Question about John Deere Garden
John deere la120
I have about 320 hours on my tractor and experiencing it not climbing hills very well and a high pitch noise when running. This usually happens after about 1/2 hour of running. I only have about 1 acre of mowing to do and the hills are not that steep.
5 Suggested Answers
  • 3911 Answers
SOURCE: I have a lgt2654 husky
either your drive belt is loose/stretched or your transmission is going out. check the belt and tensioner.
Posted on Aug 29, 2011
  • 6468 Answers
SOURCE: Cub Cadet LT1046 shutters when under a load, climbing steep hill
i would check the belt for oil or slipping the check rear axle fluid level
Posted on Mar 27, 2012
  • 884 Answers
SOURCE: John Deere X300 stalls after running for 1 hour
Diesel filter clogging up, may have water in it
Posted on May 15, 2012
SOURCE: My John Deere L130 riding mower quits after it has been running
A John Deere repair guy showed me how to fix this. It is very simple. Remove the gas cap. Pop out the liner in the gas cap with a thin pocket knife. Clean out the cap. From the top of the cap, where it comes to a peak, take a very fine point (even a small knife blade will do) and make sure the little hole in the top (that you didn't know was there) is clear. The engine is starving because the gas tank is not properly vented. I suffered with this problem for two years until he came to sharpen my blades and I asked him about this. A two minute, free fix did it and I have never had problems again.
Posted on Jul 04, 2012
My John Deere 2520 hydrostatic transmission is making a screeching noise when I push on forward or reverse pedal.
Maybe a pulley trying to lock up, drop the deck and spin your pulleys to see if theres one thats hard to turn or is loose
Apr 27, 2016 | John Deere Garden
I have a L130 and after it warms up it starts to whine and won't go up a hill.
Is the belt going tight enough when the drive is engaged make sure it is not slipping or you may have a rear drive problem.
Apr 26, 2014 | John Deere Garden
Lack of power after running for 15-20 minutes.
It sounds as though the ground travel belt (Drive belt) is slipping, you didn't mention the engine was bogging down so that is what comes to mind first. adjust the tension or replace the belt and if it is slipping that will remedy the issue.
Jul 15, 2010 | John Deere Garden
I have a John Deere LA150 that will not go steep
I have the same problem same year, same model. I changed the drive belt and it still won't go up steep hills that it used to easily climb. I don't see any way to adjust tension and it doesn't cover that in the operator's manual. What did you find out with yours?
May 01, 2010 | John Deere 54" Front Blade Part Catalog...
John Deere L120 transmission high pitch noise and no forward move
Try jacking the unit up. Start it up and try moving pushing the forward and reverse back and forth and see if it does it then. It sounds like an oil way in the hydrostatic unit has a check valve stuck. Of course make sure that the fluid lever is up. Hope this will help you. donnyb60
Mar 23, 2009 | Garden
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
