Question about Dacor Epicure ER48D Stainless Steel Gas Kitchen Range
Dacor f8 oven
How do I clear an F8 error code?
5 Suggested Answers
ngfam1
  • 639 Answers
SOURCE: F1 Error Dacor oven
I'm Neil and glad to be at your service!
This time you need to call service!
For a good service you might try,
A&E Factory service
1-800-905-9505 7days / 24hours Nation Wide
Please give me a solution rating here at fixya.com
Thank You
Neil
Posted on Aug 24, 2008
  • 187 Answers
SOURCE: Dacor range will no unlock after self-clean mode.
Try to reset the oven cleaner- set it to go off in five minutes and the lock should release at the end of the cycle. Also, ake sure you didn't accidentally set a child lock or delayed cleaning. If that doesn't work, go to your breaker box (or unplug it) and shut the power off. It should reset the electronics. If this does not work, please leave a comment telling me what kind of oven it is, manufacturer and model, and how it is powered, etc. thank you for your question.
Posted on Nov 18, 2009
  • 1891 Answers
SOURCE: Dacor Model# ERD36, Oven Element no heat & no error code flashes.
look for a hi limit thermo in burner box or on back of oven . if it has over heated this would cause this . dacor has a resetable one . it may be located on left side panel will have to be removed . ck elect sch tof location .. mm
Posted on Dec 04, 2009
  • 794 Answers
SOURCE: error code F8 keeps coming up. I was trying to run
Hi vicktys,
The error code F8 that you are getting from your machine means that there's something wrong with the door locking switch. You need to check if there's any loose wiring as well as the door locking switches. If the wiring is fine you might need to replace the door latch assembly.You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Posted on Jun 06, 2011
Frigidaire Gallery series model GLEB30T8CBA key pad not working
Hello Dana, thank you for your post!
From my understanding your Frigidaire oven is displaying an error code of "F8" and your keypad is not working properly. An "F8" error stands for runaway temperature (overheating). I would recommend performing a reset on your oven and you can do that by disconnecting the power cord for at least ten minutes.
If that does not help correct your issue then you could have a problem with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would suggest having a professional technician out to perform a proper diagnosis and repair. I hope this information is helpful. -Matt
Jan 10, 2016 | Frigidaire 30 in. Electric Gallery Series...
F8 alert. What does this mean? The clock and "cancel" buttons work, but no heating buttons work, and self-clean will not operate.
F8 code means your door latch assy needs to be replaced, them you have options:
1. Turn it off on the circuit braker
2. Replace the door latch.
It will continue to try to lock itself most likely, as door latch micro-switch logic is messed up.
Hope helps.
Jan 03, 2011 | Dacor ECD230 Epicure Electric Double Oven
Error code F8 keeps coming up. I was trying to run the self clean program and it wouldn't work. Now error code keeps coming up regardless of what mode oven is in
Hi vicktys,
Hope this helps.
Nov 22, 2010 | Dacor Epicure ERD30 Dual Fuel (Electric...
I pressed the self clean option and the oven locked but every two minutes an alarm sounds and the code F8 appears. The cancel option stops the alarm temporarily. How do I either clean the oven or cancel...
F8 code means your door latch assy needs to be replaced. Two options:
It will continue to try to lock itself most likely, as door latch microswitch logic is messed up.
www.oc-repair.com
Feb 10, 2010 | Dacor ECD230 Epicure Electric Double Oven
GE lower oven displaying code F8. Clear off does not clear code
Your ERC(clock) has failed. Replace the electronic oven control.
May 26, 2009 | GE JRP15 Electric Single Oven
Display 11
your control must be fried...dacor fault codes are f0 to F8 the display must be faulty..
Aug 25, 2007 | Dacor ECD230 Epicure Electric Double Oven
SELF CLEANING DOES'T WORK
"F8" ERROR MESSAGE. This indicates a door latch failure.
Jun 25, 2007 | Dacor ECS130 Epicure Electric Single Oven
Kenmore Gas oven is giving F8 error code
Unfortunately the F8 usually means an EEPROM data shift error. Try turning the power on and off several times. If error continues, you have no choice but to replace the ERC. Check on line for the best price. There is a group in the Chicago area that repairs ERCs. Check them out at www.cgiltd.com The failure of the your power system may have been associated with a surge either as the power went off or when it came back on. It may have been the surge that did the damage.
May 19, 2007 | Kenmore 30464 / 30465 / 30469 Gas Single...
Dacor Epicure ER48D Stainless Steel Gas Kitchen Range Logo
83 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
240cpa
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
