Question about Sharp R-1500 Microwave Oven
Sharp R-1500 range lights
My 2 over-the-range bulbs will not stop burning out. They rarely last more than a month or two. I always stay within the recommended wattage (no more than 30) and I even tried lower 20W bulbs, with no change. Why do these bulbs burn out? Thanks, Fri 805
  • Sharp Master
  • 9,098 Answers
Are any other bulbs in the home going out prematurely? If so, I would check the actual voltage of your power outlets. If not, the bulbs may be getting grease or debris on them from stovetop cooking. This can cause hot psots and premature failure. I recommend wiping them clean with alcohol on a cloth before installing them. I recommend that folks always have their hood fan on when cooking on the stovetop. Also, you might check with a local home center (Lowe's, Home Depot, etc.) to see if they have some high-quality (non-Chinese) substitutes.
Posted on Sep 23, 2007
What light bulbs are for a Sharp R-1502 carousel microwave?
Hi,I would try (www.espares.co.uk),you can put the model in and it should give you the right lamp for your microwave,all the best.
Feb 05, 2018 | GE Microwave Ovens
Bulb on ge microwave keeps burning out
Hi anything is possible being that you even replaced two different brands of bulbs. I don't think the wiring harness is the problem but like I said anything could be the problem. Might I make a suggestion. Why not replace both the left and right side bulbs with LED bulbs with the same base configuration. Maybe that just might be able to solve your problem. I would like to know if it does. It also seems that a lot of others are having the exact problem. Good luck.
Marty
Apr 14, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
On our Panasonic the genius sensor 1200w microwave the bulb burned out so replaced. After replaced turned light switch on both bulbs turned on and right away one bulb burned out and now the switch will not...
Mine burned out within a month. Probably due to the poor design of the machine which forces you to slam the door to get it to shut.
My biggest concern is the under counter lightbulbs it has burned out in my kitchen over the last year. I wonder how much leaking this thing really gives off. Moving in a few weeks and will be throwing this cancer machine out.
Sep 09, 2011 | Panasonic NN-H764 Microwave Oven
Work light switch not working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes or you can see the service manual at our site here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
May 13, 2010 | Sharp R-1601 Microwave Oven
One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
40 watt night light bulbs constantly burn out short out.
Is they are left on all the time, this can reduce their life, and they are more susceptible to vibration.
Have you checked at home center or home improvement centers like Lowe's, Builder's Square or Home Depot?
You can order quality parts such as lamps by entering your full model number or part number WB36X10003 here.
Always be sure the microwave is unplugged or the breaker is off when installing or removing bulbs, and be sure the bulbs and and your hands are clean when installing them.
Feb 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
BLEW A FUSE ?
Beware of this place, microwavedisplay.com. Of late, some are seeing very long turn around times. They don't respond to emails or answer the phone. See http://www.whoila.com/blog/?p=725 for some recent experiences.
Dec 09, 2008 | GE JVM1850 1000 Watts Microwave Oven
MH1140XMS Oven Stays On
Right, but I wondered if you might want the OLD broken board fixed, too, as a backup? Keep it in mind, It's only $39.95.
Feb 07, 2008 | Whirlpool MH1140XMS Microwave Oven
Unit does not turn off
open the control push boton and clean it one of the boton stoct.
Sep 19, 2007 | Panasonic NN-S254WF Microwave Oven
Sharp R-1500 Microwave Oven Logo
119 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
