Question about DeLonghi Microwave Ovens
Delonghi AC925EFY(F) Bought new 4 months ago and it's never been out the box until yesterday. It has not been dropped or damaged, the 1st time I used it yesterday to nuke a cup of tea for 30secs it was fine, but on using it today it made loud buzzing noise while going round. Its not heating anything on micro setting, but works on oven and grill.
Wheres the bulb in a delonghi AC925EFY microwave
You must remove the outer cabinet from the Microwave to access the bulb. Remove every screw top, sides and bottom and slide the cabinet off.
Sep 06, 2016 | DeLonghi Microwave Ovens
Sear Advantium 120
Disconnect it and connect bac to power. check the fuse. If nothing works is either the fuse, the cable or the power supply unit.
Apr 03, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave makes nioses
I would be concerned but since only a few months old take it back for repair or replacement.
Dec 19, 2012 | Hamilton Beach 1.1 Cu. Ft. 1000-Watts...
Hi, I bought this microwave yesterday, and set the clock as per manual.
Take it back to the store, there is nothing you can do, this is a manufacture issue.
Jul 16, 2012 | DeLonghi P90D23ELT2AH Microwave Oven
Delonghi ac925efy working but making noise all the time
This indicates a triac switching semiconductor problem, the triac is a switching device that allows the microwave oven to run on different power settings, if the defrost cycle is running on a higher power level it is most likely the semiconductor, but the possibility remains that the keypad control board may be the issue.
Apr 14, 2012 | DeLonghi Microwave Ovens
My delonghi perfecta plus esam5450 tells me to descale when the last descale was only 3 weeks ago. It is 18 months old and I usually only need to descale every few months. However, the last 3 times i have...
Marion, mine does the same and is around the same age. Did you ever get advice regarding this. I don't use rain water, I use tap water, but same problem
Aug 16, 2011 | Microwave Ovens
Recently purchased this microwave (4-5 months ago) 5E error light comes on. Unplugged worked for short period - lights came on and off, things started beeping and the 5E came back on. Have repeated this...
"SE" means you have a shorted membrane keypad. It's not uncommon for it to be intermittent or partially operable.
Since it's under warranty, I would contact Samsung for a free fix. See your owner's manual.
Jul 06, 2011 | Samsung SMH9151ST Stainless Steel 1000...
Hi, i have an ac925efy delonghi microwave oven, i bought it manufacturer refurbished and when i switched it on there was a big bang and a flash. it came from what looked to be the back top right hand...
From your description it is the magnetron that heats the food that has gone, I suggest that you take it back for a refund, because if you decide to fix it the repairs will run you more than what the microwave oven is worth.
Jan 16, 2011 | DeLonghi MW 535 Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top DeLonghi Microwave Ovens Experts
William Miller
William Miller
Steve Mason
Are you a DeLonghi Microwave Oven Expert? Answer questions, earn points and help others
