Question about Linksys Wireless-G Range Expander (WRE54G)
No Power I have a Linksys Wireless-G Range Expander Model WRE54G which seems not to power on. When plugged the Link light comes on very dim and the Activity light doesn't come on at all. What could be causing it?
  • 1 more comment
  • Regel Aug 15, 2007
    I've gone through that but the problem is that the Link green light comes on very dim and the Activity light doesn't turns on al all. This unit was working properly a few days ago.
  • jlight Mar 28, 2008
    Same problem here. I see that the male end of the plug is removable and thought that perhaps this module went bad but i can't find a replacement anywhere.
  • cfaychak Sep 17, 2008
    Received a replacement under warranty and after plugging it can't find internet but says computer is connected.
    Do I need to uninstall the software and reinstall from the CD?
Hello. I have a Linksys Wireless-G Range Expander Model WRE54G which seems not to power on. When plugged the Link light comes on very dim and the Activity light doesn't come on at all. What could be causing it?
Posted on Mar 14, 2008
Same with mine, worked fine after 2 year, suddenly no power, tried several AC outlet, same thing, I almost dump it into the bin, kept plugged for several days and bingo it works again!...
probably leaked capacitor inside?...who knows.
Posted on Jan 17, 2008
    Problem Solver:
  • 8 Answers
Before you plug it in the wall, insert the installation disc and go through their tutorial. When you do that you'll plug in your range expander, press the auto configuration button on the side and wait for both lights to turn up blue. Then you can unplug the range expander and put it else where.
Posted on Aug 14, 2007
SOURCE:
Can my wre54g range expander work with a wireless N router
"Using a Range Expander is not recommended if you have a Linksys Wireless-N Router." This info was found at the bottom of this link under the note.
http://homekb.cisco.com/Cisco2/ukp.aspx?vw=1&docid=afe65b013aea4e1a92424e635a6aa619_17831.xml&pid=102&slnid=3
I found a list of router that it should work with. All the routers listed are G routers though.
http://homekb.cisco.com/Cisco2/ukp.aspx?vw=1&docid=11a933a7173b4f31b43f21dde626becb_1486.xml&pid=102&slnid=3
You should check to see if you router model # is in this list.
Cisco owns Linksys FYI.
Hope this helps you. Even though it says that it is not recommended to use it if you can still try it to see if it works. You can always go back to the way things were.
Aug 27, 2012 | Linksys Wre54g wls g range expander...
What range expander should I use with a Linksys Dual Band Wireless-N Router Model WRT 320N?
For this router you can use the Linksys range expander model WRE54G v3 take not of the version number that is important since the older range expander don;t work on all routers.
Feb 13, 2011 | Linksys WRT320N Wireless Kit
How do use and install the linksys wireless range expander
just plug it in and press the configure button on the side of it, and wait for both lights to turn solid blue, the eithernet port in the front is for connecting a router, or laptop, youknow something that takes an eithernet connection
Dec 28, 2009 | Linksys Wireless-G Range Expander (WRE54G)
Link light on (blue), activity light off (neither blue nor red)
Press the RESET button on the back of the unit and reconfigure the settings.
Sep 11, 2009 | Linksys Wireless-G Range Expander (WRE54G)
Linksys WRE54G WIRELESS 802.11G RANGE EXPANDER Range
The actual max distance of the range expander is about 50 feet, and sorry to say but it cannot bounce the wireless signal from it on a wall....
Jan 25, 2009 | Linksys Wireless-G Range Expander (WRE54G)
Linksys Wireless-G Range Expander WRE54G does not work
Yes you can call Linksys about it if it is under warranty. Warranty is 3 years. Most likely just a configuration problem. Just give Linksys a call and they should be able to get you up and running
Jul 27, 2008 | Computers & Internet
Range expander
back side reset button is there pull out the power cable and put in on that time u have press the reset button on same time. eithere you go the page of linksys configuration there one opiton is there reset or the default settings.
May 26, 2008 | Linksys Wireless-G Range Expander (WRE54G)
Linksys Range Expander...
Initially, it is possible that the WRE54G has not been configured to talk with WiFi AP/Router downstairs and all that is needed is to configure/set it up.
Setup (to be done in the same room where your WiFi AP/Router is installed and preferably with your daughter's laptop which can already connect to your network when it is near):
1. Download the LinkSys WRE54G Setup Wizard from the LinkSys site;
2. Use a LAN cable connection to the WRE54G Ehternet port (located underneath a flip lid in front panel) to one of your daughter's laptop;
3. Power up the LinkSys Expander;
4. Press the Range Expander’s Auto Configuration button for about five seconds. Normally this should be sufficient for the Expander to auto-detect and auto-configure itself;
5. Power off;
6. Move the Expander to your intended place of installation;
7. Again using your daughter's laptop, expand/install the downloaded LinkSys Setup Wizard. Soon as the program is running, follow the on screen instructions. Please don't forget to Save before exiting.
8. Move your daughter's laptop to its intended location and try the system.
Should you still need a User's Guide, it is available here.
Another possibility that we cannot discount is that the WRE54G is also not reaching your router downstairs. Perhaps what can be done is installing it not a floor down from your daughter's but halfway between your daughter's floor and your office downstairs.
Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
Good luck and kind regards.
Nov 16, 2007 | Linksys Wireless-G Range Expander (WRE54G)
Linksys Wireless-G Range Expander (WRE54G) Logo
1,077 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
