Question about Whirlpool GGW9250PL Gas Dryer
Gas Dryer The igniter comes on, lights up but gas does not lightup. it will lightup manually by using a lighter. I have already replaced the igniter. thank you rekhapatel
It is either the flame sensor or the main gas valve
Posted on Aug 08, 2007
SOURCE:
Won't heat after gas meter replaced
goto the dryer's manufacturer's site and click on support you should be able to download the owner's manual, the pilot light needs to be relight or the pizeo lighter is not working
Jan 26, 2018 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Kenmore gas dryer 80series model 110.c72852101
if you hear the valve clicking but no gas the valve is bad.when the burner lights theres a probe that senses that it is lit and sends a microvoltage back to the controller to tell its lit.check to make sure all ground wires are grounded to a clean metal surface.
Oct 03, 2007 | Kenmore 74602 Gas Dryer
Gas does not light
Need more info. Is the igniter coming on but no flame, is the igniter not coming on. Several things will make the igniter not come on (timer, motor switch, thermal fuses, thermostats, temp selectors, etc. What have you checked already?
Nov 26, 2013 | Amana ALG331RAW Gas Dryer
Q 100 will not light but I hear the gas coming into the unit
Try lighting it with a fireplace lighter or long match. If it lights, your problem is your igniter. Either keep using lighters or replace the igniter.
Sep 11, 2013 | Weber Q100 Grill
How do you light a pilot light for my GE gas dryer? Model = DDG7188PHLWH
How old is your dryer? Only models from the 1980's and older have actual pilot flame lighters. If it's newer it will have either a spark igniter or an electric glow bar. If you have a large front access panel across the bottom, then you may have a pilot light. Remove the panel and look for the gas valve. (NOTE: Before lighting anything, make sure you do not smell gas. If you do, you'll need to air the room out before trying) There will be a burner coming out the back of the gas valve control and this control will have a red push button in the front or side of it to allow gas to the pilot only. Using a extended bbq type lighter, light the pilot at the pilot assembly and hold the button for about 60 seconds. The pilot assembly is connected to the gas valve control by a small diameter aluminum tubing with a copper thermocouple right next to it. Release and make sure the pilot stays lit. Before putting the access panel back on, turn on the dryer and watch for the burner to light. It should be a strong blue flame. Let us know if we can help you further. Not knowing why your pilot went out in the first place, there may be a unforeseen issue that may need attention. If you have a propane gas dryer and you ran out of gas, then it may take a while to get gas to the pilot, so be patient when trying to light it. Never hold the button down without the lighter lit at the pilot assembly, so there is not a build-up of gas. If you are not comfortable doing this, I recommend you call your gas co to light it for you, as many will do it for free! Good luck and be careful!
May 20, 2010 | GE Dryers
Oven won't light, any way to do it manually till it's repaired?
if it's the igniter you can use a long nosed lighter for lighting hot water heaters and get the bulb hot and hold the flame on it till you turn the gas on if it lights while you have the gas on then you can use it, if it won't light then you will need to replace the gas thermal bulb to get it to work.
Feb 05, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Dryer ignites but does'nt light
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
Jul 13, 2009 | Amana NGD7200TW Gas Dryer
Auto electric lighter for the gas stove no longer works
gud day,the problem is ur igniter ligther is totally damage & nid to replace, if u want to use ur cooktop use matches or ligther every time open ur gas cooktop,tnx gerbee
Nov 17, 2008 | Gaggenau 23 in. KG 260 Gas Cooktop
Oven
Try using a lighter, the type used for grills. Since you can smell gas, the gas valve is working but the egnitter that gives the spark to ignite the gas is apparently not working.
Usually is it not the igniter but the controller that controls the igniter. If using the lighter as suggested, and it lites, you probably will have to replace the igniter controller for the range
Dan Sims
May 23, 2008 | Tappan TGF320 Gas Kitchen Range
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
Open Questions:
Strange issue with my gas dryer and the control panel I am having a strange issue with my dryer. I have a Whirlpool gas dryer, Model: GGW9250PW0; and am having issues with the Electronic Control (mfg part 8558753). Yesterday, I went to go use the dryer and I press the "Control On" button like normal, but nothing happened. I did not get any lights or anything, yet when I open the door, the inside light comes on. I have a similar model washer plugged into the same electric outlet and everything there works fine. After researching the issue out a bit, I took off the toe panel and took off the duct-lint (mfg part W10128606) so that I could reach the wires connected to the dryer thermister and dryer thermal fuse better. I then took the wires off both of those as well as disconnected the sensor wiring harness (mfg part 3406653) and used a vacuum to clean out any lint as well as compressed air to clean off those connectors. I re-hooked all the wires back up and plugged the dryer in. I pressed the "Control On" button and all the proper lights lit up. I then pressed the "Cancel" button to turn it off, unplugged the dryer, and put the duct-lint back on. I plugged the dryer back in and tried the "Control On" and "Cancel" again, and it still worked. I then put the toe panel back on, pushed "Control On", then turned on the dryer using the "Hold to Start" button and everything worked like it used to. Here is the strange issue I am having. I ran a load in the washer and when done, I put in the dryer and tried the "Control On" button. Everything came up, but when I pressed the "Hold to Start", nothing happened. I then tried to press the "Cancel" button, and nothing happened. I could turn the knob and the different lights lit up, but none of the buttons seemed to be working. After holding the "Cancel" button for a few seconds it turned off the panel lights. I then pushed the "Control On" button again and had to press it a few times before the panel lights came on. After a little bit of playing with the buttons and knob, I was able to start the dryer. I stopped the dryer (didn't want to run it the whole time in case something is wrong) and tried to start it again. I can get the panel lights to come on, but it seems like the buttons are sticking and not fully working like they should. I don't want to have to buy an expensive part unless I absolutely need to and wanted to see if anyone can think of anything else that might be going on or that I could try before paying almost $200 for a new Electronic Control, especially if I will still have the same problem after replacing this part like some other people have reported. Thanks!
Jun 14, 2013 | Whirlpool GGW9250PL Gas Dryer
See all Whirlpool GGW9250PL Gas Dryer Questions
Whirlpool GGW9250PL Gas Dryer Logo
71 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
