Question about Garden
Instructions Manuals BX2506 Kubota Three Point Hitch
4 Suggested Answers
RonPark
  • 855 Answers
SOURCE: Manual needed for JD 3 bottom plow w 3 point hitch
The first thing to do is get all the information you can off your plow. Like: serial number, model number and any info on any tags you find then go to the John Deere web site. Go to the plows section and you should find everything you need. They do have parts lists and manuals on the site. But it may be harder to find parts without at least a model. But they do have help areas you can try. Try there and if no luck try to give me all the info you can about what you are looking for and I'll do some research for you.
Posted on Sep 13, 2009
  • 5 Answers
SOURCE: pto, fuel gauge, three point hitch all stop
check the acc fuse
also check wires under seat because of short in them will not let pto work
Posted on Jul 09, 2010
SOURCE: Three point hitch on 2020 Jogn Deere Tractor will not raise.
In the worst scenario, the follower, or the piece that senses load on the control shaft , may have broken. Several causes could be the culprit, but happened on my 2520 . Fix requires total disassembly of final drive and differential to remove control arm and repair the follower. Good luck.
Posted on Jun 27, 2012
How to remove/replace Kubota b7100 three point hitch hydraulic control lever
Try you tube, type "How to remove/replace Kubota b7100 three point hitch hydraulic control lever." there are videos.
Aug 20, 2016 | Kubota Garden
How do I get to three point hitch to apply down pressure on the implementI
3 Point Equipment - Tractor Supply Company
www.tractorsupply.com/tsc/.../3-point-equipme...
Tractor Supply CompanyTSC has 3 point tractor disc, trechers, forks, attachments and implements for sale every day. ... modern farming as much as the adoption of the three-point hitch.3 Point Landscaping & Utility ... - ‎3 Point Cutters & Hay ...
Oct 01, 2015 | Toys
3 point hitch won't go up wuz working. On a kubota tractor
is the pto lock on if not checkto see if hydraulic fluid is at normal operating level:) i had this problem a while ago!!!
Aug 17, 2015 | Kubota Garden
Three point hitch when up all the way the pump continues to. Pump
Springs, or valve seats in the control valve need repair. Or at least my wild guess, with some understanding of hydraulics, in general.
Mar 25, 2015 | John Deere Garden
Deere 5525 control stick is difficult to pull back
Are you talking about the three point hitch lever? Does it have a cable going to the three point hitch spool valve? If so, try spraying penitrating oil in the cable at both ends.
Jan 02, 2015 | Garden
Do you have free manuals of Kubota mowers?
Try requesting manuals directly from Kubota.
Jul 16, 2014 | Kubota Garden
Three point hitch wont lower, kubota l2550
Mine did the same thing. Below the front of the seat is a knob sticking toward the front of the tractor that is angled upward that controls the fall rate of the three point hitch. After searching the internet for a while I found what this knob is for and went out and turned it until the three point fell down. The knob is perfectly placed to bump with my foot as I get off the tractor (I have large feet and bump a lot of controls getting on and off) and I guess I had bumped it closed over time.
Dave
Jun 22, 2012 | Garden
The three point hitch raises with hydraulic pressure. When the hitch will not raise the first thing to check is the hydraulic fluid level. If it is low add hydraulic fluid to the proper level as stated in the owner manual.
Jun 20, 2009 | John Deere 420,1020,2010,2020,2510,2520...
3 point hitch wont lower
Some of these tractors have a knob under the seat that locks the three point up so it cannot be lowered by accident. Check for this knob and open it.
Mar 27, 2009 | Garden
Garden Logo
120 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
