I have a Vista III Media box coming through , after a storm I heard a crack out by the area outside my window , where I saw the guy hook something up . Now after that my T.V. has a straight line coming through the middle and then after a few seconds , I have a picture but , it jiggles with lines going across so much that you can hardly see it , a few times it came back to normal , I'm lost at what to do , and would it have anything to do with Vista or is it in my T.V. ? Thank you so much
Thank You so much MikeNJ1964 - I had come to the point where I thought a hammer and chisel would do wonders - lol - Thank You again Pattijo
High FiveThank You so much MikeNJ1964 - I had come to the point where I thought a hammer and chisel would do wonders - lol - Thank You again Pattijo
High Five
You can't post conmments that contain an email address.
The problem has nothing to do with Vista. The solder joints have come loose on your vertical output IC. This is very common in those Panasonic TV's. If you have experience in working on TV's then you can disassemble the set and resolder the pins of the vertical output IC and your picture will be fine. Otherwise, allow a qualified tech to handle it for you. It is a quick and simple procedure and should not cost too much.
Second hand circular saw - look on craig's list - $20
Storm water pipe, use a chain break, not a circular saw, then boot it with a cleanout for the future. But seriously... Call a plumber.
If that then set is a DLP? If the set is full of dust on the fans and in the air channels it may need to be taken outside and a air compressor used to dust it out--will look in some cases like a dust storm so do not do it in the house.
This is common to all old plasmas, the vertical scan module isn't getting enough power.
Long story short - you're going to need to remove the back panel of your plasma tv, turn some knobs, and watch your annoying pixel storm slowly dissipate. What you're looking for are little knobs that control various voltages. Most are these are shaped to be turned with a Philips head, and are sometimes marked with little clicks around them like a clock. If you get a flashlight and look, there's a description printed on the circuit board that tells which voltage that particular knob controls. Almost all of the tv's i've heard of being fixed need to have the VSCAN, or vertical scan adjusted. Make the adjustments in small steps and wait for a result.
Something died in there - perhaps a capacitor or a solid state device just blowing and cracking into pieces. happens. Open up the set and see if you can spot it around the power supply area.
I have exact same problem...other posts have cited improper grounding from the Cable...which makes sense as the problem does not occrr with the DVD...I have not figured out how to fix it though...
i would say take it to your local tv repair shop the screen will have to be replaced or if you told your insurance i happened because of a lighting storm they might have replaced it
pull your carpet up near the leak area and look for muddy body seams. it is possible one of the factory body seams are leaking- possibly in the cowl(under wipers) area, especially if it leaks when the car is sitting. there will be dirt/mud around the seams that are leaking. also you can check door seals by running the car on HIGH DEFROST with all doors and windows closed. spray around with a 50/50 soapy water solution. obviously bubbles will form around your leak.
vista doesn't come with 16 bit, it is 32 or 64 bit. use media center utility for watch live streaming. media player 11 is also capable for playing the live video. realplayer is the best tool for playing live videos
High Five
