Question about Garden
Devilbiss Manual Just purchased at garage sale ,would like instruction manual or specs, it has a 1/3 hp motor at 1435rpm and 2.7 amps it is orange in colour with the words "tuffy" and then the name Arnold De vilbiss , cannot seem to find any thing else about this unit, Regards Clint Boys
SOURCE: Instruction Manual
I had the same problem. If you are in Australia, the Dimplex Customer Service number is 1300 6739 033. I phoned and they are mailing me the instructions. Maybe don't say you bought the machine at a garage sale.
If you are not in Australia, try the way I did to get your local customer service number - Google the product number and go to the Dimplex website, and there should be a "Contact Us' button with a phone number or mailing address.
Pat
Posted on Jun 23, 2008
  • 3 Answers
SOURCE: Where can I find an instruction manual for this popcorn popper?
Go to http://www.nostalgiaelectrics.com/ and click on their customer support link.  At the bottom of their customer support page there is a box to enter the model number of your popcorn popper to get a manual.
Posted on Oct 07, 2008
SOURCE: Instruction/User Manual
I just took over a position as Activiyies Director for a community association. Found the popcorn popper in the closet, no maual of course, I just cleaned it up, added kernals to metal cup & plugged it in. Within 3 minutes I had a huge bowl of fresh popcorn for the kids to enjoy. They love watching it pop. Only problem is finding the perfect way to season. Any suggestions???
Posted on Feb 22, 2009
SOURCE: Changing the cutting blades on a mantis Chip Mate
The Mantis Chip Mate was actually made by a Swiss company called Stoeckler, under the model name Bio-Shredder LGM-600. Neither Mantis nor Stoeckler seem to have service parts or info on these models. Given the blade material the edge did last long and would dull out quickly on hardwood material - best to attack only pencil diameter material or soft material. The manual is of limited use but boiled down you have the following info:
STEP 1 UNPLUG IT! (Seems silly to say but just in case someone of less mechanical inclination reads this.......) Also being made in Europe, all the fasteners are Metric, not SAE/Inch.
The motor/drum assembly must be removed from the chute housing to get to the blades (7 - 5mm allen head bolts holds the drum inside the chute housing). A "T" handle hex wrench a minimum of 6" long will work to access some of the tigher clearance areas. Use a WIDE Large blade screwdriver the help separate the drum halves if they don't come apart too easily. The drum is the motor so it will stay with the smaller plastic housing part - DO NOT force the drum off the small housing part.
A 10mm open end wrench is needed to turn the bolts into the wedge/blade assembly on the drum (ie. turn the bolt head so it screws IN) to loosen the wedge assembly until the blade and wedge can be removed from the drum.
The blade goes back in the wedge blocks so the the bottom of the blade rests against the wedge and not the drum (ie the sharp edge against the wedge not the drum). Make sure the holes in the blade fit over the bumps in the wedge.
You'll next need to remove the counterknife inside the chute house and make sure the edges therer are sharp (you can flip the part around to use any of the 4 edges and bolt it back in or file them sharp and reinstall into the chute housing, BUT LEAVE IT LOOSE.
You need to adjust this counterknife distance from the drum knives. You'll need a 3.5" wide or so piece of shim stock that is 0.3mm thick. Put the drum/knife assembly back in the chute housing and rotate the drum around until one of the drum knives is under the counterknife. Insert the 0.3mm shim stock between the drum knife and counterknife. Push the counterknife down and tighten the 2 bolts that hold it in the chute. Pull the shim out, rotate the drum to the other drum knife and check for clearance to the counterknife. As long as it rotates by and does not hit you should be ok, but if they are really close, re-adjust the counterknife for 0.3mm clearance to the highest knife. Make sure the gap does not exceed 0.5mm or the unit will not chip/shred properly.
Put everything back together and make sure the bolts are tight!
Should be good to go. Given the blades don't seem to be of any particulary great hardness, I would feed material slow and easy and avoid any hardwood material over 1/2" in diameter. If you need new blades you need to search around to see what can be ground down to fit. Find yourself a person who really knows how to sharpen blades and they should be able to cut something down to fit.
Good luck.
Posted on Apr 26, 2009
smartr10U
  • 1305 Answers
SOURCE: need a manual
here is the Tuffy webpage at the troybuilt.com... directly under the photo of the tiller is a gray "download manual" link...
best wishes,
k
Posted on May 28, 2009
Manual for mastercraft garage opener 046-0266-0
Try Googling (mastercraft)(046-0266-0)(manual) without parens.
Dec 12, 2016 | Building Materials
Don't know Mod. No. lost installation manual, approx. 5 yrs. old Need installation manual.
About 496,000 results (0.43 seconds) Search Results
    [PDF]GARAGE DOOR OPENER Model 3265 1/2 HP ... - LiftMaster
    www.liftmaster.com/.../en.../tucmanuals/114a3044.pdf Chamberlain GroupFasten the manual near the garage door after installation. .... This garage door openerhas been designed and tested to offer safe service provided it is installed, ...
    Manuals Download Craftsman Garage Door Opener Model ...
    www.craftsman.com/search=manuals%20download%20crafts...
    CraftsmanCraftsman has the best selection of Garage Door Openers in stock. Get the Garage Door Openers you want from the brands you love today at Craftsman.
    Craftsman 1/2 HP Chain Drive Garage Door Opener - Sears
    www.craftsman.com > ... > Garage Door Openers
    Craftsman1/2 hp Chain Drive Garage Door Opener Opens by Remote, Inside and from Car Enjoy a great end to every day by ... Owners manual - English (Warranty).
    Free Craftsman Garage Door Opener User Manuals ...
Feb 03, 2016 | Building Materials
Need a manual for sears model 139.18856, 1/2
According to Sears your model number is bad. Double check the number and they will have the owners manual with complete installation instructions.
Sep 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Replacing new AOSSQ1152
What's the source of the info that the two orange wires are Low & High?
Orange is an unusual color, but I'd say, with 99.999% certainty, that if you put a voltmeter across the two orange wires, it'll read 220 volts (nominal).
The two orange and one white lead give you the ability to run @ 110 volts -- there will be 110 volts between one orange and white and also the other orange and white.
For this motor you only need the two orange wires which will give you 220 volts between the two. Cap off the neutral/white wire (not needed) & connect the two orange wires, one to L1 and one to L2 on the motor (L = Line). And don't forget to connect the ground...
Charlie
P.S. You should also have a GFCI on this circuit.
Sep 11, 2009 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
HOW TO THREAD THE TINY TAILOR
check this site out for a mnual Singer_ TINY-TAILOR-TT600-TT600A Manual - Only $5.00 for the ...A Handbook for your Singer_ TINY-TAILOR-TT600-TT600A Sewing Machine ... Download the TINY-TAILOR-TT600-TT600A Singer_ sewing machine manual: ...
http://gotoes.org/sales/Singer_SewingMachineManuals/ViewInfo.pl?Singer_=1&Sewing_Machine_Model=TINY-TAILOR-TT600-TT600A
Aug 28, 2009 | Singer Tiny Tailor TT700
Need owners manual for devilbiss pro 4000 air compressor
Craftsman compressors are model numbers starting with a 919.xxxxxx Find this number and look it up on searspartsdirect.com. Some manuals are available for viewing without purchase.
Eric
Jul 30, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman Garage Opener (Unit run front & back only for 2 second)
Double check to make sure the sensors are wired correctly. The 2 solid white wires go to terminal 2 and the wires with black stripes go to terminal 3. If the wiring is correct then you possibly have a bad RPM sensor. The RPM sensor is a small circuit board just in front of the motor.
Jul 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
