Not Receive i have not received my intellicard pin yet,how do i get it
MF Digital Scribe 9000 with Picojet disc printer. Hello, could anyone please help with the pin configuration connections of the 9 pin seriel cable to mini din control cable connection from the duplicator...
Have you tried emailing tech support?
http://www.mfdigital.com/techsupport.html
Failing that, and lack of pinout, serial communications can be done with only 4 connections, Transmit and Receive (TX, RX) ground (GND) if you do it with no handshaking. You'll need Data Terminal Ready (DTR) and Data Set Ready (DSR) and or CTS/RTS (Clear/Ready to end). You may have to trial and error it.
Pin 1 - Carrier Detect (CD) - only needed for a modem
Pin 2 - Receive Data (RX) - Cross over with TX
Pin 3 - Transmit Data (TX) - Cross over with RX
Pin 4 - Data Terminal Ready - Cross over with DSR
Pin 5 - Signal Ground (GND) - Goes to other side ground.
Pin 6 - Data Set Ready (DSR) - Cross over with DTR
Pin 7 - Request To Send (RTS) - Cross over with CTS
Pin 8 - Clear To Send (CTS) - Cross over with RTS
Pin 9 - Ring Indicator - Only needed for modem
May 20, 2014 | Computers & Internet
How to wire a mic
This might help as I don't have a color code for the mic. Radio pin code; 1 - Audio -2 - Shield - 3 - Receive - 4 - Sw. Wire -
5 - Transmit
MIKE WIRING GUIDE
Found this by Google searching;
5 Pin Mic Plug Model
Pin #1 Audio Output / White
Pin #2 Shield
Pin #3 Receive / Black
Pin #4 Common / Yellow
Pin #5 Transmit / Red
Feb 01, 2014 | Uniden Bearcat Pro PC68XL 40-Channels Base...
It needs a sim network unlock pin and i dont know it and this problem is preventing me from callin and texting but i can receive calls and messages
Thanks for visiting FixYa!
If you can receive calls but cannot make them, a Network Unlock PIN will not help you to make calls. A Network Unlock PIN only unlocks the phone so it can be used with another cell phone company.
From what you've described, your phone may be security locked. And, you'll need to call your cell phone company to assist you. We cannot provide security unlock codes on FixYa!.
Jun 27, 2011 | Samsung Galaxy S GTI9000 Smartphone
What is the mike wiring on a cherokee 500 to a Astatic 878 dm ?
The Cherokee wires exactly the same as does the Cobra and Galaxy radios that require a receive wire, the true 4 wire not the three wire although the three wire is the same it just does not require the fourth wire to be grounded during receive operation. pin 1 is Shield, Pin 2 is Audi usually white or yellow, Pin 3 is Transmit most times Red, Pin 4 is Receive Back most times
Feb 04, 2010 | Cherokee CBS-500 (40 Channels) 2-Way Radio
Can you tell me the procedure to get the gps data's from receiver to the PC. Receiver Unitraq GT-720F
Check your manual. I'm not familiar with this product but nomally you will be looking for an RS-232 interface. This uses a 9 pin serial cable normally hooked to pins 2, 3 and 5. 5 is the ground and 2 and 3 are send and receive. This may also be called NMEA 0183. TX is transmit and RX is receive followed by a common ground. If you never have done this before I would recommend that you get a trained pro to do it for you. Hooking it up wrong can blow up the port.
Oct 28, 2009 | GPS
I cannot receive any money after battles
In The World Ends With You, you do not receive money after battles. Depending on the Noise you fight, they can drop pins that have money values on them. Go into your pin submenu and drag a pin over to the trash can. It will ask you if you want to sell the pin. Hit yes and the pin will disappear and you will receive money.
Sep 28, 2009 | Square Enix The World Ends With You for DS
Mxit pin
Greetings,
To get your lost MXit Pin, send an SMS containing the word ‘PIN’ to 34006. You will then receive a SMS in return containing your lost PIN.
Please note:
* This only works with cell numbers that are in South Africa.
* Make sure the number you're sending the SMS from is the same number you have registered on MXit.
* Make sure that your message options on your phone are set to sms.
*The sms that you are sending to 34006 must just contain the word pin and nothing else
* If you receive a blank reply from your service provider, this means the number you SMSed from is NOT registered to MXit.
* This SMS costs R2.00
Regards,
MXit_Team
Aug 07, 2009 | Nokia N95 Cellular Phone
I have a Cobra 28 wx nw st and the two ceramic capacitors had cracked on the antenna connections inside. These look to be for the weather part. But i am having a hard time identifying these to replace...
4 pins
pin1 Ground (shield) and the red wire together
Pin 2 Audio white wire
Pin 3 Transmit blue wire
Pin 4 Receive Black receive
enjoy
CB Dave
Trenton Ontario
Jun 29, 2009 | Cobra 29WXNWST (40 Channels) 2-Way Radio
Diesel #8-32 echo power mics
cobra 4 pin is pin1= shield, pin2= mic audio (usually the shield is wrapped around the mic audio wire).pin 3= transmit or push to talk usually red or white whichever isnt wrapped with the shield, and pin4 = receive or speaker complete
5 pin cobra=1-Audio 2- Shield 3-Receive 4-Switching Wire 5-Transmit, you can jump pins 4 and two
Dec 21, 2008 | Magnum 257 CB Radio
15 people viewed this question
 Grubhead
Grubhead
