Question about Yamaha CM500 Headset
Headset use with Heil adapter for Icom Transceiver
Can I use the Headset with a Heil adapter cable (AD-1-IC) on a Icom 746-PRO Ham Radio Transceiver
Why have i lost most of my receive signal on my ic 746 txr,i may have pushed a few wrong buttons. thanks.
Check your pre-amplifier settings. There is a button along the bottom edge below the display, or possibly in the menu section, I don't remember now. The button will switch in attenuators and amplifiers.
Another item might be your RG Gain control, although this doesn't cause any beeps when used. It is easy to inadvertantly turn, reducing your received signal to almost zero.
Sep 26, 2016 | Icom IC-746 Transceiver
How come my icom 756 pro did not transmitting on 8000 frequency
You have to modify this radio to operate outside of the HAM bands. You will likely find the modification at www.mods.dk. This is a pretty common and easy modification for HAM radios. Your performance may not be as good as in the HAM bands.
You do this MOD at your own risk. If you are not licensed for operation on ANY frequency or band, you are not legally allowed to transmit. Heavy fines may be levied against you.
Jul 14, 2016 | Icom IC-756PRO Transceiver 002896
Cannot transmitt
The Icom 756 Pro is a very expensive radio. If you bought one and it's not transmitting I really recommend taking it back. It could be anything from the mic, power supply, final transistors, board, anything really. It's going to need to be scoped and looked at in person.
Jun 30, 2016 | Icom Transceiver Ic-756proii
I have a IC-756pro and the cat system won't work? Is it something easy to fix or only the factery
Icom radios are particularly problematic for HRD. I would urge you to read the instructions here. http://www.ham-radio-deluxe.com/hrdrigcontrol.pdf There are special instructions for Icom radios.
Dec 09, 2014 | Icom Ic-756pro Hf Transceiver Service...
Icom programming
I looked up ICOM 2710 on the icomamerica.com web site and found ICOM IC-2710H which is a ham radio transceiver.
Jul 14, 2014 | Radio Communications
Heil icm plug wiring diagram
The Heil "ICM" microphone is designed to be used with certain Icom brand ham radios. These have a 8-pin round plug. Describing the pinout to you will depend upon your perspective, whether you are looking at it from the microphone plug itself, or the microphone socket on the front of the radio. Therefore, from the perspective of looking at the mic plug on the end of the mic cable, note that there is a notch or dimple in the plug that also lines up with the screw. Going clockwise from the notch, the pins are numbered 1 thru 7. Pin #8 is the center pin.
Pin 1 = mic input
Pin 5 = Push-to-talk (PTT)
Pin 6 = PTT ground
Pin 7= Mic ground
From the standpoint of an Icom transceiver, the remainder of the mic connector pins are as follows:
pin 2 = +8 volts DC (output from the radio)
pin 3 = frequency control up/down
pin 4 = squelch switch
pin 8 = audio output (level varies w/vol control)
Hope this helps
Jan 03, 2014 | Heil Sound Audio Players & Recorders
Rx error on a210
replace the riben cable from head unit to main board,£2 from icom uk. regards gw0dxo
Jan 16, 2013 | Icom IC-A210 VHF Airband Transceiver
Can someone provide a wiring diagram for the
hello, my name is paul and wondering if you can help me with a wiring diagram of cool talk throat mic icom earpiece, hope to hear from you soon .
kind regards
paul
Dec 05, 2009 | ICOM Informatique IC-A23 VHF NAV/COM Air...
Radio Communications Logo
63 people viewed this question
Top Yamaha Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Yamaha Radio Communication Expert? Answer questions, earn points and help others
