My electrolux front loader washing machine is showing er40 on the screen everytime I go to press the wash (play ) button n makes a clicking sound as if the machine has finished a wash but it hasn't even started to was
2 Suggested Answers
FitzOriginal
  • 842 Answers
SOURCE: The door will not open on my Electrolux washing machine
How much trouble do you want to go to?
If you just want to preserve the washing, then simply put it on another cycle tonight and that will keep it fresh until the callout turns up to fix it.
The next clever step is to power the machine off at the mains for 10 minutes. Depriving it of power MAY release the interlock door switch even if the cycle didnt.
Final attempt to get to it... Turn off power, unplug at the mains. drag the machine out so you can see the back. Remove the 2 screws that hold the top on, pull back or tap the top forward (depending on the model) to unclip it. Peer inside. You will see the door switch inside the chassis exactly in line with the door handle on the outside. See if you manually make the mechanism release, or if you have a stubby philips screwdriver, you can probably unscrew the switch complely.
If you trust yourself NEVER to open the door in the middle of a cycle, the machine will of course function without a switch. Just so long as you recognise that you will flood the place if you do open it with water in. Also if you put your hand inside dirung a wash (Or worse still a spin) the power of the motor combined with the weight of the wet washing will rip the arm clean off a fully grown man, so if you doubt yourself or you have kids (or kids may visit) don't leave it like this.
Posted on Feb 09, 2009
My Electrolux front loader machine is showing EHO in the display, it won't move off it no matter which program I try to display, can you please help me?
The power supply is failing and needs to be replaced but first try the steps provided in the link below. Washing machine displays error message EHO EH0
Feb 17, 2018 | Electrolux Washing Machines
My Electrolux F/Loader won't start filling. I select a wash cycle and start . The screen shows 'filling' but only makes clicking noises.
Thank you for your post, friend!
I see that your Electrolux washer won't fill during the cycle and makes a clicking sound. This clicking sound could come from either the motor or the water valve. In order to locate which component could be causing the issue you may need to disassemble your washer. I would recommend having a professional technician out to properly disassemble the washer to prevent any personal injuries or future issues. I hope this information is helpful to you. -Matt
Apr 17, 2016 | Electrolux Washing Machines
Showing on screen E41
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and the nearest option button simultaneously for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensor faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
Sep 14, 2015 | Electrolux Washing Machines
Our electrolux front loader Washing Machine EWF 1083 won't fill with water and there is a humming sound, does anyone know what the problem is ? cheers
Just a long shot - it may be the water inlet filter is blocked? normally there is a little mesh filter in the hose that screws onto the back - check that its not full of crap. This happened to me only a few weeks ago hope its as simple as that for you.
Jan 20, 2013 | Washing Machines
Zanussi electrolux zwf14581w won't start, displaying Er40
my father had a zanussi dishwasher that did the same thing, turns out one of the door sensors had gone and would not release the lock. had to get an engineer out, luckily it was under warranty.
Apr 05, 2012 | Washing Machines
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
How do I unlock the door. I pressed pause however it didn't unlock and then I pressed all sorts of buttons. Now the green little button above the key simbol is on. Can't find use manual. It is the...
try un pluging it for a couple minutes then after plugging back in ht stop cancel see if that works.if you know the model # you can download the guide from electrolux website
Feb 17, 2010 | Electrolux Washing Machines
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
