Question about Konica Minolta bizhub Office Equipment & Supplies
How to solve error code c2351 in konica-minolta bizhub 164
  • Konica Minolta Master
  • 6,696 Answers
Suction Fan motor failure fan located right side of machine from the front. Check vent can air and remove cover check fan and or replace worse case the board
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Dec 27, 2015
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
SOURCE: Error code C-0211 Konica Minolta Bizhub C-351
I have a Konica bizhub c351 with and error code of c0211. I took the back off and played with the black motor that lifts the tray. The tray moves freely and the motor seems to move freely. When I turn the machine on it does not go through any kind of check like it did before it just goes to the same screen. Is there a way to reset this to get it going again to test if there is still a problem
Posted on Nov 03, 2009
xeerie
  • 347 Answers
SOURCE: REMEDY TO SOLVING ERRORS COF32 AND CO650 IN KONICA
to remove code "COF32" from your machine, simply change the developer with the new one. code will remove.
wish you best of luck............
Posted on Jun 17, 2010
How to solve konica minolta 164 c2351 problem
at the back of the machine TOP. below the document feeder is 4 fans check the filters and check for high dust remove the panel and check all fans!!! remove dust might need a need a new fan
Sep 17, 2017 | Konica Minolta Office Equipment & Supplies
Erro 2351 da bizhub 164
C2351Suction fan motor malfunction
- The fan lock signal remains HIGH for a predetermined continuous period of time while the motor remains stationary.1 Check the connector between FM5-relay CN13-PRCB CN14 for proper connection and correct as necessary. 2 Check the fan for possible overload and correct as necessary. 3 FM5 operation check. 4 Change PRCB.
164
http://printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20164&code=C2351
Sep 11, 2016 | Konica Minolta bizhub Office Equipment &...
Suction Fan motor failure fan located right side of machine from the front. Check vent can air and remove cover check fan and or replace worse case the board that controls it is bad
Dec 21, 2015 | Konica Minolta Office Equipment & Supplies
BIZHUB 164 error M2 what have I to do
replace the drum and developer and then reset the counter
Jul 10, 2014 | Konica Minolta PAGEPRO 1380MF All-In-One...
How to solve error code C2351 in konica minolta bizhub 164
On a bizhub 165 it's a fault with the sucktion fan motor so check
to see if turning and replace if needed. If this does not fix print control board might need replacing.
Jul 03, 2014 | Minolta bizhub 200 All-In-One Printer
Bizhub 164 error code CC153
Have a tech come and re-flash the firmware, and check the NVRAM. Firmware is only available fro secure Konica Minolta Web site they like to keep they software secure. You mite also have a bad control board. Or the memory on the board, a Tech is required.
May 08, 2014 | Konica Minolta bizhub Office Equipment &...
Suction fan motor malfunction power off the on wait ten seconds between. check all the vents on the machine remove the covers where they are located and power on the machine check to see if they turn use can air to clean or get them replaced.
Apr 30, 2013 | Minolta bizhub 200 All-In-One Printer
How do I clear error message C-2558 for the Konica Minolta bizhub C253
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Nov 12, 2009 | Konica Minolta bizhub C250 All-In-One...
618 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
