SOURCE: TORO Z5000 zero turn mower. right side
it should hold hydralic fluid there should be a resirvour somewhere on the back along with the pump you should be able to check the level there and if you don't get the leak stopped it will lock up the whole drive system.
SOURCE: toro lx 500 deck belt pops off
check for play in the bearings blade bearings and the idler pulleys
SOURCE: blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
SOURCE: i have a craftsman lts1500 riding mower and the blade won't engage
check the cable they break
SOURCE: TORO MOWER MODEL 22168 VIBRATION
Hi, most likely cause is a bearing failed in the pto. Regards Phil.
