Question about Cell Phones
Hype wireless bluetooth mobile phone zone - Cell Phones
How do I get a pairing code for a HYPE Ultra Slim Bluetooth Keyboard?
Pairing code for keyboard is not usually required. The one I have basically has a connect button, then you confirm on the computer. Otherwise the most common pairing code seems to be 0000.
Dec 01, 2014 | Hype Technology Ultra Slim Bluetooth...
How do I get a Bluetooth pairing code for a hype ultra slim Bluetooth keyboard?
The pairing code will be displayed on the screen of the device you are trying to pair it with. Simply switch on the keyboard. It should go into pairing mode looking for a device. Go into the bluetooth option on your device and you should see the "HYPE" device listed. Choose it and then enter the pairing code that displays on the screen of your device. That should be all there is to it.
Unlock samsung sgh a256 hype
hi codes are the best method to unlock your samsung hype from network lock.to get codes visit superunlockcodes.com here they ask you the network name to which your mobile is locked and the imei number of your mobile .finally they send you codes to unlock your mobile.
Jul 17, 2012 | Samsung A256 Hype Cell Phone
I av bluetooth model no ce0889 but it is not conecting with my nokia e5 nokia mobile phone please tell me solution ,thanks
try to insert it in another nokia mobile phone same to your phone, If not functioning you may go to the any nokia mobile phone store & ask them to find you the right nokia wireless bluetooth headset. You may also return it where you buy it, bring your receipt to change what fit to your mobile phone, or consult mobile technician.
May 26, 2011 | Nokia Wireless Bluetooth Headset Headset
How can i upload my pictures to my pc from my samsung hype a256
You can upload your pictures :
1.) Using a Bluetooth Dongle
2.) Using a Data Cable
3.)If your pictures in your phone memory then copy or move those to memory card.And then use a Memory card reader to upload your pictures.
Dec 20, 2010 | Samsung A256 Hype Cell Phone
Will a Bluetooth wireless headset work with a normal Blackberry phone, or does the phone have to be Bluetooth enabled?
yes, for you to use a bluetooth headset with any mobile phone, it has to be bluetooth enabled so it can have a means of connecting to the headset.
although, majority of the blackberry phones that are known should work with certain bluetooth headsets since they do not comprise of just simple mechanisms like normal mobile phones. that is just about the same way that iphones usually select special types of bluetooth headsts to work with
hope this answered your question, please rate
Dec 15, 2010 | Just Wireless Bluetooth Headset Wireless...
How to connect samsung tocco mobile to another samsung tocco mobile using bluetooth?
Turn on the Bluetooth wireless feature.
To turn on the Bluetooth follow the below steps,
1. In Menu mode, select Applications > Bluetooth.
2.. Select the circle in the center to turn on the Bluetooth wireless feature.
3.. To allow other devices to locate your phone, select Settings > On under My phone’s visibility > Save.
To connect other device to your mobile
1. In Menu mode, select Applications Bluetooth Search.
2. Select and drag a device icon into the centre.
3. Enter a PIN for the Bluetooth wireless feature or the other device’s Bluetooth PIN, if it has one, and select OK.
When the owner of the other device enters the same PIN or accepts the connection, pairing is complete.
After connecting you can start sending the files from one mobile to another mobile.
To send files follow the below steps.
1. Select the file or item from one of your phone’s applications that you want to send.
2. Select Send via or Send URL via Bluetooth, or select More Send via Bluetooth
Thank You
Aug 12, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
My mobile is nokia 6085 has aproblem in its bluetooth, the bluetooth send data to other mobiles but can't receive any data from the other mobils
it's simple,just turn visibility option to shown to all in your bluetooth option,but take care to turn of bluetooth after complition to make safe your mobile from viruses
Dec 07, 2009 | Nokia 6085 Cellular Phone
Cell Phones Logo
70 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
