Question about Husqvarna Garden
Idles but no power - Husqvarna Garden
  • Husqvarna Master
  • 7,482 Answers
Hi Sean
Posted on May 01, 2013
1999 audi quattro no power idles up and down and will not idle on its own
You need to have a fault code test run, that is the first step in diagnosis and repair
Sep 21, 2016 | Audi Cars & Trucks
High idle mercedes E350 2010 when i turn heater on leave heater off and car will idle at 550rpm
thats because the electrical system is using more power than the alternator supplies at idle so the ECU increases idle so that all electrical systems i.e fuel delivery etc have enough power supplied absolutely normal
Apr 02, 2014 | Mercedes-Benz Cars & Trucks
Idle up and down not good power
which engine, there are many opted engine, name one.
did you say the engine lacks power? under what conditions.
Parked
moving.
hills,
wideopen throttle weak?
what?
btw : no idle works right if the engine runs bad.
lean fuel the ISC cant control idle ,
same for misifire.
idle is the last thing to work right in EFI.
is engine misfiring, and if so did it before the tune up or after./?
Jan 27, 2014 | 1997 Jeep Grand Cherokee
My Makita G5500r power generator doesn't have smooth Idle?
sounds like the carb needs to be cleaned inside any fuel the was left in the carb goes bad and it never runs it all out
Sep 06, 2012 | Electrical Supplies
Got a 99 Nissan Altima 2.4, t-chain broke... replaced head and all t-components... start up surging idle and whistling off idle... engine runs smooth and great power off idle
the surging and whistling sounds like there might be a vacuum leak that is causing this.recheck all vacuum lines and surfaces were this is a gasket that seals a vacuum source.smooth running and good power off idle suggest this leak only affects the motor at a low(idle)rpm.
Apr 14, 2011 | 2005 Nissan Altima
Power steering hard to turn at idle only on 2000 chrysler lhs.power steering rack and pinion and pump already replaced.
start with checking your tire pressure if thats ok check the belt for proper tension and fluid level and last that your idle speed is set correctly while the vehicle is idle in drive not idle in park hope this helps.
Jan 03, 2011 | Chrysler LHS Cars & Trucks
My 323 starts buts wont idle, it will run if you pick up the revs but once you let go of the accelerator it dies. please help
if its carby engine has the idle solenoid stopped working or lost power very common
single wire soleniod can be checked for power with test light
power=ign. on/run
no power=off/no idle
or has some one adjusted carby settings?
Feb 20, 2010 | 1984 Mazda B-Series
Idle Problem
man it's normal that when u turn on the A/C then the idle will drop and but it will turn off cause the A/C load and the other accesories consume higher power than the power from idle so u need to less the load applied on the engine by turning off any auxiliary electronics when u want to use the A/C like xenon lights but if u only turn hte A/C and u have this problem then u need to increase the idle to prevent turning off of the engine
Jun 29, 2009 | 1995 Honda Civic
Does not automatically idle up when demand for power
Check your idle solenoid by applying 12Vdc. If it moves then the solenoid is fine. This means you will need the idle control board, or in most cases the idle board might be integrated with the main control board, which means that the main control board will have to be replaced.
Apr 09, 2009 | Northstar Generator 20 Hp, 13,000 Watt,...
Rough idle / engine surges until power is applied
Sounds like a possible vaccume hose leak?
Feb 07, 2009 | 1997 Chevrolet Astro
Garden Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
