Question about GMC Denali 700C Road Bike
Where do you to install frame pump?
The only place where I find 2 screw holes is where the water bottle is mounted. I don't want to remove the bottle. Could the holes on the down frame be hidden by the sticker?
  • David Bernier May 05, 2013
    Ok, I don't understand. When I replace the water bottle with the frame pump, I'll use the only 2 holes on the frame. Where do I find more holes for the water bottle to mount to the frame?
    New Friend:
Thats were they go ,is and unscrew / screw back up .take water bottle cage out ,put the bracket for the pump,in top put your water cage ,put bolts back in , secure it and u should be good.the only reason you shouldn't be able to fit it ,is because is not for a bicycle .
Posted on May 01, 2013
How do you attach a water bottle holder. I don't see any indention's for the screws on the frame.
if there are no screw holes in the frame You need to get two clamps that go around the frame and they will hold the holder in place...available at any bike shop.They usually come with the water bottle
Aug 27, 2013 | Mongoose Domain Dual Suspension Mountain...
How do i change a waterpump on a 2001Volkswagen cabrio?
Your Cabrio has one of several 2.0L Volkswagen engines - determine your engine type from the
8th digit of your VIN, which will be either an "A", or "C",both are 2.0L engines.
Volkswagen 2.0L engines offered in 2001:
(a) 2.0L (Aba) Engine
(b) 2.0L (Aeg/Avh/Azg/Bdc/Bev/Bgd) Engine
(c) 2.0L (Aeg/Avh/Azg/Bdf) Engine
For completeness, I've included the water pump maintenance manual entries for all (3) 2.0L VW
engines offered in 2001. Note that the instructions below include (3) illustrations, which are
reproduced faithfully from the manual, but the last (2) illustrations are identical, since the last two
engines in the list above are virtually identical.
Volkswagen 2001 engines - water pump replacement
2.0L (Aba) Engine
Before servicing the vehicle, refer to the Precautions section.
Remove or disconnect:
1. Coolant
2. Thermostat housing from under the water pump housing.
Loosen but don't remove the bolts holding the pulley to the water pump.
Timing belt cover.
Alternator and/or steering pump as required to remove the water pump drive belt.
Water pump pulley. On some vehicles, the crankshaft pulley must also be removed by removing the bolts holding the pulley to the timing belt sprocket.
Water pump from its housing.
To install:
Be sure to clean the housing before installing the new gasket. Install the pump into the housing. Pump-to-housing bolts: 84 inch lbs. (10 Nm).
Install the water pump drive pulley. Bolts: 15 ft. lbs. (20 Nm). Install crankshaft drive pulley. Bolts: 15 ft. lbs. (20 Nm).
Adjust drive belt tension and install the thermostat and housing. Bolts: 84 inch lbs. (10 Nm).
Fig. Water pump and thermostat housing-2.0L (ABA) engine
1. Before servicing the vehicle, refer to the Precautions Section.
2. Remove or disconnect:
Coolant
3. Loosen but don't remove the bolts holding the pulley to the water pump.
4. Remove or disconnect:
Timing belt cover.
Water pump from its housing. Refer to figure of ABA engine's water pump above.
To install:
1. Be sure to clean the housing before installing the new gasket. Install the pump into the housing. Pump-to-housing bolts: 84 inch lbs. (10 Nm).
2. Install the water pump drive pulley. Bolts: 15 ft. lbs. (20 Nm). Install crankshaft drive pulley. Bolts: 15 ft. lbs. (20 Nm).
3. Adjust drive belt tension and install the thermostat and housing. Bolts: 84 inch lbs. (10 Nm).
Negative battery cable.
Coolant.
Accessory drive belt and tensioner.
Upper and center timing belt covers.
3. Position the engine so that the No. 1 cylinder is at TDC.
WARNING
Cover the timing belt to protect it from being contaminated with coolant.
4. Loosen the timing belt tension and slide the belt off the water pump sprocket.
5. Remove or disconnect:
Timing belt guard (2) mounting bolt (1), if equipped.
Water pump mounting bolts (5), then the water pump (4).
O-ring (3) and clean the seating area.
To install:
Fig. Exploded view of the water pump mounting-2.0L (AEG/AVH/AZG/BDF) engine
1. Install or connect:
O-ring, moistened with coolant.
Water pump so that the plug in the housing faces downward. Mounting bolts: 11 ft. lbs. (15 Nm).
Timing belt guard, if equipped. Mounting bolt: 15 ft. lbs. (20 Nm).
Timing belt.
Accessory drive belt tensioner. Mounting bolt: 18 ft. lbs. (25 Nm).
Accessory drive belt.
Coolant.
2. Check and clear any DTCs, then match the ECM to the TCM.
1. Before servicing the vehicle, refer to the Precautions section.
1. Negative battery cable.
2. Coolant.
3. Accessory drive belt and tensioner.
4. Upper and center timing belt covers.
WARNING
1. Timing belt guard (2) mounting bolt (1).
2. Water pump mounting bolts (5), then the water pump (4).
3. O-ring (3) and clean the seating area.
To install:
Install or connect:
1. O-ring, moistened with coolant.
2. Water pump so that the plug in the housing faces downward. Mounting bolts: 11 ft. lbs. (15 Nm).
3. Timing belt guard. Mounting bolt: 15 ft. lbs. (20 Nm).
4. Timing belt.
5. Upper and center timing belt covers.
6. Accessory drive belt tensioner. Mounting bolt: 18 ft. lbs. (25 Nm).
7. Accessory drive belt.
8. Coolant.
9. Negative battery cable.
Sep 13, 2011 | 2001 Volkswagen Cabrio
I have no clue on how to replace water pump on a 1995 chrysler cirrus 2.5L. I have to do this myself I dont have the money for a garage.
This is found on the autozone.com website.
2.5L Engine
See Figures 3 through 7
  1. Disconnect the negative battery cable.
  2. Place a large drain pan under the radiator drain plug. Drain and properly contain the engine coolant.
This procedure requires removing the engine timing belt and the auto tensioner. To help assure proper alignment at assembly, it may be helpful to set the engine at TDC on No. 1 compression stroke. This should align all timing marks on the crankshaft sprocket and both camshaft sprockets.
  1. Remove the accessory drive belts and crankshaft damper.
  2. Remove the right engine mount. This requires safely supporting the engine with a floor jack and wood block so the mount can be removed.
  3. Remove the timing belt covers.
  4. Remove the timing belt and tensioner.
Fig. Fig. 3: Remove the water pump mounting bolts
Fig. Fig. 4: Pull the water pump assembly off of the engine and inlet pipe
Fig. Fig. 5: Open the water pump housing and examine for cracks or damage
Fig. Fig. 6: Replace the water pump housing gasket using a scraper tool
Fig. Fig. 7: Always keep the water pump's mounting bolts lined up with their correct mounting holes
  1. Remove the water pump mounting bolts.
  2. Separate the water pump from the water inlet pipe and remove the pump.
To install:
  1. Thoroughly clean all sealing surfaces. Inspect the pump for damage or cracks, signs of coolant leakage at the vent, and excessive looseness or rough turning bearings. Any problems require a new pump.
  2. Install a new O-ring on the water inlet pipe. Wet the O-ring with water to make installation easier. DO NOT use oil or grease on the O-ring.
  3. Install a new gasket on the water pump and fit the pump inlet opening over the water pipe. Press the assembly together to force the pipe into the water pump.
  4. Install the water pump-to-engine bolts and tighten to 20 ft. lbs. (27 Nm).
  5. Install the timing belt and timing belt tensioner. Set the timing belt tension.
  6. Install the timing belt covers. Install the right engine mount. Remove the floor jack and engine block from underneath the engine.
  7. Install the crankshaft damper.
  8. Install the accessory drive belts and set to the proper tension.
  9. Connect the negative battery cable.
  10. Fill and bleed the engine cooling system.
  11. Start the engine and verify proper operation, with no leaks
Aug 20, 2011 | 1995 Chrysler Cirrus
Trying to R & R the serpentine belt on a 1999 Olds Delta 88. The belt is routed arond a motor mount. Do I have to jack the motor and disconnect it from the motor mount in order to remove and replace...
yes you do. place a floor jack under engine with a block of wood on top of jack to protect the engine, put just enough pressure on jack to steady engine. remove motor mount, then jack up engine a bit to take belt off. replace the belt then lower jack and attach the mount. on the mount only the outside bolts need to come off to raise engine. do not remove from engine side unless you are changing it or its bad, be carefull when raising engine, pick it up from a sturdy place, not the oil pan. have a good day !!
Jun 07, 2011 | Oldsmobile Delta 88 Cars & Trucks
How do you install a drink cage and a basket ?
Installation of water bottle holder is simple. It usually mounts using the two screws on the top of the tube leading to the pedals of the frame. Remove these screws from the frame using a 4mm or 5mm allen wrench, place the holder over these holes, and rescrew in the bolts.
Installation of the basket is dependent on the model and location of the basket. However, all will mount to the frame(in the back) or fork of the bike on bosses.
Mar 15, 2011 | Schwinn 26in Women's Mirada Bicycle
Replace water pump 1995 aurora
Water Pump REMOVAL & INSTALLATION 3.5L Engine
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Partially drain the cooling system.
  3. Remove or disconnect the following:
    • Water pump pulley bolts, loosen but do not remove at this time
    • Drive belt
    • Idler pulley
    • Water pump pulley
    NOTE: The water pump is attached to the engine with both long and short bolts, be sure to note their locations.
    • Water pump and discard the gasket
    NOTE: Note the locations of the 5 long bolts.
  4. Clean the water pump mounting surface. Fig. 1: Be sure to install the 5 long water pump bolts in the correct locations - 3.5L engine 9300z502.gif
    Fig. 2: Water pump mounting - 3.5L engine 9300z503.gif
    To install: NOTE: Be sure to install the 5 long bolts in the proper locations.
  5. Install or connect the following:
    • Water pump using a new gasket. Torque the bolts to 124 inch lbs. (14 Nm).
    • Water pump pulley
    • Idler pulley. Torque the bolt to 37 ft. lbs. (50 Nm).
    • Drive belt
  6. Refill the cooling system.
  7. Start the engine and check for leaks.
3.8L Engines
  2. Disconnect the negative battery cable.
  3. Drain the cooling system.
  4. Remove or disconnect the following:
    • Serpentine belt
    • Heater and bypass hoses from the water pump
    • Water pump pulley
    NOTE: The long bolt can be removed by aligning the bolt head with the frame rail hole.
  5. Install an engine support fixture.
  6. Remove or disconnect the following:
    • Torque axis mount
    To install: Fig. 3: Exploded view of the water pump and mounting bolt locations - 3.8L engines 7922xg01.gif
  7. Thoroughly clean all the sealing surfaces.
  8. Apply a thin bead of sealer around the outside edge of the water pump
  9. Install or connect the following:
    • New gasket
    • Water pump. Torque the inlet and outlet side bolts to 29 ft. lbs. (39 Nm) and the remaining bolts to 97 inch lbs. (11 Nm).
    • Torque axis mount
  10. Remove the support fixture.
  11. Install or connect the following:
    • Water pump pulley
    • Water pump hoses
    • Serpentine belt
    • Water pump pulley bolts. Torque the bolts to 115 inch lbs. (13 Nm).
    • Negative battery cable
  12. Refill the cooling system.
  13. Start the vehicle and check for proper operation.
4.0L Engine
    • Air inlet duct
    • Water pump drive belt cover
    • Lower radiator hose and bypass hose
    • Thermostat housing from the water pump housing
    • Water pump from the water pump housing, by turning the locking ring with a Water Pump Remover/Installer tool J-38816
    To install: Fig. 4: Exploded view of the water pump housing and water pump - 4.0L engine 7922xg02.gif
    • Water pump, seat the locking ring
    • Thermostat housing to the water pump housing
    • Lower radiator hose and coolant bypass hose
    • Drive belt and drive belt cover
    • Air inlet duct
  6. Refill and bleed the cooling system.
Jan 24, 2011 | 1995 Oldsmobile Aurora
Were changing the water pump on a 1993 buick lesabre but have run into a problem. Can't get the motor mount out so we can get to the water pump. Have removed 2 bolts and a nut on the engine and all the...
Water Pump REMOVAL & INSTALLATION CAUTION
When draining the coolant, keep in mind that cats and dogs are attracted by ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old. 1987-95 Vehicles EXCEPT 1995 VIN 1 ENGINE
  2. Drain cooling system into a suitable container.
  3. Remove the serpentine drive belt, as outlined in Section 1 of this manual. NOTE: On some engines, removing the alternator provides better clearance for removing the water pump. For alternator removal and installation procedures, please refer to Section 2 of this manual. Fig. 1: After removing the alternator, remove the brace 89633p01.jpg
  4. Unfasten the water pump pulley bolts, (long bolt removed through access hole provided in the body side rail), then remove the pulley. Fig. 2: Pull the water pump pulley from the pump 89633p03.jpg
  5. Disconnect the radiator and heater hoses from water pump. Fig. 3: Use a screwdriver to loosen the hose clamp screws, then disconnect the hoses from the water pump 89633p02.jpg
  6. For 1992-95 vehicles, remove the torque axis mount, as follows:
    1. Use a suitable engine support fixture and lifting bracket to raise the engine slightly to take the weight off of the engine mounts.
    2. Remove the through-bolt from the torque axis (front) engine mount.
    3. Lift the engine with the support fixture until the power steering reservoir touches the strut tower cross brace.
    4. Loosen the bottom two bolts on the torque axis (front) engine mount.
    5. Remove the A/C line clip and top two bolts on the torque axis engine mount, then remove the mount.
    6. Remove the 2 bolts and nut attaching the engine torque axis mount bracket assembly to the front of the engine. NOTE: On some engines, when you remove the 13mm bolts, coolant will flow from the bolt holes, so make sure to position a drain pan under the pump before unfastening the bolts.
  7. Remove the water pump attaching bolts, then remove the water pump from the vehicle. Remove and discard the gasket. Thoroughly clean the gasket mating surfaces. Fig. 4: Unfasten the water pump mounting bolts (see arrows for locations of top bolts) . . . 89633p04.jpg
    Fig. 5: . . . then remove the water pump from the engine 89633p05.jpg
    Fig. 6: Use a gasket scraper to carefully clean the water pump's mating surface 89633p06.jpg
    Fig. 7: You can also use Scotchbrite® or equivalent non-abrasive scouring pad to clean the water pump gasket mating surface 89633p07.jpg
    Fig. 8: When using a scraper to clean the gasket mating surfaces, be careful not to gouge the engine and cause leaks 89633p10.jpg
    Fig. 9: Exploded view of the water pump mounting - 1994 vehicle shown, others similar 89633g37.gif
    To install:
  8. Apply a suitable sealant to the bolt threads. Fig. 10: Coat the bolt threads with a suitable sealing compound 89633p09.jpg
  9. Position a new gasket, then install the water pump to the engine and tighten the retaining bolts, as follows: Fig. 11: Place a new gasket on the water pump mounting surface 89633p08.jpg
    1. For 1987-94 vehicles, tighten the long bolts to 29 ft. lbs. (39 Nm) and the short bolts to 97 inch lbs. (11 Nm).
    2. For 1995 vehicles, tighten the water pump-to-block bolts to 22 ft. lbs. (30 Nm) and the water pump-to-front cover bolts to 11 ft. lbs. (15 Nm), plus an additional 80°rotation.
  10. For 1992-95 vehicles, install the torque axis mount, as follows:
    1. Attach the torque axis engine mount bracket assembly to the front of the engine using the 2 bolts and nut. Fig. 12: Install the torque axis engine mount bracket and secure with the 2 bolts and nut 89633g34.gif
    2. Replace the 2 upper bolts previously removed from the torque axis engine mount, and attach the mount and plastic clip for the A/C lines.
    3. Tighten the 2 lower bolts that were previously loosened on the torque axis engine mount. Fig. 13: Exploded view of the torque axis engine mount and tightening specifications 89633g35.gif
    4. Adjust the engine height to align the torque mount with the torque axis mount bracket.
    5. Insert the through-bolt, attach the retaining nut and tighten to the specifications shown in the accompanying figure. Remove the engine support and lifting fixture. Fig. 14: Insert the torque axis mount bracket through-bolt 89633g36.gif
  11. Install the water pump pulley and secure with the retaining bolts.
  12. Connect the radiator and heater hoses to the water pump.
  13. Install the serpentine drive belt.
  14. Connect the negative battery cable.
  15. Fill cooling system and check for leaks. Start the engine and allow to come to normal operating temperature. Check for leaks and top-off the coolant.
Dec 17, 2010 | Buick LeSabre Cars & Trucks
I need to replace the washer bottle for my 03 ford mondeo
If you still need to do this .... It's a plastic bottle mounted under the front wing on the drivers side of the car. Access to it is from underneath the wheel arch. Removal of the wheel will make it easier. You need to remove the protective liner that stops the majority of water & road dirt from hitting the underside of the wing and thus protects it somewhat from corrosion and damage. This shield is held in place by about 8 screws. The washer bottle itself is secured to the bodywork by 3 bolts. The washer's water pump (maybe 2 pumps if you have the headlamp cleaning system) is mounted in the side of the bottle and is just a push-fit through a rubber seal
Hope this helps
Feb 28, 2010 | 2003 Ford Focus
A friend bought me a cannondale airspeed maximum pump i am trying to mount to my bike it has a snap type mount? with screw holes matching the bottle mounts how does this work? pump will not be centered on...
The pump mount is installed under the bottle cage, if you have one, using the same bolts. Sometimes longer bolts are required.
The pump snaps into its mount besides the bottle cage, on the left or right side.
Nov 04, 2009 | Cycling
I'm trying to remove a Hotpoint RVM58003. I removed four long bolts from the top but it does not move. Any help on what I need to do to remove it? Dan
The Hotpoint RVM58003 (circa 1984) cannot be lifted off a hanger after the four top screws are removed because it doesn't have a separate pre-installed hanger like newer units do. The rear mounting screw holes are part of the outer frame of the unit, which requires removal of the Microwave sub-assembly of the Hotpoint RVM58003 to expose the outer metal frame and the array of pre-drilled rear mounting holes before the rear mounting screw(s) can be accessed and removed. Based on my recent experience removing a Hotpoint RVM58003 Microwave Hood from 1984 it appears the unit was originally installed this way too. Please note that this is a very involved process. Basic steps are: 1) Unplug AC power to the unit, or turn off the circuit breaker. 2) Remove the top plastic grill over the door and control panel (2 screws). 3) Next to the grill screws remove the larger left/right screws holding the Microwave sub-assembly in. 4) Drop down the hinged light bulb/air filter cover panel (mine had 7 screws). 5) Remove the small metal cover plate on the right under the control panel. This exposes the Microwave sub-assembly electrical connector. 6) Disconnect the Microwave sub- assembly connector. 7) Carefully pull the Microwave sub-assembly out of the frame and set aside. You may need to fish the power cord through the cabinet or unscrew the power cord terminals. NOTE: this is best done with a helper because this sub-assembly is about 25-30 pounds. 8) Once the sub-assembly is out the rear plate is exposed and the rear mounting screws can be removed. I found that the GE/Hotpoint Owner's Manual does not have installation instructions. Neither does the GE web site, they only have the Owner's Manual. For more specific help and instructions I suggest calling The GE Answer Center at 800-626-2000 or hiring a professional installer experienced with this older style Microwave Hood.
Jan 23, 2009 | Hotpoint JE740WY/GY Microwave Oven
GMC Denali 700C Road Bike Logo
55 people viewed this question
Top GMC Cycling Experts
Mike
Arnie Burke
Arnie Burke
Donald Ayers-Marsh
Are you a GMC Cycling Expert? Answer questions, earn points and help others
