Question about Microsoft Xbox 360 Console
Av cable hey i just bought a new 360 and my av cable doesnt stay in the back of it so ever time i turn it on i will either have to wiggle it of take it out then put it back in wat should i do plz help thanks
  • phe burr Aug 08, 2007
    should i just trade the bad one in and get another one?
Send it back to xbox and 2-3 weeks for another
Posted on Aug 08, 2007
E 74 error message on my xbox 360
thats because that error message means your AV cable has died or the chip inside has cooked, if the error goes away wen you remove the cable its the cable you need to purchase a new one
Oct 26, 2009 | Microsoft Xbox 360 Console
New xbox 360 arcade no screen or sound
to start off,what type of cable are you using??
since you've already tried using 2diff TVs,basically its with the console
try using a different AV CABLES, if it still doesnt work,try calling xbox support hotline for possible replacement of your cable or for processing a repair for the xbox if necessary..
since you just bought your console,try going back to the store where you bought it and have it replaced, because for the repalcement of the cable if you call xbox support,it will take 8-12business days for toureceive it and 2-3weeks for the turn around time of the repair for the xbox.
May 17, 2009 | Microsoft Xbox 360 Console
Picture will not show
You might want to try the following:
1. make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV
2. make sure that you have the correct AV cable for your TV, to verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, disconnect the AV cable and then reconnect the AV cable to both devices
3. if you are using composite cables, do not try to set any HDTV settings because you may lose the picture
4. make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
Example:
- if your Xbox 360 console is an NTSC console, make sure that your TV supports NTSC
- if your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- if your TV has a type of picture compensation enabled, disable it
5. reset your Xbox 360 console
- Remove any discs from the disc tray
- Turn off the console
- Turn on the console
- As the console starts, press and hold the Y button, and then pull the right trigger at the same time
- The Xbox Dashboard resets the display settings to the default settings and then automatically restarts the console.
6. Do not take your Xbox 360 console or its accessories to your retailer for repair or for service unless an Xbox Customer Support representative asks you to do this
Mar 09, 2009 | Microsoft Xbox 360 Console
I would reccomend checking both the TV's input jacks and the Xbox's output slot. If you got a new AV cable, then the odds that that cable are faulty are slim.
Try your new AV cord on a friends 360 if you have a friend with one. See if it works.
I found a microsoft troubleshooting Web Article that may help you solve your problem.
http://support.microsoft.com/kb/909335
Re-post and tell me how it works out or if you need more help.
Hope this helped,
- Josh
Oct 23, 2008 | Microsoft Video Game Consoles & Games
Video has white lines that roll on screen.
cheak video output 480 reg tv 720 p mid quilty lcd plamasa or full 1080 p only on hi end lcd tvs ect ok
Oct 06, 2008 | Sony Playstation 3 (PS3) Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Xbox 360 e74
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
Try the cable swap if that works then great buy yourself a new cable and bam your set if that doesnt work then you need to contact MS or use a replacement plan. cuz your GPU is fried.
Dec 27, 2007 | Microsoft Xbox 360 Console
Sound works but no image
This means the AV cable is not detected, try one of these...
1. Make sure that the AV cable is correctly connected to the Xbox 360 console.
2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
If this is helpful at all, please rate, thanks!
Nov 24, 2007 | Microsoft Xbox 360 Console
Xbox 360
Hi, I hope something from below is useful to you...
Sections 1, 2, 3, and 4 are flashing red
- The AV cable cannot be detected
If this is helpful in any way, please rate! Thanks
Black screen with 'system error E74' written on it
Ok this is what i have found out The Bottom Right Red light Flashing is
1022 AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
try getting a new av cable should do the trick and i know this post is old But it should help people who are having this problem
There Is a bit more info
Nov 08, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
12 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
