Question about SanDisk Sansa c150 MP3 Player
Headphone jack only heading one side
  • Anonymous Mar 26, 2009
    the left side will go in and out and you have to turn the connector to have the sound come out right. it's not the headphones, i've tried on different ones and speakers. it's the headphone jack inside the player
I would think that this wouldn't have to do so much with the mp3 that the fact that your headphones are broken. Hvae you tried other headphones?
Posted on Aug 15, 2007
SOURCE:
Headphones
Hi
Try them in another device to eliminate a faulty jack, if they still dont work the head phone may be faulty, return to seller and ask for a refund or replacement.
But also try a different head set in the jack to see if the jacks working properly.
Cheers
Nov 23, 2012 | Steel Series SteelSeries 7H Headset -...
I have a VI210 big tv and want to put wireless head phone on it. I need to know if there is a jack for head phone if not where do I plug it in
Most TV's will have some kind of stereo output - if not in the form of a 3.5mm headphone jack, then in the form of two RCA outputs (Left and Right).
If you can't physically see a headphone jack on the back, bottom, sides, or front of your TV, it probably doesn't have one. However, You can plug an RCA to 3.5mm female adapter cable into your TV and plug your headphone receiver into that!
May 19, 2011 | Televison & Video
Brand new. No sound from any speakers or headphone. Headphone indicator is on without headphone jack inserted
try to reinsert the head phone jack there is small switch in side while moving or play the system and try to insert
Nov 17, 2009 | Onkyo TX-SR876 Receiver
Only one side works when headphones are plugged all the way in and both sides work when only half way in, but this is no good as it doesn't lock into place only half way in and keeps falling out.
apple's love is too deep. crumple some tinfoil - aluminum foil - and drop it in the jack receptacle, then insert jack - worked perfectly for me - after a long frustrating morning surfing for solution.
Jul 07, 2009 | Apple (MA662G/A) pour iPod Headphones
My headphones wont work everthing else is fine
Hi There,                The input for the head phone is a 32 ohm input. You need to get the proper 32ohm headphone for it. It seems that you tryed others but there are 16 ohms and 32ohms headphones. But if they do not work then it is your input connection or the device if your headphones work on other devices.You should bring the product back as a faulty device to the store and exchange it with your reciept then.  For the headphone that works on one side it can be the headphone jack that does not fit properly into the hole input (female jack).The one side does not touch or connect for it to work. It happens to cheap headphones and some good ones too. The male jacks on the headphones are slightly off it specification size by a small amount that it is not noticed by the naked eye, so it does not get a good connection.Try another head phone if you haven't tryed that
Mar 26, 2009 | Audio Players & Recorders
Headphones only have left channel on Denon AVR-588 Receiver
Hi peroty,
Two suggestions for you.
1. If you look at the headphone jack connecton do you see one or two black O-rings or black lines on the jack. If you only see one they are Mono headphones and you would only get sound out of the left side. If there are two black lines they are stereo headphones and you should get sound on both the left & right sides.
2. If after checking the headphone jack connection and there are two black lines on it then I would suggest try a different pair of headphones to see if a different set of headphones works fine.
If a different pair of headphones works properly the original headphones may be bad. If neither set of headphones work properly it may be the reciever that may need to be repaired.
I hope it's not the receiver, but let me know if you have questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Nov 25, 2008 | Denon AVR588 Receiver
AHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!
The internal cable of your Headphones is broken somewhere ....replace the Headphones
Oct 18, 2008 | SanDisk Sansa c200 MP3 Player
Head phone jack only plays right side/brad new headphones
Call Philips, get replaced - this is a common problem across all mp3 manufacturers. You can look at the YouTube video on repairing mp3 player headphone jacks, but i doubt it will work without causing more problems with your mp3 player.
Aug 21, 2008 | Philips GOGEAR SA6045 MP3 Player
Ipod head phone jack no good
I agree with Solution 5. The copper pins in the jack that make the connection to your headphone plug are bent in such a way that they are springy and will make a good tight connection to the plug. When those copper connections get worn, they are not so springy and they bend inward causing you to lose audio on one side of your headphones unless you wiggle the plug and find that sweet spot that makes a connection. Then you have to hold the wire to keep pressure on it... it gets annoying.
You can open the case and there are slots in the headphone jack that you can get a hook scribe (like the dentists use) or safety pin to bent those copper connections back out. Don't bend them too far or they will break. You can also pick get a new part for $25 or a used part much cheaper. Once you iPod is open, it's a matter of a couple screws and a ribbon cable to replace the jack. Problem solved!
Feb 08, 2008 | Apple iPod MA446LL/A MP3 Player
Music only goes into one side of my headphones
you have a bad head phone jack
http://www.ipodhowtovideo.com/video/videoheadphonereplacement.html
Dec 17, 2007 | Apple iPod MA446LL/A MP3 Player
Open Questions:
SanDisk Sansa c150 MP3 Player Logo
69 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
