Question about Panasonic KX TG4021 Cordless Phone
Time set
I set the time correctly, but after 24 hours, the EST changes to pacific time(3 hours difference). How to solve this problem?
Trouble with precisetime atomic wall clock several hours behind
Check the time zone setting for your local time zone. If you are Eastern Time Zone but setting is for Pacific Time Zone, then the difference will be several hours. Check your manual for proper setting.
Mar 02, 2015 | Home
How do I set the time zone? It run out of battery so when I changed it, the time zone is pacific and I need to change it to mountain time.
To change the time zone, open the control compartment cover on the bottom of the clock. Locate the "Time Zone" switch and set it to the appropriate time zone for your area. Six time zones are programmed into your clock, "A" for Atlantic, "E" for Eastern, "C" for Central, "M" for Mountain, "P" for Pacific and "H" for Hawaiian. Once you've chosen the correct time zone for your Brookstone digital desk clock, you must select whether you want the clock to operate using the 12-hour or 24-hour format. The clock is set to the 12-hour format by default. If you'd like to change the setting to the 24-hour format, locate the "Time Format" switch on the bottom of the clock and flip it to "24-hour".
You can also decide whether to turn your clock's automatic Daylight Savings Time feature on or off. If you turn the feature on, your clock will automatically move forward by one hour at 2:00 a.m. on the first Sunday in March and fall back by one hour at 2:00 a.m. on the first Sunday in November. To choose your preference, locate the "DST" switch on the bottom of the clock and flip it to "Autoicon1.png" or "Off".
Read more: http://www.ehow.com/way_5585650_brookstone-digital-desk-clock-instructions.html#ixzz2phA7kQ1b
Jan 07, 2014 | Brookstone Self-Setting Atomic LCD Clock
I have a clock that will only come up as pacific time zone time. I am in central time zone in the usa. How can I correct this as it does not allow me to input any time changes manually? I have tried...
1. press "MODE" (it will show the alarm time)
2. press "ADJUST" (this will switch the time zones)
3. when it is on the desired time zone, press "MODE" to return to the clock.
Mar 15, 2011 | Audio Players & Recorders
Model 31981B Replaced AAA battery's and now it is 3 hours behind
PROGRAM MENU: b> TIME ZONE: Use a pencil or paperclip togently press and release the TIME ZONE button one time. Press and release the PLUS button to choosefrom: PST= Pacific Time MST= Mountain Time CST= Central Time EST= Eastern Time Press and release the SET button to return to a normaldisplay. DAYLIGHT SAVING INDICATOR: The DST indicator isdefaulted to the ON position. If your area does not observe DST please removethe battery cover on the back of the station and move the DST switch to the OFFposition. SET CALENDAR, TIME, 12/24HR & F/C: Press and release the SET button once toenter the program menu. NOTE:Holding a button will move the digits faster. YEAR: The Year will be flashing. Use the PLUS or MINUSbutton to set the Year. Press and release the SET button one time. MONTH/DATE: The Month and Date will beflashing. Use the PLUS or MINUS button to set the Month and Date. Press andrelease the SET button one time. HOUR/MINUTES: The Hour and Minutes will beflashing. Use the PLUS or MINUS button to set the Hour and Minutes. Press andrelease the SET button one time. 12/24-HOUR TIME: 12Hr will be flashing. Use thePLUS or MINUS button to switch to 24-Hour time. Press and release the SETbutton one time. FAHRENHEIT/CELSIUS: The Temperature will beflashing. Use the PLUS or MINUS button to switch from F to C.
Dec 06, 2010 | Equity Time USA Sky Scan 44100 Clock Radio
Sentry self setting atomic clock lost the instructions
Select The Time Zone - For Sentry Self-setting Atomic Clock (ATC - 10)
The default time zone is Pacific zone.
1. In the normal time mode, press the MODE key to enter the alarm time mode.
2. Press the SET key to change the time zone.
each press of the SET key will move the time zone back one hour
P= Pacific M=Mountain C=Central E=Eastern
3. Press MODE key when correct Time Zone is highlighted.
I think the Instructions may tell you to use the ADJUST key instead of the SET key.
ADJUST key does not work for TIME ZONE change, SET key works.
This will set your clock to your chosen Time Zone for normal time.
Instructions for the ATC20 are located at the following url
http://www.sentryindustries.com/pdf/instructions/ATC20_instructions.pdf
Sep 28, 2010 | Office Equipment & Supplies
How do I reset the time when I move into a different time zone
mcdevito75 here, You re-set the time in a different time zone the same way as you do for the time zone your in now. The different time zones in the USA ru from 1 to 3 hours before the time in the Eastern part of the USA, example, Eastern time 3 PM, then going West, you have Central time 1 hour before, then Mountain time, 2 hours before , then Pacific time 3 hours before eastern time.
Aug 10, 2010 | Timex Automatic Watch
Timex 1440 time from 24 hour clock to 12 hour
Hi bowingman,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Oct 09, 2009 | Timex 1440 Nylon watch
How do I reset my skyscan 86715 atomic clock?
SkyScan 86715:
>Press "SET" once,
>>press "+" until you see your time zone;
-4 ATL-Atlantic
-5 EST-Eastern
-6 CST-Central
-7 MST-Mountain
-8 PST-Pacific
-9 ALA-Alaska
-10
-11
-12
-6MT-?
>Press "SET" once,
DST ON/Off
>Press "SET" once,
US - duh, huh
F - MER-Mercredi, French
E - MIE-Miércoles, Spanish
>Press "SET" once,
>>press "+", for correct hour
>Press "SET" once,
>>press "+", for correct minute
>Press "SET" once,
Range 00-20; 09 = 2009
>Press "SET" once,
Month
>Press "SET" once,
Day
>Press "SET" once,
Day of the Week
>Press "SET" once,
12 or 24 hour
>Press "SET" once,
Fahrenheit or Celsius
>Press "SET" once again - DONE!!!
The clock should now display "month/day/day of the week/moon phase/Temperature"
NOTE: Moon phase and Seconds will correct on first reception from Coordinated Universal Time (UTC)
Lastly,
Press "+" once,
Temperature changes to seconds
>>Press "+" once,
Temperature returns on right-most panel and
seconds replaces day of the week.
>>Press "+" one last time and you are back to done!!!
Thanks,
peppermyers@yahoo.com
Apr 02, 2009 | La Crosse Radio Controlled Atomic Clock
Change time zone Dect 6.0 Dual handset
Singerjaxfl, I used to have the same problem with my Vtech DECT 6.0 phone. I solved it by changing the system time on my VOIP Adapter.
In order to do that, you need to (1) know the IP address of your VOIP Adapter (the manual should have it, or ask its manufacturer), and (2) have the Admin authority (again, the manual or manufacturer) to change system time.
Mar 16, 2009 | Vtech DECT 6.0 Cordless Phone with Digital...
Time on Outlook Express is wrong
I solved the time problem when I realized that the computer thought I was on Pacific coast time. I found the setting to move to east coast time. I then reset the clock to my correct EST, and everything is good now.
Sep 28, 2008 | Microsoft Office Professional 2007 Full...
Panasonic KX TG4021 Cordless Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
