the clutch disengaged so that the pto gear is not spinning in the box.before it engages.
The pto gear runs off the counter shaft of the gear box and is spinning all the time the engine is running
when engaging the pto ,you are physically engaging a gear ( like selecting 1st gear) so you have to stop the counter shaft spinning so that the pto gear will engage with slashing
Jun 14, 2015 | Garden
Pto suddenly stopped working on my late 90's 25 hp dlt lawn tractor
Sounds like your cable might of broken. watch the deck end of the cable when you pull the lever up. If it is not moving the pully, it is broken. If you are trying to start with lever still up, even though the deck is not running, the safety switch is usually up on the lever. Try disengaging the deck lever, sit in seat, apply brake or parking brake and turn key to start. Let me know if that doesnt work and we can go from there.
Aug 06, 2014 | Craftsman Garden
On my 42in cut hydro. Husqvarna, The mower will not disengage until the speed is reduced to a low idle
Before you do anything else check to make sure the blades are engaged on thier seat ( the star) and the blade bolts are tight.
If you have an electric PTO this does not apply to you.
After confirming that your blades are tight check the operation of the PTO cable and the pivot bracket by lowering the deck all the way. Laying on the ground on the discharge side of the mower you will be able to look at the components and see and touch whats not moving freely as you engage and disengage the PTO lever. Look for a stiff PTO cable, stiff pivot bracket, missing return spring, broken spindle brackets and broken deck bracket welds.
Of course you should never work on any mechanical device while it is running.
Oct 31, 2012 | Husqvarna Garden
Jan 12, 2012 | Garden
Hi, I have a 2008 Kubota L3400 HST and recently developed a problem with the PTO not turning off when when the PTO lever is shifted to disengage. I have disconnected the two small wires to the PTO lever...
I just fixed the same problem. The cable running from the PTO shift goes into the transmission case under your seat. You can follow the cable down and where you see a rubberboot, spray DW40 on it liberally. Work the PTO shift back and forth and wait five minutes. Do again if necessary. The spring load under the seat seems to seize up and the cable doesn't slide properly. This is one of the reasons for this problem that is easily fixed. The other a broken snap ring internally that is a much bigger problem.
Good Luck
Apr 21, 2011 | Computers & Internet
Tines wont turn /disengaging type grinding noise
its possibly the gears inside the box they are spider gears & wearout on those they are great machines but the gear drives are weak most of the time or the belt could be slipping
Jun 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
