Question about First Alert Smoke & Carbon Monoxide Detector
Lifesaver 9co 1
It is chirping slowly and batteries are good. what to do
First, did you write the date on the side? If it's older than seven years, it needs to be thrown out and replaced with a new one, because the chemical that detects CO has been exhausted. If the light that's blinking only occasionally is red, that would be another indication it needs to be thrown out. If the light were yellow a battery change should have fixed the issue. If it did not, give the brandname holder a phone call.
Posted on Aug 18, 2015
Smoke detector chirp 5 times
how old is it if 10 years old replace it other than that replace batteries their weak or defective
Jun 16, 2017 | Power Computers & Internet
Alarm keeps chirping even with battery is replaced?
This could mean that the unit is defective or it may need to be replaced...check the date on the back of the device; if it's over 10 years old it must be replaced by code (NFPA72).
Feb 24, 2015 | Lifesaver Kidde 1275 120Volt9Volt...
Smoke detector keeps chirping after battery is changed, chirps every 30 seconds. chirps come from the ceiling not the device
The chirp means the battery you chose wasn't good enough... it has to be the newest '''alkaline''' you can get hold of. If it isn't alkaline that's why you are having trouble. Upon replacement press the button to do a hard reset.
Aug 11, 2013 | Kidde Home
Replaced smoke alarm battery and also took down from ceiling--still chirping every 30 seconds. Any thoughts?
The chirping is definitely the low battery warning. Are you sure the battery you put in was good? I would definitely double check the battery using a meter.
Jun 26, 2011 | Vacuums
Nighthawk carbon monoxide alarm model KN-COPP-3. ( ERR appears in the window, what does this mean ....
Readings You May See When Unit is AC Powered
Display Shows Alarm Sound Unit Status Recommended Action
Steady "Err" "Chirp" every Unit malfunctioning when Call KIDDE customer
and flashing dot 30 seconds AC powered service at 1-800-880-6788
Readings You May See When Unit is on Temporary Battery Backup
Flashing dot None Normal battery-only operation - Plug in to AC as soon as
unit will show reading only if it possible to conserve battery
senses CO
Flashing dot and "Chirp" every Unit malfunctioning when Call KIDDE customer
"Err" 30 seconds battery powered service at 1-800-880-6788
Hope this helps. Manual is here:
http://www.detectorsandalarms.com/images/pdf/Manual_KN-COPP-3_900-0100en.pdf
If this helps you resolve your problem, please consider giving a good rating and a quick thanks or good job.It will help me as well Thank you.
Oct 26, 2010 | Computers & Internet
What kinf of personal lifesaving appliances are needed for Sail and powered pleasure craft over 9 m and up to 12 m?
The Small Vessel Regulations set out the minimum safety equipment required on board a pleasure craft according to its type and length. In your case these are the personal lifesaving appliances needed:
1. One Canadian-approved personal flotation device or lifejacket of appropriate size for each person on board
2. One buoyant heaving line at least than 15 m (49’3”) long
3. Onelifebuoy attached to a buoyant line at least 15 m (49’3”) long 4.One reboarding device
Aug 12, 2010 | Cabela's Boating
Service tire monitor light is on
is it just a dummy light on the dash or is it more specific like L.F tire low,ect? if its a dummy light then you need to go to a garage with a tire pressure monitor service to to check to see if the batteries in the monitors are still good or if you are just dealing with a leaking tire. If you Tahoe uses wheel speed sensors to monitor tires and pressure you may have a faulty wheel speed sensor or a heads up that your wheel bearing is wearing and the gap between the tone ring and sensor have increase or decreased good luck
Apr 07, 2010 | 2005 Chevrolet Tahoe
A/C chirping noise Camry 1998
If there is chirping noise then some object in the blower motor or the blower is making noise due the frictions b/w the walls of the blower motor unit ,you need to check the blower motor .....
Good luck...
Jan 19, 2009 | 1998 Toyota Camry
Low battery chirping sound: changed battery, but still chirping!!
try a another new battery sometimes they are no good if they where on the store shelf for to long of course the store wont tell you this. if this dosent work replace the unit its better to be safe than sorry
good luck
Dec 10, 2008 | First Alert SA302 Dual System Smoke...
Phone is chirping
Most phones chirp.
1. Low battery........NEEDS a 12 hour or more charge from phone charger.
2. Loosing signal.
3. Electrical interference.
4. Some set communicate with the base for freqency signaling and change channels automatically when interference occurs. The chirp is to autonotify the user.
Most importantly, think about the situation when chirps occur and write it down. At some later date, compare your notes and you'll find your culprit.
Hope this is helpful.
Feb 24, 2008 | Jwin JT-P33 Phone
First Alert Smoke & Carbon Monoxide Detector Logo
644 people viewed this question
Top First Alert Home Experts
JOHN LAPIER
Dan Apthorp
Are you a First Alert Home Expert? Answer questions, earn points and help others
