Question about SanDisk Sansa c200 MP3 Player
Headset jack headset will only work one side and the other didnt hear nothing
  • lawchick Dec 27, 2007
    MIne is doing this too, I have a Sansa 2G, and it's not the headphones (tried 3 pairs now). How do you fix the jack? And will SanDisk do this for me??
  • 12,061 Answers
Ok often this is caused by one of the cables in the earphones breaking.. try another set. Sometimes it can be the socket on the unit breaking at the solder joint on the PCB, if it is, and ya can solder? it is a pretty easy fix. But I would "Punt" for a broken earphone lead.
Posted on Aug 08, 2007
Why my headset not working/realtek?
Do the speakers work? Maybe you have the headset plugged into the wrong Jack. Maybe you have the headset on Mute. If the speakers work, unplug where the speakers go into the computer's port and plug the headset into that same port and see if you hear anything. If not, maybe your headset is bad.
Mar 25, 2012 | Computers & Internet
I can hear callers through my s11 plantronics headset but after using and trying all configuration no.'s they can't hear me at all
Make sure the Plantronics S11 headset is plugged into your handset jack on your phone, not the headset jack, this will make a difference on most phones. After plugging the S11 into the handset jack on your phone, you will need to pick up your handset receiver and sit it off to the side of the phone to place a call or to receive a call, after you are finished with your call sit the handset receiver back in the cradle on your phone.
Good luck from Headsets Direct!
Nov 07, 2011 | Plantronics S11 Headset
I have the Plantronics S11 headset and I can hear callers, but they can't hear me, I need to know what to do. The phone is working fine and everything is all set up correctly as far as I can tell.
There are a couple of basic things to check first. You want to make sure the mute is turned off and your outgoing (mic) volume is loud enough (there is the speak level switch on the side and the speak volume control on top). Also, you want to make sure it is connected through the handset jack on the phone (generally it will not work through the headset jack on the phone). Finally you want to make sure it's configured right (scale located on the side).
Good Luck from Headsets Direct!
Jul 04, 2011 | Plantronics S11 Headset
Everytime i hit the blue button on the desk set i don't hear a dial tone in my head piece
Two things to remember. If you're connected through the handset jack, the handset (receiver) needs to be lifted off the phone to get a dial tone. Secondly, if you're connected through the headset jack, you may need to adjust the configuration dial (round dial on left-hand side of base) to make it work when the headset button on phone is pushed.
Aug 24, 2010 | Plantronics Voyager 500A Deskphone Adapter...
How do i fix the volume because i do not have sound? my tv has no volume/sound. tried turning the tv up and down but still no sound
1 - hi
2 - check the jack for headset
- if you heard any sound with headset = your speakers are burned
3 - if you always use this jack for head set its maybe got problem = when push or pull the headset jack if you hear any sound from speakers your headset socket should change
4 - if you didnt hear any sound from both (speaker and headset) it means your ampilifire should repair
May 23, 2010 | Emerson CR202EM9 TV
LG VX5400 Cannot hear during calls
I was able to get the phone "unstuck" from this mode by plugging and unplugging my wired headset several times. Perhpas the contacts were dirty inside the jack...
Sep 20, 2009 | LG VX5400 Cellular Phone
Palm Centro has a faulty headset jack. I can hear sound through the (Plantronics, wired) headset, but no one can hear me, neither through headset nor without a headset. Centro acts as if there's a...
i had this happen to me recently and found out whats wrong the phones kinda slow and thinks the headphones are still plugged in and if you take out the battery and put it back in it saves that you had somthing plugged in and dosent help. For some people they can fix this as easily as plugging the headset back in and pulling it out slowly but for me this didnt work so what i did is, i turned on pocket tunes and you souldnt hear anything and make sure your sound is turned on, then take a small pin and stick it in the headphone jack and wiggle it around untill you hear somthing and then quickley pull out the pin.
Hope this helps
Jul 09, 2009 | Sprint Centro Smartphone
My headset is grounded
pushing the jack hard may result in some connections pushed way off, and there is no contact to the speaker. Please see the nearest technician.
Jun 12, 2009 | Cell Phones
NBX 3102 Headset jack stops working
You should be using a plantronics a-10 interface cable if you are using hardwire headsets. get rid of the m-20 amplifiers. I support 280 of these phones and the best solution is to replace the phone. Power cycling the phone will help for a while but the problem will come back.
Feb 02, 2009 | 3Com NBX 3102 IP Phone
Headset jack
If its less than 1 year, you can call SanDisk and they will replace it.
Sep 02, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa  c200 MP3 Player Logo
50 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
